Home » Archived » BIRT » Locate a java class
Locate a java class [message #650946] Thu, 27 January 2011 04:27 Go to next message
I currently open reports, that I have designed with Eclipse-BIRT-Report-Designer-Plugin, via WebViewer.display()
out of an RCP-application.
Up to now, I used a XML-File as datasource and everything worked fine.
Now I tried to use a java-class to deliver data.
The java-class is located in the same plugin as the report .
When I preview the result in the reportDesigner-Plugin for Eclipse, it is running, but when I start
the application, it seems that it does not find my java-class.
My dataset-open-script:
importPackage(Packages.com.test.reports.modelprovider);
count=0;
modelProvider = ModelProvider.getInstance();
modelData = modelProvider.getTestdata();
(comment: ModelProvider is singleton with public method "getInstance()")
Now to my question:
When I view the report out of my application, it seems to crash at the script-line:
What do I have to do, to make the report find this class?
Dominik
PS: I use BIRT 2.6.1 and Eclipse 3.6
Re: Locate a java class [message #651076 is a reply to message #650946] Thu, 27 January 2011 12:01 Go to previous messageGo to next message
Dominik,
Are you setting the parent classloader for the engine?
Take a look at this example:
http://www.birt-exchange.org/org/devshare/designing-birt-rep orts/889-rcp-app-with-birt-and-scripted-datasource/
Jason
On 1/27/2011 4:27 AM, Dominik wrote:
> count=0;
> Now to my question:
> script-line:
> Dominik
Re: Locate a java class [message #651257 is a reply to message #651076] Fri, 28 January 2011 10:22 Go to previous message
Jason,
no I didn´t and that was my problem.
Now its working.
Thanks a lot,
Dominik
Previous Topic:Birt Integration
Next Topic:Reading delimited data from web
Current Time: Thu Jul 24 20:40:30 EDT 2025
Powered by FUDForum. Page generated in 0.04414 seconds
