Home » Archived » AM3 » [AM3 XML injector]
[AM3 XML injector] [message #650616] Tue, 25 January 2011 12:37 Go to next message
I'm trying to launch the XML injector from a ant file:
		<atl.loadModel name="MyXMLModel" metamodel="XML" path="${XML_M_path}">
			<injector name="XML" />
		</atl.loadModel>
But I get the following error (because the XML injectors are not embedded with ATL 3.1):
[atl.loadModel] org.eclipse.m2m.atl.core.ATLCoreException: org.eclipse.m2m.atl.core.injector XML not found, check the spelling or register it manually
[atl.loadModel] 	at org.eclipse.m2m.atl.core.service.CoreService.getInjector(CoreService.java:243)
So my question is: how can I install the XML injector ?
thanks
Re: [AM3 XML injector] [message #650719 is a reply to message #650616] Wed, 26 January 2011 04:19 Go to previous messageGo to next message
Hi El Arbi,
AM3 is now part of the MDT-MoDisco project: http://wiki.eclipse.org/index.php/AM3
To get the ATL3.x compatible XML projectors plug-in named "org.eclipse.m2m.atl.projectors.xml", you need to follow the instructions from http://wiki.eclipse.org/index.php?title=AM3/How_Install_New_ AM3_From_SVN (select the SVN trunk).
I hope this help.
Hugo
Re: [AM3 XML injector] [message #651265 is a reply to message #650719] Fri, 28 January 2011 11:19 Go to previous message
Thanks Hugo!
Previous Topic:[AM3] Extending AM3 Metamodel
Next Topic:ATL metamodel validated
Current Time: Mon Nov 03 08:52:39 EST 2025
Powered by FUDForum. Page generated in 0.04969 seconds
