Home » Archived » BIRT » SQL Text and Birt formating
SQL Text and Birt formating [message #650310] Mon, 24 January 2011 05:55 Go to next message
I am reading a text type column from MS Sql database to Birt. On HTML everything looks fine but when I print it to PDF the text doesn't look ok anymore.
In PDF I don't get any line changes.
Datatype for the Birt element is String.
edit: Actually in PDF I only get the first line.
[Updated on: Mon, 24 January 2011 06:10] by Moderator
Re: SQL Text and Birt formating [message #650391 is a reply to message #650310] Mon, 24 January 2011 12:16 Go to previous messageGo to next message
What is in the text?
Jason
On 1/24/2011 5:55 AM, Ville Kaukonen wrote:
> Hello,
> I am reading a column text from MS Sql database to Birt. On HTML
> ok anymore.
Re: SQL Text and Birt formating [message #650466 is a reply to message #650391] Tue, 25 January 2011 01:44 Go to previous messageGo to next message
Basically it's text saved from normal html text box to database. It's in MS SQL Text type column.
So I believe that text comes with char(13)+char(10) line changes. Or atleast that has been common earlier. I tried to replace those marks in Birt with a placeholder, but I saw no replacement. dataSetRow["Lisätietoja"].replace(String.fromCharCode(13)+String.fromCharCode(10), "</ br>")
Also I tested to export the document to word. There the lines changes worked just fine.
http://gdp.kapsi.fi/pics/Birt_problem.JPG
Example of my problem.
[Updated on: Tue, 25 January 2011 02:42] by Moderator
Re: SQL Text and Birt formating [message #650589 is a reply to message #650466] Tue, 25 January 2011 10:48 Go to previous messageGo to next message
I did not get the attachment. Are you using a text box or a dynamic
text box report item in the design to display it?
Jason
> worked just fine.
Re: SQL Text and Birt formating [message #650696 is a reply to message #650589] Wed, 26 January 2011 02:02 Go to previous message
Alright!
Yeah I had just drag and dropped the data set from the data source menu to the project. Now I added a new Dynamic Text box and bind it to data source. I actually had tried this before, but i got reference errors. Now that I did the biding correctly on the dynamic textbox, the text output was like magic.
So problem solved. Thank you very much.
[Updated on: Wed, 26 January 2011 03:12] by Moderator
Previous Topic:Properties file
Next Topic:Round average aggregation on chart
Current Time: Sat Jul 26 06:09:36 EDT 2025
Powered by FUDForum. Page generated in 0.27927 seconds
