Home » Eclipse Projects » Virgo » Create a web bundle project, and deploy it within Eclipse
Create a web bundle project, and deploy it within Eclipse [message #649523] Wed, 19 January 2011 09:58 Go to next message
I am creating a web bundle to implement an configuration interface. I created a new bundle project, following greenpages.web example. But I'm not able to deploy this bundle in my Virgo Web Server within Eclipse.
If I build my project with maven, and copy/paste the war into the pickup, it starts fine.
But if I drag and drop my project on my server instance in Eclipse, the deployment fails.
After analyzing the content of the war in one case, and of the stage directory in the other case, I identified several differences that could explain the problem :
  1. The MANIFEST.MF file is not the one generated by Bundlor
  2. The directory structure is quite different. For example, the ftl directory is under WEB-INF in the war file, whereas it is directely under the bundle root in the stage directory
I'd like to have more explainations on what the tooling is doing behind the scene during deployment of artifacts. This is not the first time I'm facing difficulties with deployement within Eclipse, and it would make things much more easy if we'd have a piece of documentation on this topic.
In this specific case, is there some specific recommandations to follow to deploy web bundle in Virgo?
Re: Create a web bundle project, and deploy it within Eclipse [message #649984 is a reply to message #649523] Fri, 21 January 2011 04:56 Go to previous messageGo to next message
The goal of the tooling is to make deployment of web bundles really easy, so this sounds like a bug or a problem within your settings, maybe.
I would suggest you open a bug report in bugzilla. It would be great if you could attach a small zipped sample project to the bug entry with some steps how to reproduce. Ok? I will take a look at it.
-Martin
Re: Create a web bundle project, and deploy it within Eclipse [message #650072 is a reply to message #649984] Fri, 21 January 2011 10:55 Go to previous message
Thanx Martin,
I created the new bug at https://bugs.eclipse.org/bugs/show_bug.cgi?id=335008
If I can help you in investigating on that issue, just let me know.
Lorie
Previous Topic:[virgo kernel] ExtensionsHookConfigurator breaks resource loading in Pax Web/Felix Webconsole
Next Topic:Virgo and log4j
Current Time: Sun Jul 27 14:14:45 EDT 2025
Powered by FUDForum. Page generated in 0.05174 seconds
