Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] recursive import not supported
[Acceleo 3] recursive import not supported [message #649287] Tue, 18 January 2011 10:39 Go to next message
Hi all,
I face problems with the import directive. It doesn't import templates recursively, and so the generation output is not the one expected.
I created a small project to explain that (importbug.zip). There is a basic metamodel, an instance of it and 3 templates.
A concept named 'container' holds references to A concepts. AA and AB concepts inherits from A.
The main template (generate) calls the genA template on A elements hold in the container. The genA template is defined in generateA.mtl. Specializations of the genA template are defined in generateAA.mtl. generate.mtl imports generateA.mtl importing generateAA.mtl itself.
The expected result for the given model (container.xmi) is:
        genA
	genAA
	genAB
but I got
	genA
	genA
	genA
It seems like a bug (or a missing feature), right?
Christophe.
Re: [Acceleo 3] recursive import not supported [message #649298 is a reply to message #649287] Tue, 18 January 2011 11:27 Go to previous messageGo to next message
Hi Christophe,
Could you show us a small example of your templates ? Because from our point of you it seems to be a simple problem of polymorphism, keep in mind that the type of an element is resolved during the runtime.
Stephane Begaudeau, Obeo
Re: [Acceleo 3] recursive import not supported [message #649330 is a reply to message #649298] Tue, 18 January 2011 13:37 Go to previous messageGo to next message
Hi Stephane,
The whole project can be downloaded with the link provided in my first message. this is not a polymorphism problem. This sample works fine if you merge the generateA and the generateAA templates.
Christophe.
Re: [Acceleo 3] recursive import not supported [message #649439 is a reply to message #649287] Wed, 19 January 2011 04:08 Go to previous message
Hi Christophe,
I'm sorry I didn't see the zip archive before Smile
So, the problem is clearly coming from recursive imports that are not supported and we do not intend to support it (just like in Java).
Stephane Begaudeau, Obeo.
Previous Topic:[Acceleo 3] Casting to supertype necessary!
Next Topic:[Acceleo 3] Problems in memory management
Current Time: Wed Jul 23 10:43:40 EDT 2025
Powered by FUDForum. Page generated in 0.05984 seconds
