Home » Language IDEs » Java Development Tools (JDT) » Eclipse crashes(Eclipse crashes)
Eclipse crashes [message #648747] Fri, 14 January 2011 06:57 Go to next message
Hello to everyone!
I use Slackware 13.1 and Eclipse 3.6 Helios
When I use autocomplete(CTRL-Space), Eclipse crashes with the following log.
Could anyone help me to resolve this issue?
Dzmitry.
Crash log:
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0xb2552512, pid=2048, tid=3076511424
# JRE version: 6.0_20-b02
# Java VM: Java HotSpot(TM) Client VM (16.3-b01 mixed mode, sharing linux-x86 )
# Problematic frame:
# C  [libxpcom_core.so+0x52512]
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  T H R E A D  ---------------
Current thread (0x080db400):  JavaThread "main" [_thread_in_native, id=2048, stack(0xbf91c000,0xbf96c000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0xff64bcf0
Registers:
EAX=0xff64bcf0, EBX=0xb259ab9c, ECX=0x086d4f6a, EDX=0xbf96a6f0
ESP=0xbf969660, EBP=0xbf9696a8, ESI=0xbf96a6f4, EDI=0xbf96a6f8
EIP=0xb2552512, CR2=0xff64bcf0, EFLAGS=0x00210286
Top of Stack: (sp=0xbf969660)
0xbf969660:   bf96a6ec bf96a6f0 bf96a6ec 08580e28
0xbf969670:   00000000 00000001 00000000 00000000
0xbf969680:   00000000 00000000 000003dc 10daa042
0xbf969690:   b2504b20 b259ab9c bf9696ec b259ab9c
0xbf9696a0:   bf9696ec bf96a6ff bf96a718 b2552833
0xbf9696b0:   bf96a6ff bf96a6f8 bf96a6f4 bf96a6f0
0xbf9696c0:   bf96a6ec 00001000 bf96a718 b25527a5
0xbf9696d0:   b2649288 bf96a6f4 bf96a6f0 bf96a6ec
Instructions: (pc=0xb2552512)
0xb2552502:   74 8d 8b 01 85 c0 74 87 89 4d c0 8d 76 00 8b 07
0xb2552512:   66 8b 00 8b 0a 88 01 83 07 02 ff 0e ff 02 8b 4d
Stack: [0xbf91c000,0xbf96c000],  sp=0xbf969660,  free space=135bf968ff0k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [libxpcom_core.so+0x52833]  _Z22NS_CopyUnicodeToNativeRK18nsAString_internalR19nsACString_internal+0xb3
C  [libxpcom_core.so+0x5ac82]  NS_NewLocalFile_P+0x32
C  [libxpcom.so+0x2764]  NS_NewLocalFile+0x24
C  [libswt-mozilla-gtk-3650.so+0x6cee]  Java_org_eclipse_swt_internal_mozilla_XPCOM__1NS_1NewLocalFile+0x52
j  org.eclipse.swt.internal.mozilla.XPCOM._NS_NewLocalFile(II[I)I+0
j  org.eclipse.swt.internal.mozilla.XPCOM.NS_NewLocalFile(II[I)I+10
j  org.eclipse.swt.browser.AppFileLocProvider.<init>(Ljava/lang/String;Ljava/lang/String;Z)V+94
j  org.eclipse.swt.browser.Mozilla.create(Lorg/eclipse/swt/widgets/Composite;I)Z+559
j  org.eclipse.swt.browser.Browser.<init>(Lorg/eclipse/swt/widgets/Composite;I)V+302
j  org.eclipse.jface.internal.text.html.BrowserInformationControl.isAvailable(Lorg/eclipse/swt/widgets/Composite;)Z+12
j  org.eclipse.jdt.internal.ui.text.java.AbstractJavaCompletionProposal.getInformationControlCreator()Lorg/eclipse/jface/text/IInformationControlCreator;+9
j  org.eclipse.jface.text.contentassist.AdditionalInfoController.computeInformation()V+18
j  org.eclipse.jface.text.AbstractInformationControlManager.doShowInformation()V+11
j  org.eclipse.jface.text.AbstractInformationControlManager.showInformation()V+8
j  org.eclipse.jface.text.contentassist.AdditionalInfoController.showInformation(Lorg/eclipse/jface/text/contentassist/ICompletionProposal;Ljava/lang/Object;)V+64
j  org.eclipse.jface.text.contentassist.AdditionalInfoController$10.showInformation(Lorg/eclipse/jface/text/contentassist/ICompletionProposal;Ljava/lang/Object;)V+25
j  org.eclipse.jface.text.contentassist.AdditionalInfoController$9.run()V+36
j  org.eclipse.swt.widgets.RunnableLock.run()V+11
j  org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Z)Z+29
j  org.eclipse.swt.widgets.Display.runAsyncMessages(Z)Z+5
j  org.eclipse.swt.widgets.Display.readAndDispatch()Z+58
j  org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widgets/Display;)V+9
j  org.eclipse.ui.internal.Workbench.runUI()I+555
j  org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
j  org.eclipse.ui.internal.Workbench$7.run()V+55
j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/Runnable;)V+12
j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+2
j  org.eclipse.ui.internal.ide.application.IDEApplication.start(Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Object;+99
j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Object;+135
j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Ljava/lang/Object;+29
j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object;+149
j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
v  ~StubRoutines::call_stub
V  [libjvm.so+0x219840]
V  [libjvm.so+0x33f298]
V  [libjvm.so+0x21969f]
V  [libjvm.so+0x36c2db]
V  [libjvm.so+0x36f241]
V  [libjvm.so+0x2955cf]
C  [libjava.so+0x15314]  Java_sun_reflect_NativeMethodAccessorImpl_invoke0+0x34
j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87
j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+161
j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+211
j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+126
j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
V  [libjvm.so+0x24bebb]
V  [libjvm.so+0x22d66e]
C  [eclipse_1307.so+0x7fd1]  startJavaJNI+0x418
C  [eclipse_1307.so+0x959c]  startJavaVM+0x24
C  [eclipse_1307.so+0x30d6]  run+0x588
C  [eclipse+0x10ee]
C  [libc.so.6+0x16b86]  __libc_start_main+0xe6
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0xb279a000 JavaThread "Additional info timer" [_thread_blocked, id=2133, stack(0xb25d3000,0xb2623000)]
  0xb27a7400 JavaThread "Thread-9" [_thread_blocked, id=2132, stack(0xb2819000,0xb2869000)]
  0xb27a5800 JavaThread "Thread-7" [_thread_in_native, id=2131, stack(0xb2f01000,0xb2f51000)]
  0x083b3c00 JavaThread "Worker-3" [_thread_blocked, id=2129, stack(0xb3137000,0xb3187000)]
  0xb2c8dc00 JavaThread "org.eclipse.jdt.internal.ui.text.JavaReconciler" daemon [_thread_blocked, id=2090, stack(0xb2d41000,0xb2d91000)]
  0x083cec00 JavaThread "Worker-2" [_thread_blocked, id=2086, stack(0xb2f51000,0xb2fa1000)]
  0x083d0800 JavaThread "Java indexing" daemon [_thread_blocked, id=2082, stack(0xb2fb0000,0xb3000000)]
  0xb3a82800 JavaThread "Worker-1" [_thread_blocked, id=2078, stack(0xb31ba000,0xb320a000)]
  0x08148c00 JavaThread "Worker-0" [_thread_blocked, id=2077, stack(0xb3612000,0xb3662000)]
  0xb3a50c00 JavaThread "Worker-JM" [_thread_blocked, id=2076, stack(0xb3565000,0xb35b5000)]
  0xb3a7e800 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=2075, stack(0xb35c2000,0xb3612000)]
  0x0818dc00 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=2073, stack(0xb3662000,0xb36b2000)]
  0xb3a57c00 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=2072, stack(0xb36b2000,0xb3702000)]
  0xb3a54800 JavaThread "State Data Manager" daemon [_thread_blocked, id=2071, stack(0xb3702000,0xb3752000)]
  0xb3a00c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2063, stack(0xb39b0000,0xb3a00000)]
  0x0810a800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2062, stack(0xb3b20000,0xb3ba0000)]
  0x08108c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2061, stack(0xb3ba0000,0xb3bf0000)]
  0x08104400 JavaThread "Finalizer" daemon [_thread_blocked, id=2060, stack(0xb3bf0000,0xb3c40000)]
  0x080ff800 JavaThread "Reference Handler" daemon [_thread_blocked, id=2059, stack(0xb3c40000,0xb3c90000)]
=>0x080db400 JavaThread "main" [_thread_in_native, id=2048, stack(0xbf91c000,0xbf96c000)]
Other Threads:
  0x080fe000 VMThread [stack: 0xb3c90000,0xb3d10000] [id=2058]
  0xb3a03400 WatcherThread [stack: 0xb3930000,0xb39b0000] [id=2064]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 def new generation   total 16064K, used 10740K [0x6aea0000, 0x6c000000, 0x72ea0000)
  eden space 14336K,  62% used [0x6aea0000, 0x6b76d0d8, 0x6bca0000)
  from space 1728K, 100% used [0x6be50000, 0x6c000000, 0x6c000000)
  to   space 1728K,   0% used [0x6bca0000, 0x6bca0000, 0x6be50000)
 tenured generation   total 35448K, used 22635K [0x72ea0000, 0x7513e000, 0x82ea0000)
   the space 35448K,  63% used [0x72ea0000, 0x744bac80, 0x744bae00, 0x7513e000)
 compacting perm gen  total 39424K, used 39402K [0x82ea0000, 0x85520000, 0x92ea0000)
   the space 39424K,  99% used [0x82ea0000, 0x8551aa80, 0x8551ac00, 0x85520000)
    ro space 10240K,  58% used [0x92ea0000, 0x9346db98, 0x9346dc00, 0x938a0000)
    rw space 12288K,  59% used [0x938a0000, 0x93fce438, 0x93fce600, 0x944a0000)
Dynamic libraries:
08048000-0804c000 r-xp 00000000 08:01 420229     /opt/eclipse/eclipse
0804c000-0804d000 rw-p 00003000 08:01 420229     /opt/eclipse/eclipse
0804d000-08a06000 rw-p 00000000 00:00 0          [heap]
6aea0000-6c000000 rw-p 00000000 00:00 0
6c000000-72ea0000 rw-p 00000000 00:00 0
72ea0000-7513e000 rw-p 00000000 00:00 0
7513e000-82ea0000 rw-p 00000000 00:00 0
82ea0000-85520000 rw-p 00000000 00:00 0
85520000-92ea0000 rw-p 00000000 00:00 0
92ea0000-9346e000 r--s 00001000 08:01 350479     /usr/java/jre1.6.0_20/lib/i386/client/classes.jsa
9346e000-938a0000 rw-p 00000000 00:00 0
938a0000-93fcf000 rw-p 005cf000 08:01 350479     /usr/java/jre1.6.0_20/lib/i386/client/classes.jsa
93fcf000-944a0000 rw-p 00000000 00:00 0
944a0000-9457c000 rw-p 00cfe000 08:01 350479     /usr/java/jre1.6.0_20/lib/i386/client/classes.jsa
9457c000-948a0000 rw-p 00000000 00:00 0
948a0000-948a8000 r-xs 00dda000 08:01 350479     /usr/java/jre1.6.0_20/lib/i386/client/classes.jsa
948a8000-94ca0000 rw-p 00000000 00:00 0
b2414000-b24d5000 r-xp 00000000 08:01 218        /usr/lib/libasound.so.2.0.0
b24d5000-b24d9000 rw-p 000c1000 08:01 218        /usr/lib/libasound.so.2.0.0
b24fc000-b24fe000 r-xp 00000000 08:01 13869      /usr/lib/gconv/UTF-16.so
b24fe000-b24ff000 r--p 00001000 08:01 13869      /usr/lib/gconv/UTF-16.so
b24ff000-b2500000 rw-p 00002000 08:01 13869      /usr/lib/gconv/UTF-16.so
b2500000-b2593000 r-xp 00000000 08:01 332055     /usr/lib/seamonkey-2.0.4/libxpcom_core.so
b2593000-b259c000 rw-p 00092000 08:01 332055     /usr/lib/seamonkey-2.0.4/libxpcom_core.so
b259c000-b259f000 r-xp 00000000 08:01 271143     /usr/lib/seamonkey-2.0.4/libplc4.so
b259f000-b25a0000 rw-p 00002000 08:01 271143     /usr/lib/seamonkey-2.0.4/libplc4.so
b25a0000-b25d0000 r-xp 00000000 08:01 271146     /usr/lib/seamonkey-2.0.4/libnspr4.so
b25d0000-b25d1000 rw-p 00030000 08:01 271146     /usr/lib/seamonkey-2.0.4/libnspr4.so
b25d1000-b25d3000 rw-p 00000000 00:00 0
b25d3000-b25d6000 ---p 00000000 00:00 0
b25d6000-b2623000 rwxp 00000000 00:00 0
b2623000-b2628000 r-xp 00000000 08:01 14105      /lib/libnss_dns-2.11.1.so
b2628000-b2629000 r--p 00004000 08:01 14105      /lib/libnss_dns-2.11.1.so
b2629000-b262a000 rw-p 00005000 08:01 14105      /lib/libnss_dns-2.11.1.so
b262a000-b262c000 r-xp 00000000 08:01 271149     /usr/lib/seamonkey-2.0.4/libplds4.so
b262c000-b262d000 rw-p 00001000 08:01 271149     /usr/lib/seamonkey-2.0.4/libplds4.so
b262d000-b2630000 r-xp 00000000 08:01 331846     /usr/lib/seamonkey-2.0.4/libxpcom.so
b2630000-b2631000 rw-p 00002000 08:01 331846     /usr/lib/seamonkey-2.0.4/libxpcom.so
b2631000-b2649000 r-xp 00000000 08:03 144932     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/151/1/.cp/libswt-mozilla-gtk-3650.so
b2649000-b264a000 rw-p 00018000 08:03 144932     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/151/1/.cp/libswt-mozilla-gtk-3650.so
b264a000-b264f000 r-xp 00000000 08:03 144931     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/151/1/.cp/libswt-xpcominit-gtk-3650.so
b264f000-b2651000 rw-p 00005000 08:03 144931     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/151/1/.cp/libswt-xpcominit-gtk-3650.so
b2651000-b2660000 r--s 000da000 08:01 421020     /opt/eclipse/plugins/org.eclipse.ant.ui_3.5.0.v20100427.jar
b2660000-b2669000 r--s 000aa000 08:01 421119     /opt/eclipse/plugins/org.eclipse.pde.api.tools_1.0.201.v20100602-0930.jar
b2669000-b2678000 r--p 00000000 08:01 238183     /usr/share/locale/ru/LC_MESSAGES/glib20.mo
b2678000-b267a000 r--s 00017000 08:01 420472     /opt/eclipse/plugins/org.eclipse.update.configurator_3.3.100.v20100512.jar
b267a000-b2684000 r--s 00088000 08:01 421287     /opt/eclipse/plugins/org.eclipse.update.core_3.2.400.v20100512.jar
b2684000-b2686000 r--s 00003000 08:01 421472     /opt/eclipse/plugins/org.eclipse.equinox.p2.updatechecker_1.1.100.v20100503a.jar
b2686000-b2689000 r--s 00018000 08:01 420438     /opt/eclipse/plugins/org.eclipse.equinox.p2.metadata.repository_1.1.0.v20100513.jar
b2689000-b268d000 r--s 00021000 08:01 421501     /opt/eclipse/plugins/org.eclipse.equinox.p2.repository_2.0.0.v20100519.jar
b268d000-b2695000 r--s 00049000 08:01 421173     /opt/eclipse/plugins/org.eclipse.equinox.p2.metadata_2.0.0.v20100601.jar
b2695000-b2699000 r--s 00028000 08:01 421021     /opt/eclipse/plugins/org.eclipse.equinox.p2.engine_2.0.0.v20100606.jar
b2699000-b269b000 r--s 0000b000 08:01 421292     /opt/eclipse/plugins/org.eclipse.equinox.p2.operations_2.0.0.v20100510.jar
b269b000-b269e000 r--s 0000c000 08:01 421475     /opt/eclipse/plugins/org.eclipse.equinox.p2.ui.sdk.scheduler_1.0.0.v20100507-1815.jar
b269e000-b26a0000 r--s 0000a000 08:01 421158     /opt/eclipse/plugins/org.eclipse.ui.net_1.2.100.I20100505-1245.jar
b26a0000-b2700000 rw-s 00000000 00:04 425997     /SYSV00000000 (deleted)
b2700000-b27ff000 rw-p 00000000 00:00 0
b27ff000-b2800000 ---p 00000000 00:00 0
b2800000-b2803000 r--s 00013000 08:01 350692     /usr/java/jre1.6.0_20/lib/jce.jar
b2803000-b2804000 r--s 00008000 08:01 421012     /opt/eclipse/plugins/org.eclipse.core.net.linux.x86_1.1.0.I20100505-1245.jar
b2804000-b2807000 r--s 00017000 08:01 420429     /opt/eclipse/plugins/org.eclipse.equinox.security_1.0.200.v20100503.jar
b2807000-b280a000 r--s 0000e000 08:01 421186     /opt/eclipse/plugins/org.eclipse.core.net_1.2.100.I20100511-0800.jar
b280a000-b2813000 r--s 0005b000 08:01 420420     /opt/eclipse/plugins/org.eclipse.jdt.junit_3.6.0.v20100526-0800.jar
b2813000-b2815000 r--s 00014000 08:01 420954     /opt/eclipse/plugins/org.eclipse.ui.intro.universal_3.2.400.v20100517/universal.jar
b2815000-b2819000 r--s 0001d000 08:01 421143     /opt/eclipse/plugins/org.eclipse.ui.externaltools_3.2.0.v20100427.jar
b2819000-b281c000 ---p 00000000 00:00 0
b281c000-b2869000 rwxp 00000000 00:00 0
b2869000-b2885000 r--s 00141000 08:01 421337     /opt/eclipse/plugins/org.eclipse.team.ui_3.5.100.I20100527-0800.jar
b2885000-b2887000 r--s 00007000 08:01 421502     /opt/eclipse/plugins/org.eclipse.core.variables_3.2.400.v20100505.jar
b2887000-b288b000 r--s 00024000 08:01 421148     /opt/eclipse/plugins/org.eclipse.ui.console_3.5.0.v20100526.jar
b288b000-b288f000 r--s 0001e000 08:01 420489     /opt/eclipse/plugins/org.eclipse.ui.views.log_1.0.100.v20100423.jar
b288f000-b28c6000 r--p 00000000 08:01 310068     /usr/share/fonts/TTF/DejaVuSansMono-BoldOblique.ttf
b28c6000-b28fe000 r--p 00000000 08:01 310079     /usr/share/fonts/TTF/DejaVuSansMono-Oblique.ttf
b28fe000-b2948000 r--p 00000000 08:01 310075     /usr/share/fonts/TTF/DejaVuSansMono-Bold.ttf
b2948000-b2997000 r--p 00000000 08:01 310076     /usr/share/fonts/TTF/DejaVuSansMono.ttf
b2997000-b29b1000 r--s 0012c000 08:01 421116     /opt/eclipse/plugins/org.eclipse.jdt.debug.ui_3.5.0.v20100602-0830.jar
b29b1000-b2a31000 r--p 00000000 08:01 310067     /usr/share/fonts/TTF/DejaVuSans-BoldOblique.ttf
b2a31000-b2ab1000 r--p 00000000 08:01 310062     /usr/share/fonts/TTF/DejaVuSans-Oblique.ttf
b2ab1000-b2b3d000 r--p 00000000 08:01 310077     /usr/share/fonts/TTF/DejaVuSans-Bold.ttf
b2b3d000-b2b6e000 r--s 00240000 08:01 420414     /opt/eclipse/plugins/org.eclipse.debug.ui_3.6.0.v20100601-1530.jar
b2b6e000-b2c00000 r--s 008f6000 08:01 421163     /opt/eclipse/plugins/org.eclipse.jdt.ui_3.6.0.v20100602-1600.jar
b2c00000-b2d00000 rw-p 00000000 00:00 0
b2d00000-b2d03000 r--s 00019000 08:01 420422     /opt/eclipse/plugins/org.eclipse.pde.launching_3.6.0.v20100601.jar
b2d03000-b2d0d000 r--s 00066000 08:01 421238     /opt/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.5.0.v20100526-0800.jar
b2d0d000-b2d14000 r--s 00048000 08:01 420427     /opt/eclipse/plugins/org.eclipse.ltk.core.refactoring_3.5.100.v20100526-0800.jar
b2d14000-b2d17000 r--s 00013000 08:01 420442     /opt/eclipse/plugins/org.eclipse.ui.views_3.5.0.I20100527-0800.jar
b2d17000-b2d20000 r--s 0005a000 08:01 420443     /opt/eclipse/plugins/org.eclipse.pde.api.tools.ui_1.0.200.v20100601-1815.jar
b2d20000-b2d23000 r--s 00019000 08:01 420453     /opt/eclipse/plugins/org.eclipse.core.filebuffers_3.5.100.v20100520-0800.jar
b2d23000-b2d36000 r--s 000dc000 08:01 421503     /opt/eclipse/plugins/org.eclipse.jface.text_3.6.0.v20100526-0800.jar
b2d36000-b2d40000 r-xp 00000000 08:03 144727     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/151/1/.cp/libswt-cairo-gtk-3650.so
b2d40000-b2d41000 rw-p 00009000 08:03 144727     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/151/1/.cp/libswt-cairo-gtk-3650.so
b2d41000-b2d44000 ---p 00000000 00:00 0
b2d44000-b2d91000 rwxp 00000000 00:00 0
b2d91000-b2d94000 rw-s 00000000 00:04 393228     /SYSV00000000 (deleted)
b2d94000-b2d96000 r--s 0000e000 08:01 420433     /opt/eclipse/plugins/org.eclipse.compare.core_3.5.100.I20100526-0800.jar
b2d96000-b2da1000 r--s 0007d000 08:01 421114     /opt/eclipse/plugins/org.eclipse.ui.editors_3.6.0.v20100520-0800.jar
b2da1000-b2dad000 r--s 00082000 08:01 421031     /opt/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.6.0.v20100520-0800.jar
b2dad000-b2df6000 r--s 003b8000 08:01 421444     /opt/eclipse/plugins/org.eclipse.pde.ui_3.6.0.v20100601.jar
b2df7000-b2e00000 r--s 00069000 08:01 421245     /opt/eclipse/plugins/org.eclipse.search_3.6.0.v20100520-0800.jar
b2e00000-b2f00000 rw-p 00000000 00:00 0
b2f00000-b2f01000 r--s 00007000 08:01 421218     /opt/eclipse/plugins/org.eclipse.update.scheduler_3.2.300.v20100512.jar
b2f01000-b2f04000 ---p 00000000 00:00 0
b2f04000-b2f51000 rwxp 00000000 00:00 0
b2f51000-b2f54000 ---p 00000000 00:00 0
b2f54000-b2fa1000 rwxp 00000000 00:00 0
b2fa1000-b2fa8000 r--s 00052000 08:01 421123     /opt/eclipse/plugins/org.eclipse.jdt.apt.core_3.3.400.v20100513-0845.jar
b2fa8000-b2fb0000 r--s 0004c000 08:01 421132     /opt/eclipse/plugins/org.eclipse.debug.core_3.6.0.v20100519.jar
b2fb0000-b2fb3000 ---p 00000000 00:00 0
b2fb3000-b3000000 rwxp 00000000 00:00 0
b3000000-b3100000 rw-p 00000000 00:00 0
b3100000-b3103000 r--s 00012000 08:01 421298     /opt/eclipse/plugins/org.eclipse.jdt.core.manipulation_1.3.0.v20100520-0800.jar
b3103000-b3107000 r--s 0003b000 08:01 421126     /opt/eclipse/plugins/org.eclipse.help_3.5.0.v20100524.jar
b3107000-b310b000 r--s 00044000 08:01 421213     /opt/eclipse/plugins/org.eclipse.jdt.launching_3.5.100.v20100526.jar
b310b000-b3112000 r--s 00111000 08:01 350754     /usr/java/jre1.6.0_20/lib/resources.jar
b3112000-b311a000 r--s 00049000 08:01 421286     /opt/eclipse/plugins/org.eclipse.ui.cheatsheets_3.4.0.v20100427.jar
b311a000-b311f000 r--s 0002a000 08:01 420469     /opt/eclipse/plugins/org.eclipse.ui.browser_3.3.0.v20100517.jar
b311f000-b3124000 r--s 00038000 08:01 421281     /opt/eclipse/plugins/org.eclipse.text_3.5.0.v20100601-1300.jar
b3124000-b3128000 r--s 00023000 08:01 421018     /opt/eclipse/plugins/org.eclipse.pde.runtime_3.4.200.v20100601.jar
b3128000-b3132000 r--s 0006e000 08:01 420477     /opt/eclipse/plugins/org.eclipse.help.ui_3.5.0.v20100517.jar
b3132000-b3134000 r--s 0000c000 08:01 421360     /opt/eclipse/plugins/org.eclipse.jdt.compiler.tool_1.0.100.v_A58.jar
b3134000-b3137000 r--s 00013000 08:01 421152     /opt/eclipse/plugins/org.eclipse.core.expressions_3.4.200.v20100505.jar
b3137000-b313a000 ---p 00000000 00:00 0
b313a000-b3187000 rwxp 00000000 00:00 0
b3187000-b31b0000 r--s 00423000 08:01 421207     /opt/eclipse/plugins/org.eclipse.jdt.core_3.6.0.v_A58.jar
b31b0000-b31b9000 r-xp 00000000 08:03 144683     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/151/1/.cp/libswt-atk-gtk-3650.so
b31b9000-b31ba000 rw-p 00008000 08:03 144683     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/151/1/.cp/libswt-atk-gtk-3650.so
b31ba000-b31bd000 ---p 00000000 00:00 0
b31bd000-b320a000 rwxp 00000000 00:00 0
b320a000-b3213000 r--s 00056000 08:01 421277     /opt/eclipse/plugins/org.eclipse.team.core_3.5.100.I20100527-0800.jar
b3213000-b3234000 r--s 00607000 08:01 421449     /opt/eclipse/plugins/com.ibm.icu_4.2.1.v20100412.jar
b3234000-b323c000 r--s 0003b000 08:01 421122     /opt/eclipse/plugins/org.eclipse.core.databinding.observable_1.3.0.I20100601-0800.jar
b323c000-b3244000 r--s 0003a000 08:01 421358     /opt/eclipse/plugins/org.eclipse.jface.databinding_1.4.0.I20100601-0800.jar
b3244000-b3247000 r--s 00014000 08:01 420436     /opt/eclipse/plugins/org.eclipse.core.contenttype_3.4.100.v20100505-1235.jar
b3247000-b3249000 r-xp 00000000 08:03 145086     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/30/1/.cp/os/linux/x86/libunixfile_1_0_0.so
b3249000-b324a000 rw-p 00001000 08:03 145086     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/30/1/.cp/os/linux/x86/libunixfile_1_0_0.so
b324a000-b324c000 r--s 0000b000 08:01 421170     /opt/eclipse/plugins/org.eclipse.core.filesystem_1.3.0.v20100526-0737.jar
b324c000-b3257000 r--s 000b1000 08:01 420500     /opt/eclipse/plugins/org.eclipse.core.resources_3.6.0.v20100526-0737.jar
b3257000-b327d000 r--s 0020a000 08:01 421168     /opt/eclipse/plugins/org.eclipse.ui.ide_3.6.0.I20100601-0800.jar
b327d000-b3281000 r-xp 00000000 08:01 250177     /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
b3281000-b3282000 rw-p 00003000 08:01 250177     /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
b3282000-b3287000 r-xp 00000000 08:01 250162     /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
b3287000-b3288000 rw-p 00004000 08:01 250162     /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
b3288000-b3320000 r--p 00000000 08:01 310069     /usr/share/fonts/TTF/DejaVuSans.ttf
b3320000-b334b000 r--s 00000000 08:01 408335     /var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-le32d4.cache-3
b334b000-b334f000 r-xp 00000000 08:01 317453     /usr/lib/libXtst.so.6.1.0
b334f000-b3350000 rw-p 00003000 08:01 317453     /usr/lib/libXtst.so.6.1.0
b3350000-b3353000 r-xp 00000000 08:01 204        /usr/lib/libgthread-2.0.so.0.2200.5
b3353000-b3354000 rw-p 00003000 08:01 204        /usr/lib/libgthread-2.0.so.0.2200.5
b3354000-b3355000 r--s 00007000 08:01 421493     /opt/eclipse/plugins/org.eclipse.jdt.apt.pluggable.core_1.0.300.v20100513-0845.jar
b3355000-b3357000 r-xp 00000000 08:01 262494     /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
b3357000-b3358000 rw-p 00001000 08:01 262494     /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
b3358000-b3368000 r--s 00000000 08:01 408537     /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-le32d4.cache-3
b3368000-b3372000 r--s 00000000 08:01 408533     /var/cache/fontconfig/d62e99ef547d1d24cdb1bd22ec1a2976-le32d4.cache-3
b3372000-b3377000 r--s 00000000 08:01 406788     /var/cache/fontconfig/f349e9996a5320f6dd491cedd2b1f964-le32d4.cache-3
b3377000-b337b000 rwxp 00000000 00:00 0
b337b000-b33d4000 r-xp 00000000 08:03 144673     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/151/1/.cp/libswt-pi-gtk-3650.so
b33d4000-b33d6000 rw-p 00058000 08:03 144673     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/151/1/.cp/libswt-pi-gtk-3650.so
b33d6000-b33d7000 rw-p 00000000 00:00 0
b33d7000-b33eb000 r--s 00212000 08:01 420424     /opt/eclipse/plugins/org.eclipse.swt.gtk.linux.x86_3.6.0.v3650b.jar
b33eb000-b33ec000 r--s 00004000 08:01 421453     /opt/eclipse/plugins/org.eclipse.swt_3.6.0.v3650b.jar
b33ec000-b3400000 r--s 000f1000 08:01 421171     /opt/eclipse/plugins/org.eclipse.jface_3.6.0.I20100601-0800.jar
b3400000-b34fc000 rw-p 00000000 00:00 0
b34fc000-b3500000 ---p 00000000 00:00 0
b3500000-b3502000 r--s 00024000 08:01 421373     /opt/eclipse/plugins/org.eclipse.jdt.compiler.apt_1.0.300.v20100513-0845.jar
b3502000-b3503000 r--s 00002000 08:01 421180     /opt/eclipse/plugins/org.eclipse.core.filesystem.linux.x86_1.4.0.v20100505-1235.jar
b3503000-b3506000 r-xp 00000000 08:03 144672     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/151/1/.cp/libswt-gtk-3650.so
b3506000-b3507000 rw-p 00002000 08:03 144672     /home/dzmitry/.eclipse/org.eclipse.platform_3.5.0_1473617060/configuration/org.eclipse.osgi/bundles/151/1/.cp/libswt-gtk-3650.so
b3507000-b3508000 rw-p 00000000 00:00 0
b3508000-b350c000 r--s 00017000 08:01 421498     /opt/eclipse/plugins/org.eclipse.core.commands_3.6.0.I20100512-1500.jar
b350c000-b3511000 r--s 00021000 08:01 421290     /opt/eclipse/plugins/org.eclipse.ui_3.6.0.I20100603-1100.jar
b3511000-b3513000 r--s 00001000 08:01 420459     /opt/eclipse/plugins/org.eclipse.ui.workbench.compatibility_3.2.100.I20100511-0800/compatibility.jar
b3513000-b3559000 r--s 003ab000 08:01 421359     /opt/eclipse/plugins/org.eclipse.ui.workbench_3.6.0.I20100603-1100.jar
b3559000-b355b000 r--s 0000e000 08:01 421301     /opt/eclipse/plugins/org.eclipse.ui.ide.application_1.0.200.I20100601-0800.jar
b355b000-b355e000 r--s 0000e000 08:01 420437     /opt/eclipse/plugins/org.eclipse.equinox.p2.core_2.0.0.v20100510.jar
b355e000-b3560000 r--s 00006000 08:01 421478     /opt/eclipse/plugins/org.eclipse.equinox.p2.directorywatcher_1.0.200.v20100601.jar
b3560000-b3561000 r--s 0000a000 08:01 421505     /opt/eclipse/plugins/org.eclipse.equinox.p2.reconciler.dropins_1.1.0.v20100525.jar
b3561000-b3563000 r--s 00015000 08:01 421356     /opt/eclipse/plugins/org.eclipse.core.runtime.compatibility_3.2.100.v20100505.jar
b3563000-b3565000 r--s 00013000 08:01 421468     /opt/eclipse/plugins/org.eclipse.equinox.app_1.3.0.v20100512.jar
b3565000-b3568000 ---p 00000000 00:00 0
b3568000-b35b5000 rwxp 00000000 00:00 0
b35b5000-b35b8000 r--s 00014000 08:01 421477     /opt/eclipse/plugins/org.eclipse.core.jobs_3.5.0.v20100515.jar
b35b8000-b35bb000 r--s 00019000 08:01 421220     /opt/eclipse/plugins/org.eclipse.equinox.preferences_3.3.0.v20100503.jar
b35bb000-b35bc000 r--s 00005000 08:01 421216     /opt/eclipse/plugins/org.eclipse.core.runtime.compatibility.auth_3.2.200.v20100517.jar
b35bc000-b35c0000 r--s 00029000 08:01 421243     /opt/eclipse/plugins/org.eclipse.equinox.registry_3.5.0.v20100503.jar
b35c0000-b35c2000 r--s 00010000 08:01 421182     /opt/eclipse/plugins/org.eclipse.core.runtime_3.6.0.v20100505.jar
b35c2000-b35c5000 ---p 00000000 00:00 0
b35c5000-b3612000 rwxp 00000000 00:00 0
b3612000-b3615000 ---p 00000000 00:00 0
b3615000-b3662000 rwxp 00000000 00:00 0
b3662000-b3665000 ---p 00000000 00:00 0
b3665000-b36b2000 rwxp 00000000 00:00 0
b36b2000-b36b5000 ---p 00000000 00:00 0
b36b5000-b3702000 rwxp 00000000 00:00 0
b3702000-b3705000 ---p 00000000 00:00 0
b3705000-b3752000 rwxp 00000000 00:00 0
b3752000-b3765000 r-xp 00000000 08:01 350654     /usr/java/jre1.6.0_20/lib/i386/libnet.so
b3765000-b3766000 rw-p 00013000 08:01 350654     /usr/java/jre1.6.0_20/lib/i386/libnet.so
b3766000-b3799000 rw-p 00000000 00:00 0
b3799000-b3930000 r--s 02abf000 08:01 351267     /usr/java/jre1.6.0_20/lib/rt.jar
b3930000-b3931000 ---p 00000000 00:00 0
b3931000-b39b0000 rwxp 00000000 00:00 0
b39b0000-b39b3000 ---p 00000000 00:00 0
b39b3000-b3a00000 rwxp 00000000 00:00 0
b3a00000-b3b00000 rw-p 00000000 00:00 0
b3b00000-b3b02000 r--s 00006000 08:01 420445     /opt/eclipse/plugins/org.eclipse.equinox.event_1.2.0.v20100503.jar
b3b02000-b3b05000 r--s 0000e000 08:01 421210     /opt/eclipse/plugins/org.eclipse.osgi.services_3.2.100.v20100503.jar
b3b05000-b3b07000 r--s 00011000 08:01 421364     /opt/eclipse/plugins/org.eclipse.equinox.util_1.0.200.v20100503.jar
b3b07000-b3b0e000 r-xp 00000000 08:01 350655     /usr/java/jre1.6.0_20/lib/i386/libnio.so
b3b0e000-b3b0f000 rw-p 00006000 08:01 350655     /usr/java/jre1.6.0_20/lib/i386/libnio.so
b3b0f000-b3b20000 r--s 00108000 08:01 421294     /opt/eclipse/plugins/org.eclipse.osgi_3.6.0.v20100517.jar
b3b20000-b3b23000 ---p 00000000 00:00 0
b3b23000-b3ba0000 rwxp 00000000 00:00 0
b3ba0000-b3ba3000 ---p 00000000 00:00 0
b3ba3000-b3bf0000 rwxp 00000000 00:00 0
b3bf0000-b3bf3000 ---p 00000000 00:00 0
b3bf3000-b3c40000 rwxp 00000000 00:00 0
b3c40000-b3c43000 ---p 00000000 00:00 0
b3c43000-b3c90000 rwxp 00000000 00:00 0
b3c90000-b3c91000 ---p 00000000 00:00 0
b3c91000-b3d10000 rwxp 00000000 00:00 0
b3d10000-b3d2b000 rw-p 00000000 00:00 0
b3d2b000-b3d98000 rw-p 00000000 00:00 0
b3d98000-b3daa000 rw-p 00000000 00:00 0
b3daa000-b3e19000 rw-p 00000000 00:00 0
b3e19000-b3e22000 rw-p 00000000 00:00 0
b3e22000-b3e59000 rw-p 00000000 00:00 0
b3e59000-b3e6b000 rw-p 00000000 00:00 0
b3e6b000-b3ed9000 rw-p 00000000 00:00 0
b3ed9000-b3eed000 rw-p 00000000 00:00 0
b3eed000-b3f59000 rw-p 00000000 00:00 0
b3f59000-b3f75000 rw-p 00000000 00:00 0
b3f75000-b3fe5000 rw-p 00000000 00:00 0
b3fe5000-b43b5000 rwxp 00000000 00:00 0
b43b5000-b5fe5000 rw-p 00000000 00:00 0
b5fe5000-b5ff4000 r-xp 00000000 08:01 350662     /usr/java/jre1.6.0_20/lib/i386/libzip.so
b5ff4000-b5ff6000 rw-p 0000e000 08:01 350662     /usr/java/jre1.6.0_20/lib/i386/libzip.so
b5ff6000-b6019000 r-xp 00000000 08:01 350639     /usr/java/jre1.6.0_20/lib/i386/libjava.so
b6019000-b601b000 rw-p 00023000 08:01 350639     /usr/java/jre1.6.0_20/lib/i386/libjava.so
b601b000-b6022000 r-xp 00000000 08:01 14113      /lib/librt-2.11.1.so
b6022000-b6023000 r--p 00006000 08:01 14113      /lib/librt-2.11.1.so
b6023000-b6024000 rw-p 00007000 08:01 14113      /lib/librt-2.11.1.so
b6024000-b6026000 r--s 0002b000 08:01 420496     /opt/eclipse/plugins/org.eclipse.equinox.ds_1.2.0.v20100507.jar
b6026000-b6028000 r--s 00017000 08:01 421451     /opt/eclipse/plugins/org.eclipse.equinox.common_3.6.0.v20100503.jar
b6028000-b602a000 r--s 00008000 08:01 421302     /opt/eclipse/plugins/org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar
b602a000-b6030000 rw-p 00000000 00:00 0
b6030000-b6038000 rw-s 00000000 08:01 408573     /tmp/hsperfdata_dzmitry/2048
b6038000-b603e000 r-xp 00000000 08:01 350666     /usr/java/jre1.6.0_20/lib/i386/native_threads/libhpi.so
b603e000-b603f000 rw-p 00006000 08:01 350666     /usr/java/jre1.6.0_20/lib/i386/native_threads/libhpi.so
b603f000-b604a000 r-xp 00000000 08:01 350661     /usr/java/jre1.6.0_20/lib/i386/libverify.so
b604a000-b604b000 rw-p 0000b000 08:01 350661     /usr/java/jre1.6.0_20/lib/i386/libverify.so
b604b000-b64ce000 r-xp 00000000 08:01 350619     /usr/java/jre1.6.0_20/lib/i386/client/libjvm.so
b64ce000-b64ef000 rw-p 00483000 08:01 350619     /usr/java/jre1.6.0_20/lib/i386/client/libjvm.so
b64ef000-b690b000 rw-p 00000000 00:00 0
b690b000-b696b000 rw-s 00000000 00:04 327690     /SYSV00000000 (deleted)
b696b000-b69ce000 rw-p 00000000 00:00 0
b69ce000-b69e9000 r--s 00000000 08:01 344759     /usr/share/mime/mime.cache
b69e9000-b6a14000 r--p 00000000 08:01 240701     /usr/share/locale/ru/LC_MESSAGES/libc.mo
b6a14000-b6a49000 r--p 00000000 08:01 250208     /usr/share/locale/ru/LC_MESSAGES/gtk20-properties.mo
b6a49000-b6a54000 r-xp 00000000 08:01 14106      /lib/libnss_files-2.11.1.so
b6a54000-b6a55000 r--p 0000a000 08:01 14106      /lib/libnss_files-2.11.1.so
b6a55000-b6a56000 rw-p 0000b000 08:01 14106      /lib/libnss_files-2.11.1.so
b6a56000-b6a5f000 r-xp 00000000 08:01 14108      /lib/libnss_nis-2.11.1.so
b6a5f000-b6a60000 r--p 00008000 08:01 14108      /lib/libnss_nis-2.11.1.so
b6a60000-b6a61000 rw-p 00009000 08:01 14108      /lib/libnss_nis-2.11.1.so
b6a61000-b6a76000 r-xp 00000000 08:01 14103      /lib/libnsl-2.11.1.so
b6a76000-b6a77000 r--p 00014000 08:01 14103      /lib/libnsl-2.11.1.so
b6a77000-b6a78000 rw-p 00015000 08:01 14103      /lib/libnsl-2.11.1.so
b6a78000-b6a7a000 rw-p 00000000 00:00 0
b6a7a000-b6a7c000 r--s 0000a000 08:01 421154     /opt/eclipse/plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
b6a7c000-b6a97000 r--s 00000000 08:01 344759     /usr/share/mime/mime.cache
b6a97000-b6aa0000 r-xp 00000000 08:01 333089     /usr/lib/gtk-2.0/2.10.0/engines/libxfce.so
b6aa0000-b6aa1000 rw-p 00008000 08:01 333089     /usr/lib/gtk-2.0/2.10.0/engines/libxfce.so
b6aa1000-b6ab9000 r-xp 00000000 08:01 228131     /usr/lib/libatk-1.0.so.0.3009.1
b6ab9000-b6abb000 rw-p 00018000 08:01 228131     /usr/lib/libatk-1.0.so.0.3009.1
b6abb000-b6e62000 r-xp 00000000 08:01 250205     /usr/lib/libgtk-x11-2.0.so.0.1800.9
b6e62000-b6e68000 rw-p 003a7000 08:01 250205     /usr/lib/libgtk-x11-2.0.so.0.1800.9
b6e68000-b6e69000 rw-p 00000000 00:00 0
b6e69000-b6e85000 r-xp 00000000 08:01 189        /usr/lib/libgcc_s.so.1
b6e85000-b6e86000 rw-p 0001b000 08:01 189        /usr/lib/libgcc_s.so.1
b6e86000-b6f6a000 r-xp 00000000 08:01 2624       /usr/lib/libstdc++.so.6.0.13
b6f6a000-b6f6e000 r--p 000e3000 08:01 2624       /usr/lib/libstdc++.so.6.0.13
b6f6e000-b6f6f000 rw-p 000e7000 08:01 2624       /usr/lib/libstdc++.so.6.0.13
b6f6f000-b6f76000 rw-p 00000000 00:00 0
b6f76000-b6f9b000 r-xp 00000000 08:01 262507     /usr/lib/libpangoft2-1.0.so.0.2600.2
b6f9b000-b6f9c000 rw-p 00025000 08:01 262507     /usr/lib/libpangoft2-1.0.so.0.2600.2
b6f9c000-b6fc0000 r-xp 00000000 08:01 14101      /lib/libm-2.11.1.so
b6fc0000-b6fc1000 r--p 00023000 08:01 14101      /lib/libm-2.11.1.so
b6fc1000-b6fc2000 rw-p 00024000 08:01 14101      /lib/libm-2.11.1.so
b6fc2000-b6fc4000 r-xp 00000000 08:01 225        /usr/lib/libgmodule-2.0.so.0.2200.5
b6fc4000-b6fc5000 rw-p 00002000 08:01 225        /usr/lib/libgmodule-2.0.so.0.2200.5
b6fc5000-b6fd8000 r-xp 00000000 08:01 14112      /lib/libresolv-2.11.1.so
b6fd8000-b6fd9000 r--p 00012000 08:01 14112      /lib/libresolv-2.11.1.so
b6fd9000-b6fda000 rw-p 00013000 08:01 14112      /lib/libresolv-2.11.1.so
b6fda000-b6fdc000 rw-p 00000000 00:00 0
b6fdc000-b706a000 r-xp 00000000 08:01 238169     /usr/lib/libgio-2.0.so.0.2200.5
b706a000-b706c000 rw-p 0008e000 08:01 238169     /usr/lib/libgio-2.0.so.0.2200.5
b706c000-b7083000 r-xp 00000000 08:01 250192     /usr/lib/libgdk_pixbuf-2.0.so.0.1800.9
b7083000-b7084000 rw-p 00016000 08:01 250192     /usr/lib/libgdk_pixbuf-2.0.so.0.1800.9
b7084000-b709b000 r-xp 00000000 08:01 317838     /usr/lib/libxcb.so.1.1.0
b709b000-b709c000 rw-p 00016000 08:01 317838     /usr/lib/libxcb.so.1.1.0
b709c000-b71b3000 r-xp 00000000 08:01 316142     /usr/lib/libX11.so.6.3.0
b71b3000-b71b7000 rw-p 00116000 08:01 316142     /usr/lib/libX11.so.6.3.0
b71b7000-b71ca000 r-xp 00000000 08:01 221        /usr/lib/libz.so.1.2.3
b71ca000-b71cb000 rw-p 00012000 08:01 221        /usr/lib/libz.so.1.2.3
b71cb000-b71d3000 r-xp 00000000 08:01 317095     /usr/lib/libXrender.so.1.3.0
b71d3000-b71d4000 rw-p 00007000 08:01 317095     /usr/lib/libXrender.so.1.3.0
b71d4000-b71f9000 r-xp 00000000 08:01 207        /usr/lib/libpng14.so.14.2.0
b71f9000-b71fa000 rw-p 00024000 08:01 207        /usr/lib/libpng14.so.14.2.0
b71fa000-b7218000 r-xp 00000000 08:01 196        /usr/lib/libexpat.so.1.5.2
b7218000-b721a000 rw-p 0001d000 08:01 196        /usr/lib/libexpat.so.1.5.2
b721a000-b728c000 r-xp 00000000 08:01 192        /usr/lib/libfreetype.so.6.4.0
b728c000-b7290000 rw-p 00071000 08:01 192        /usr/lib/libfreetype.so.6.4.0
b7290000-b72bc000 r-xp 00000000 08:01 315080     /usr/lib/libfontconfig.so.1.4.4
b72bc000-b72be000 rw-p 0002b000 08:01 315080     /usr/lib/libfontconfig.so.1.4.4
b72be000-b730b000 r-xp 00000000 08:01 319037     /usr/lib/libpixman-1.so.0.16.6
b730b000-b730d000 rw-p 0004c000 08:01 319037     /usr/lib/libpixman-1.so.0.16.6
b730d000-b7379000 r-xp 00000000 08:01 236172     /usr/lib/libcairo.so.2.10800.8
b7379000-b737b000 rw-p 0006c000 08:01 236172     /usr/lib/libcairo.so.2.10800.8
b737b000-b737f000 r-xp 00000000 08:01 316773     /usr/lib/libXfixes.so.3.1.0
b737f000-b7380000 rw-p 00003000 08:01 316773     /usr/lib/libXfixes.so.3.1.0
b7380000-b7382000 r-xp 00000000 08:01 316635     /usr/lib/libXdamage.so.1.1.0
b7382000-b7383000 rw-p 00001000 08:01 316635     /usr/lib/libXdamage.so.1.1.0
b7383000-b7390000 r-xp 00000000 08:01 316757     /usr/lib/libXext.so.6.4.0
b7390000-b7391000 rw-p 0000d000 08:01 316757     /usr/lib/libXext.so.6.4.0
b7391000-b7393000 r-xp 00000000 08:01 316574     /usr/lib/libXcomposite.so.1.0.0
b7393000-b7394000 rw-p 00001000 08:01 316574     /usr/lib/libXcomposite.so.1.0.0
b7394000-b739c000 r-xp 00000000 08:01 316621     /usr/lib/libXcursor.so.1.0.2
b739c000-b739d000 rw-p 00007000 08:01 316621     /usr/lib/libXcursor.so.1.0.2
b739d000-b73a1000 r-xp 00000000 08:01 316649     /usr/lib/libXdmcp.so.6.0.0
b73a1000-b73a2000 rw-p 00003000 08:01 316649     /usr/lib/libXdmcp.so.6.0.0
b73a2000-b73a4000 r-xp 00000000 08:01 316448     /usr/lib/libXau.so.6.0.0
b73a4000-b73a5000 rw-p 00001000 08:01 316448     /usr/lib/libXau.so.6.0.0
b73a5000-b73ab000 r-xp 00000000 08:01 317078     /usr/lib/libXrandr.so.2.2.0
b73ab000-b73ac000 rw-p 00005000 08:01 317078     /usr/lib/libXrandr.so.2.2.0
b73ac000-b73b8000 r-xp 00000000 08:01 316918     /usr/lib/libXi.so.6.1.0
b73b8000-b73b9000 rw-p 0000b000 08:01 316918     /usr/lib/libXi.so.6.1.0
b73b9000-b73f8000 r-xp 00000000 08:01 262475     /usr/lib/libpango-1.0.so.0.2600.2
b73f8000-b73fa000 rw-p 0003f000 08:01 262475     /usr/lib/libpango-1.0.so.0.2600.2
b73fa000-b748a000 r-xp 00000000 08:01 250207     /usr/lib/libgdk-x11-2.0.so.0.1800.9
b748a000-b748d000 rw-p 00090000 08:01 250207     /usr/lib/libgdk-x11-2.0.so.0.1800.9
b748d000-b755c000 r-xp 00000000 08:01 199        /usr/lib/libglib-2.0.so.0.2200.5
b755c000-b755d000 rw-p 000cf000 08:01 199        /usr/lib/libglib-2.0.so.0.2200.5
b755d000-b7596000 r-xp 00000000 08:01 191        /usr/lib/libgobject-2.0.so.0.2200.5
b7596000-b7597000 rw-p 00039000 08:01 191        /usr/lib/libgobject-2.0.so.0.2200.5
b7597000-b7598000 r--s 00002000 08:01 421326     /opt/eclipse/plugins/org.eclipse.core.runtime.compatibility.registry_3.3.0.v20100520/runtime_registry_compatibility.jar
b7598000-b7599000 rw-p 00000000 00:00 0
b7599000-b759c000 r-xp 00000000 08:01 250174     /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
b759c000-b759d000 rw-p 00002000 08:01 250174     /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
b759d000-b75a4000 r-xp 00000000 08:01 14104      /lib/libnss_compat-2.11.1.so
b75a4000-b75a5000 r--p 00006000 08:01 14104      /lib/libnss_compat-2.11.1.so
b75a5000-b75a6000 rw-p 00007000 08:01 14104      /lib/libnss_compat-2.11.1.so
b75a6000-b75be000 r--p 00000000 08:01 250209     /usr/share/locale/ru/LC_MESSAGES/gtk20.mo
b75be000-b75fd000 r--p 00000000 08:01 242765     /usr/lib/locale/ru_RU.utf8/LC_CTYPE
b75fd000-b75ff000 rw-p 00000000 00:00 0
b75ff000-b775b000 r-xp 00000000 08:01 14097      /lib/libc-2.11.1.so
b775b000-b775c000 ---p 0015c000 08:01 14097      /lib/libc-2.11.1.so
b775c000-b775e000 r--p 0015c000 08:01 14097      /lib/libc-2.11.1.so
b775e000-b775f000 rw-p 0015e000 08:01 14097      /lib/libc-2.11.1.so
b775f000-b7762000 rw-p 00000000 00:00 0
b7762000-b7764000 r-xp 00000000 08:01 14100      /lib/libdl-2.11.1.so
b7764000-b7765000 r--p 00001000 08:01 14100      /lib/libdl-2.11.1.so
b7765000-b7766000 rw-p 00002000 08:01 14100      /lib/libdl-2.11.1.so
b7766000-b777b000 r-xp 00000000 08:01 14111      /lib/libpthread-2.11.1.so
b777b000-b777c000 r--p 00014000 08:01 14111      /lib/libpthread-2.11.1.so
b777c000-b777d000 rw-p 00015000 08:01 14111      /lib/libpthread-2.11.1.so
b777d000-b777f000 rw-p 00000000 00:00 0
b777f000-b7780000 r--s 00000000 08:03 139829     /home/dzmitry/.local/share/mime/mime.cache
b7780000-b7781000 r--p 00000000 00:00 0
b7781000-b7783000 r-xp 00000000 08:01 316937     /usr/lib/libXinerama.so.1.0.0
b7783000-b7784000 rw-p 00001000 08:01 316937     /usr/lib/libXinerama.so.1.0.0
b7784000-b778e000 r-xp 00000000 08:01 262516     /usr/lib/libpangocairo-1.0.so.0.2600.2
b778e000-b778f000 rw-p 00009000 08:01 262516     /usr/lib/libpangocairo-1.0.so.0.2600.2
b778f000-b779b000 r-xp 00000000 08:01 421191     /opt/eclipse/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.0.v20100503/eclipse_1307.so
b779b000-b779c000 rw-p 0000c000 08:01 421191     /opt/eclipse/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.0.v20100503/eclipse_1307.so
b779c000-b779d000 r--p 00000000 08:01 242849     /usr/lib/locale/ru_RU.utf8/LC_NUMERIC
b779d000-b779e000 r--p 00000000 08:01 239754     /usr/lib/locale/ru_RU.utf8/LC_TIME
b779e000-b779f000 r--p 00000000 08:01 239753     /usr/lib/locale/ru_RU.utf8/LC_MONETARY
b779f000-b77a0000 r--p 00000000 08:01 239165     /usr/lib/locale/ru_RU.utf8/LC_MESSAGES/SYS_LC_MESSAGES
b77a0000-b77a1000 r--p 00000000 08:01 242762     /usr/lib/locale/ru_RU.utf8/LC_PAPER
b77a1000-b77a2000 r--p 00000000 08:01 242764     /usr/lib/locale/ru_RU.utf8/LC_NAME
b77a2000-b77a3000 r--p 00000000 08:01 239160     /usr/lib/locale/ru_RU.utf8/LC_ADDRESS
b77a3000-b77a4000 r--p 00000000 08:01 243008     /usr/lib/locale/ru_RU.utf8/LC_TELEPHONE
b77a4000-b77a5000 r--p 00000000 08:01 242766     /usr/lib/locale/ru_RU.utf8/LC_MEASUREMENT
b77a5000-b77a6000 r--p 00000000 08:01 239752     /usr/lib/locale/ru_RU.utf8/LC_IDENTIFICATION
b77a6000-b77a7000 rw-p 00000000 00:00 0
b77a7000-b77c4000 r-xp 00000000 08:01 14139      /lib/ld-2.11.1.so
b77c4000-b77c5000 r--p 0001d000 08:01 14139      /lib/ld-2.11.1.so
b77c5000-b77c6000 rw-p 0001e000 08:01 14139      /lib/ld-2.11.1.so
bf91c000-bf91f000 ---p 00000000 00:00 0
bf91f000-bf96c000 rwxp 00000000 00:00 0          [stack]
bf96c000-bf96e000 rw-p 00000000 00:00 0
ffffe000-fffff000 r-xp 00000000 00:00 0          [vdso]
VM Arguments:
jvm_args: -Xms40m -Xmx384m -XX:MaxPermSize=256m
java_command: <unknown>
Launcher Type: generic
Environment Variables:
JAVA_HOME=/usr/lib/java
PATH=/usr/local/bin:/usr/bin:/bin:/usr/games:/usr/lib/java/bin:/usr/lib/kde4/libexec:/usr/lib/qt/bin:/usr/share/texmf/bin:.
LD_LIBRARY_PATH=/usr/java/jre1.6.0_20/lib/i386/client:/usr/java/jre1.6.0_20/lib/i386:/usr/lib/seamonkey-2.0.4:/usr/lib/seamonkey-2.0.4
SHELL=/bin/bash
DISPLAY=:0.0
Signal Handlers:
SIGSEGV: [libjvm.so+0x418670], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x418670], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x33e070], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGXFSZ: [libjvm.so+0x33e070], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x33e070], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x340cb0], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x3409e0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: [libjvm.so+0x3409e0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x3409e0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x3409e0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
---------------  S Y S T E M  ---------------
OS:Linux
uname:Linux 2.6.33.4-smp #2 SMP Wed May 12 22:47:36 CDT 2010 i686
libc:glibc 2.11.1 NPTL 2.11.1
rlimit: STACK 8192k, CORE 0k, NPROC 7940, NOFILE 1024, AS infinity
load average:0,80 0,45 0,18
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 6, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 1017028k(435336k free), swap 2104504k(2104504k free)
vm_info: Java HotSpot(TM) Client VM (16.3-b01) for linux-x86 JRE (1.6.0_20-b02), built on Apr 12 2010 14:15:08 by "java_re" with gcc 3.2.1-7a (J2SE release)
time: Sun Jan  9 19:23:58 2011
elapsed time: 31 seconds
Re: Eclipse crashes [message #649370 is a reply to message #648747] Tue, 18 January 2011 18:13 Go to previous messageGo to next message
I have the same problem.Can anyone help us please?
Re: Eclipse crashes [message #649385 is a reply to message #648747] Tue, 18 January 2011 21:50 Go to previous messageGo to next message
On 1/14/2011 5:27 PM, Dzmitry Kashlach wrote:
> Hello to everyone!
> log.
> Dzmitry.
Please file a bug against JDT/Core with steps to reproduce the problem.
Re: Eclipse crashes [message #649393 is a reply to message #649385] Wed, 19 January 2011 00:27 Go to previous messageGo to next message
>> Hello to everyone!
>> log.
>> Thanks,
>> Dzmitry.
Sorry, file a bug with Platform/SWT.
Re: Eclipse crashes [message #649397 is a reply to message #649385] Wed, 19 January 2011 00:27 Go to previous messageGo to next message
>> Hello to everyone!
>> log.
>> Thanks,
>> Dzmitry.
Re: Eclipse crashes [message #649399 is a reply to message #648747] Wed, 19 January 2011 01:42 Go to previous messageGo to next message
Please post with the steps to reproduce the error
Re: Eclipse crashes [message #668070 is a reply to message #649399] Tue, 03 May 2011 11:33 Go to previous messageGo to next message
Mine crashes as well.
Even though the previous reporters were quite explicit, I will have my own attempt to document as to how the problem occurs.
1. Create a new project and the class Test with the contents below:
package test;
public class Test {
public void test()
new
2. Get your cursor after new and then type the magic sequence: CTRL+SPACE.
What I got was a crash file with the following contents:
# SIGSEGV (0xb) at pc=0xb2687517, pid=4053, tid=3076986560
# JRE version: 6.0_25-b06
# Java VM: Java HotSpot(TM) Client VM (20.0-b11 mixed mode, sharing linux-x86 )
# C [libxpcom_core.so+0x52517] NS_IsNativeUTF8()+0x1a7
Current thread (0x080c9000): JavaThread "main" [_thread_in_native, id=4053, stack(0xbff19000,0xbff69000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0xbff6a000
Registers:
EAX=0xb2720000, EBX=0xb26cfb9c, ECX=0xbff6a000, EDX=0xbff67390
ESP=0xbff66300, EBP=0xbff66348, ESI=0xbff67394, EDI=0xbff67398
EIP=0xb2687517, EFLAGS=0x00010282, CR2=0xbff6a000
Top of Stack: (sp=0xbff66300)
0xbff66300: bff6738c bff67390 bff6738c 086efaa0
0xbff66310: 00000000 00000001 00000000 00000000
0xbff66320: 00000000 00000000 000003e4 10c67642
0xbff66330: b2639b20 b26cfb9c bff6638c b26cfb9c
0xbff66340: bff6638c bff6739f bff673b8 b2687833
0xbff66350: bff6739f bff67398 bff67394 bff67390
0xbff66360: bff6738c 00001000 bff673b8 b26877a5
0xbff66370: b2727288 bff67394 bff67390 bff6738c
Instructions: (pc=0xb2687517)
0xb26874f7: 20 8b 55 bc 8b 4d b8 8b 06 85 c0 74 8d 8b 01 85
0xb2687507: c0 74 87 89 4d c0 8d 76 00 8b 07 66 8b 00 8b 0a
0xb2687517: 88 01 83 07 02 ff 0e ff 02 8b 4d c0 8b 01 48 89
0xb2687527: 01 8b 0e 85 c9 0f 84 5f ff ff ff 85 c0 75 da 31
Register to memory mapping:
EAX=0xb2720000: <offset 0x11000> in /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-mozilla-gtk-3659.so at 0xb270f000
EBX=0xb26cfb9c: <offset 0x9ab9c> in /usr/lib/seamonkey/libxpcom_core.so at 0xb2635000
ECX=0xbff6a000 is an unknown value
EDX=0xbff67390 is pointing into the stack for thread: 0x080c9000
ESP=0xbff66300 is pointing into the stack for thread: 0x080c9000
EBP=0xbff66348 is pointing into the stack for thread: 0x080c9000
ESI=0xbff67394 is pointing into the stack for thread: 0x080c9000
EDI=0xbff67398 is pointing into the stack for thread: 0x080c9000
Stack: [0xbff19000,0xbff69000], sp=0xbff66300, free space=308k
C [libxpcom_core.so+0x52833] NS_CopyUnicodeToNative(nsAString_internal const&, nsACString_internal&)+0xb3
[error occurred during error reporting (printing Java stack), id 0xb]
0x08808400 JavaThread "Additional info timer" [_thread_blocked, id=4128, stack(0xb2f04000,0xb2f54000)]
0x08666c00 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=4126, stack(0xb2f8f000,0xb2fdf000)]
0x083f1400 JavaThread "org.eclipse.jdt.internal.ui.text.JavaReconciler" daemon [_thread_blocked, id=4120, stack(0xb3247000,0xb3297000)]
0xb311dc00 JavaThread "Worker-2" [_thread_blocked, id=4080, stack(0xb2fe6000,0xb3036000)]
0x0846e800 JavaThread "Java indexing" daemon [_thread_blocked, id=4079, stack(0xb3042000,0xb3092000)]
0x08414400 JavaThread "Worker-1" [_thread_blocked, id=4078, stack(0xb30b0000,0xb3100000)]
0xb384fc00 JavaThread "Worker-0" [_thread_blocked, id=4076, stack(0xb32d2000,0xb3322000)]
0xb3885000 JavaThread "Worker-JM" [_thread_blocked, id=4075, stack(0xb368f000,0xb36df000)]
0xb3843400 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=4074, stack(0xb363f000,0xb368f000)]
0x08192000 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=4072, stack(0xb36ea000,0xb373a000)]
0xb383bc00 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=4071, stack(0xb373a000,0xb378a000)]
0xb383e400 JavaThread "State Data Manager" daemon [_thread_blocked, id=4070, stack(0xb378a000,0xb37da000)]
0xb3800800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=4068, stack(0xb398a000,0xb39da000)]
0x08101000 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=4067, stack(0xb39da000,0xb3a5a000)]
0x080ff800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4066, stack(0xb3a5a000,0xb3aaa000)]
0x080fb800 JavaThread "Finalizer" daemon [_thread_blocked, id=4065, stack(0xb3aaa000,0xb3afa000)]
0x080f6c00 JavaThread "Reference Handler" daemon [_thread_blocked, id=4064, stack(0xb3afa000,0xb3b4a000)]
=>0x080c9000 JavaThread "main" [_thread_in_native, id=4053, stack(0xbff19000,0xbff69000)]
Other Threads:
0x080ec800 VMThread [stack: 0xb3d16000,0xb3d96000] [id=4063]
0xb3802c00 WatcherThread [stack: 0xb390a000,0xb398a000] [id=4069]
Heap
def new generation total 13248K, used 8273K [0x6ae50000, 0x6bcb0000, 0x72e50000)
eden space 11776K, 63% used [0x6ae50000, 0x6b5a2f60, 0x6b9d0000)
from space 1472K, 52% used [0x6bb40000, 0x6bc01628, 0x6bcb0000)
to space 1472K, 0% used [0x6b9d0000, 0x6b9d0000, 0x6bb40000)
tenured generation total 29316K, used 17587K [0x72e50000, 0x74af1000, 0x82e50000)
the space 29316K, 59% used [0x72e50000, 0x73f7cfe8, 0x73f7d000, 0x74af1000)
compacting perm gen total 40192K, used 40136K [0x82e50000, 0x85590000, 0x92e50000)
the space 40192K, 99% used [0x82e50000, 0x855822b0, 0x85582400, 0x85590000)
ro space 10240K, 61% used [0x92e50000, 0x934799f0, 0x93479a00, 0x93850000)
rw space 12288K, 60% used [0x93850000, 0x93f8c800, 0x93f8c800, 0x94450000)
Code Cache [0xb4071000, 0xb43e9000, 0xb6071000)
total_blobs=1470 nmethods=1247 adapters=158 free_code_cache=29942016 largest_free_block=256
Dynamic libraries:
08048000-0804c000 r-xp 00000000 08:15 1068014 /opt/eclipse362/eclipse
0804c000-0804d000 rw-p 00003000 08:15 1068014 /opt/eclipse362/eclipse
0804d000-08948000 rw-p 00000000 00:00 0 [heap]
6ae50000-6bcb0000 rw-p 00000000 00:00 0
6bcb0000-72e50000 rw-p 00000000 00:00 0
72e50000-74af1000 rw-p 00000000 00:00 0
74af1000-82e50000 rw-p 00000000 00:00 0
82e50000-85590000 rw-p 00000000 00:00 0
85590000-92e50000 rw-p 00000000 00:00 0
92e50000-9347a000 r--s 00001000 08:15 2104385 /opt/jdk1.6.0_25/jre/lib/i386/client/classes.jsa
9347a000-93850000 rw-p 00000000 00:00 0
93850000-93f8d000 rw-p 0062b000 08:15 2104385 /opt/jdk1.6.0_25/jre/lib/i386/client/classes.jsa
93f8d000-94450000 rw-p 00000000 00:00 0
94450000-94532000 rw-p 00d68000 08:15 2104385 /opt/jdk1.6.0_25/jre/lib/i386/client/classes.jsa
94532000-94850000 rw-p 00000000 00:00 0
94850000-94858000 r-xs 00e4a000 08:15 2104385 /opt/jdk1.6.0_25/jre/lib/i386/client/classes.jsa
94858000-94c50000 rw-p 00000000 00:00 0
b2549000-b260a000 r-xp 00000000 08:15 262254 /usr/lib/libasound.so.2.0.0
b260a000-b260e000 rw-p 000c1000 08:15 262254 /usr/lib/libasound.so.2.0.0
b2631000-b2633000 r-xp 00000000 08:15 265389 /usr/lib/gconv/UTF-16.so
b2633000-b2634000 r--p 00001000 08:15 265389 /usr/lib/gconv/UTF-16.so
b2634000-b2635000 rw-p 00002000 08:15 265389 /usr/lib/gconv/UTF-16.so
b2635000-b26c8000 r-xp 00000000 08:15 959733 /usr/lib/seamonkey-2.0.4/libxpcom_core.so
b26c8000-b26d1000 rw-p 00092000 08:15 959733 /usr/lib/seamonkey-2.0.4/libxpcom_core.so
b26d1000-b26d4000 r-xp 00000000 08:15 930403 /usr/lib/seamonkey-2.0.4/libplc4.so
b26d4000-b26d5000 rw-p 00002000 08:15 930403 /usr/lib/seamonkey-2.0.4/libplc4.so
b26d5000-b26d7000 r-xp 00000000 08:15 930409 /usr/lib/seamonkey-2.0.4/libplds4.so
b26d7000-b26d8000 rw-p 00001000 08:15 930409 /usr/lib/seamonkey-2.0.4/libplds4.so
b26d8000-b2708000 r-xp 00000000 08:15 930406 /usr/lib/seamonkey-2.0.4/libnspr4.so
b2708000-b2709000 rw-p 00030000 08:15 930406 /usr/lib/seamonkey-2.0.4/libnspr4.so
b2709000-b270b000 rw-p 00000000 00:00 0
b270b000-b270e000 r-xp 00000000 08:15 959711 /usr/lib/seamonkey-2.0.4/libxpcom.so
b270e000-b270f000 rw-p 00002000 08:15 959711 /usr/lib/seamonkey-2.0.4/libxpcom.so
b270f000-b2727000 r-xp 00000000 08:15 1068481 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-mozilla-gtk-3659.so
b2727000-b2728000 rw-p 00018000 08:15 1068481 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-mozilla-gtk-3659.so
b2728000-b272d000 r-xp 00000000 08:15 1068480 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-xpcominit-gtk-3659.so
b272d000-b272f000 rw-p 00005000 08:15 1068480 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-xpcominit-gtk-3659.so
b272f000-b273e000 r--s 000da000 08:15 1067731 /opt/eclipse362/plugins/org.eclipse.ant.ui_3.5.0.v20100427.j ar
b273e000-b2747000 r--s 000aa000 08:15 1066926 /opt/eclipse362/plugins/org.eclipse.pde.api.tools_1.0.202.v2 0100820_r361.jar
b2747000-b277e000 r--p 00000000 08:15 827223 /usr/share/fonts/TTF/DejaVuSansMono-BoldOblique.ttf
b277e000-b27b6000 r--p 00000000 08:15 827234 /usr/share/fonts/TTF/DejaVuSansMono-Oblique.ttf
b27b6000-b2800000 r--p 00000000 08:15 827230 /usr/share/fonts/TTF/DejaVuSansMono-Bold.ttf
b2800000-b28d1000 rw-p 00000000 00:00 0
b28d1000-b2900000 ---p 00000000 00:00 0
b2900000-b2909000 r--s 0005b000 08:15 1067053 /opt/eclipse362/plugins/org.eclipse.jdt.junit_3.6.1.r361_v20 100825-0800.jar
b2909000-b290b000 r--s 00007000 08:15 1067857 /opt/eclipse362/plugins/org.eclipse.core.variables_3.2.400.v 20100505.jar
b290b000-b2915000 r--s 00066000 08:15 1067800 /opt/eclipse362/plugins/org.eclipse.ltk.ui.refactoring_3.5.0 .v20100526-0800.jar
b2915000-b2964000 r--p 00000000 08:15 827231 /usr/share/fonts/TTF/DejaVuSansMono.ttf
b2964000-b29e4000 r--p 00000000 08:15 827222 /usr/share/fonts/TTF/DejaVuSans-BoldOblique.ttf
b29e4000-b2a64000 r--p 00000000 08:15 827217 /usr/share/fonts/TTF/DejaVuSans-Oblique.ttf
b2a64000-b2af0000 r--p 00000000 08:15 827232 /usr/share/fonts/TTF/DejaVuSans-Bold.ttf
b2af0000-b2af9000 r--s 0005a000 08:15 1067136 /opt/eclipse362/plugins/org.eclipse.pde.api.tools.ui_1.0.201 .v20100820_r361.jar
b2af9000-b2b00000 r--s 00048000 08:15 1067059 /opt/eclipse362/plugins/org.eclipse.ltk.core.refactoring_3.5 .101.r362_v20101117-0800.jar
b2b00000-b2bfa000 rw-p 00000000 00:00 0
b2bfa000-b2c00000 ---p 00000000 00:00 0
b2c00000-b2c02000 r--s 0000e000 08:15 1067175 /opt/eclipse362/plugins/org.eclipse.compare.core_3.5.101.R36 x_v20100929-0800.jar
b2c02000-b2c1c000 r--s 0012c000 08:15 1067754 /opt/eclipse362/plugins/org.eclipse.jdt.debug.ui_3.5.2.v2010 0928a_r362.jar
b2c1c000-b2c1e000 r--s 00017000 08:15 1067832 /opt/eclipse362/plugins/org.eclipse.update.configurator_3.3. 100.v20100512.jar
b2c1e000-b2c28000 r--s 00089000 08:15 1067842 /opt/eclipse362/plugins/org.eclipse.update.core_3.2.402.R36x _v20100629.jar
b2c28000-b2c29000 r--s 00007000 08:15 1067203 /opt/eclipse362/plugins/org.eclipse.update.scheduler_3.2.300 .v20100512.jar
b2c29000-b2c2b000 r--s 00003000 08:15 1068004 /opt/eclipse362/plugins/org.eclipse.equinox.p2.updatechecker _1.1.101.R36x_v20100823.jar
b2c2b000-b2c2e000 r--s 00018000 08:15 1067804 /opt/eclipse362/plugins/org.eclipse.equinox.p2.metadata.repo sitory_1.1.0.v20100513.jar
b2c2e000-b2c32000 r--s 00021000 08:15 1067797 /opt/eclipse362/plugins/org.eclipse.equinox.p2.repository_2. 0.2.R36x_v20110111-1500.jar
b2c32000-b2c3a000 r--s 00049000 08:15 1067151 /opt/eclipse362/plugins/org.eclipse.equinox.p2.metadata_2.0. 1.R36x_v20101202.jar
b2c3a000-b2c3e000 r--s 00028000 08:15 1067036 /opt/eclipse362/plugins/org.eclipse.equinox.p2.engine_2.0.1. R36x_v20110201.jar
b2c3e000-b2c40000 r--s 0000b000 08:15 1067207 /opt/eclipse362/plugins/org.eclipse.equinox.p2.operations_2. 0.0.v20100510.jar
b2c40000-b2c43000 r--s 0000c000 08:15 1067211 /opt/eclipse362/plugins/org.eclipse.equinox.p2.ui.sdk.schedu ler_1.0.0.v20100507-1815.jar
b2c43000-b2c45000 r--s 0000a000 08:15 1067789 /opt/eclipse362/plugins/org.eclipse.ui.net_1.2.100.I20100505 -1245.jar
b2c45000-b2c48000 r--s 00013000 08:15 2099156 /opt/jdk1.6.0_25/jre/lib/jce.jar
b2c48000-b2c49000 r--s 00008000 08:15 1067165 /opt/eclipse362/plugins/org.eclipse.core.net.linux.x86_1.1.1 00.R36x_v20100825-0800.jar
b2c49000-b2c4c000 r--s 00017000 08:15 1067977 /opt/eclipse362/plugins/org.eclipse.equinox.security_1.0.200 .v20100503.jar
b2c4c000-b2c4f000 r--s 0000e000 08:15 1067043 /opt/eclipse362/plugins/org.eclipse.core.net_1.2.100.I201005 11-0800.jar
b2c4f000-b2caf000 rw-s 00000000 00:04 42795014 /SYSV00000000 (deleted)
b2caf000-b2cb1000 r--s 00014000 08:15 1067281 /opt/eclipse362/plugins/org.eclipse.ui.intro.universal_3.2.4 02.r36_v20100702/universal.jar
b2cb1000-b2cb5000 r--s 0001d000 08:15 1067974 /opt/eclipse362/plugins/org.eclipse.ui.externaltools_3.2.0.v 20100427.jar
b2cb5000-b2cd1000 r--s 00141000 08:15 1066925 /opt/eclipse362/plugins/org.eclipse.team.ui_3.5.102.R36x_v20 110203-1036.jar
b2cd1000-b2cd4000 r--s 00019000 08:15 1067812 /opt/eclipse362/plugins/org.eclipse.pde.launching_3.6.0.v201 00601.jar
b2cd4000-b2cdd000 r--s 00069000 08:15 1067938 /opt/eclipse362/plugins/org.eclipse.search_3.6.0.v20100520-0 800.jar
b2cdd000-b2d0e000 r--s 00240000 08:15 1067979 /opt/eclipse362/plugins/org.eclipse.debug.ui_3.6.3.v20101201 _r362.jar
b2d0e000-b2d1a000 r--s 00082000 08:15 1067244 /opt/eclipse362/plugins/org.eclipse.ui.workbench.texteditor_ 3.6.1.r361_v20100714-0800.jar
b2d1a000-b2d25000 r--s 0007d000 08:15 1067065 /opt/eclipse362/plugins/org.eclipse.ui.editors_3.6.1.r361_v2 0100825-0800.jar
b2d25000-b2db7000 r--s 008f6000 08:15 1067733 /opt/eclipse362/plugins/org.eclipse.jdt.ui_3.6.2.r362_v20110 203.jar
b2db7000-b2e00000 r--s 003b8000 08:15 1068003 /opt/eclipse362/plugins/org.eclipse.pde.ui_3.6.1.v20110210_r 362.jar
b2e00000-b2eff000 rw-p 00000000 00:00 0
b2eff000-b2f00000 ---p 00000000 00:00 0
b2f01000-b2f04000 r--s 00019000 08:15 1067276 /opt/eclipse362/plugins/org.eclipse.core.filebuffers_3.5.100 .v20100520-0800.jar
b2f04000-b2f07000 ---p 00000000 00:00 0
b2f07000-b2f54000 rwxp 00000000 00:00 0
b2f54000-b2f5e000 r-xp 00000000 08:15 1068277 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-cairo-gtk-3659.so
b2f5e000-b2f5f000 rw-p 00009000 08:15 1068277 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-cairo-gtk-3659.so
b2f60000-b2f63000 r--s 00012000 08:15 1067763 /opt/eclipse362/plugins/org.eclipse.jdt.core.manipulation_1. 3.0.v20100520-0800.jar
b2f63000-b2f76000 r--s 000dc000 08:15 1067937 /opt/eclipse362/plugins/org.eclipse.jface.text_3.6.1.r361_v2 0100825-0800.jar
b2f76000-b2f7b000 r--p 00000000 08:15 1189357 /usr/local/share/icons/hicolor/icon-theme.cache
b2f7b000-b2f85000 r--p 00000000 08:15 331208 /usr/share/locale/en_GB/LC_MESSAGES/glib20.mo
b2f85000-b2f89000 r--s 0001e000 08:15 1067243 /opt/eclipse362/plugins/org.eclipse.ui.views.log_1.0.100.v20 110210_r362.jar
b2f89000-b2f8c000 r--s 00013000 08:15 1067215 /opt/eclipse362/plugins/org.eclipse.ui.views_3.5.1.M20110202 -0800.jar
b2f8c000-b2f8f000 rw-s 00000000 00:04 42762245 /SYSV00000000 (deleted)
b2f8f000-b2f92000 ---p 00000000 00:00 0
b2f92000-b2fdf000 rwxp 00000000 00:00 0
b2fdf000-b2fe6000 r--s 00052000 08:15 1067803 /opt/eclipse362/plugins/org.eclipse.jdt.apt.core_3.3.402.R36 _v20110120-1000.jar
b2fe6000-b2fe9000 ---p 00000000 00:00 0
b2fe9000-b3036000 rwxp 00000000 00:00 0
b3036000-b303e000 r--s 0004c000 08:15 1067160 /opt/eclipse362/plugins/org.eclipse.debug.core_3.6.0.v201005 19.jar
b303e000-b3042000 r--s 00044000 08:15 1068000 /opt/eclipse362/plugins/org.eclipse.jdt.launching_3.5.200.v2 0110105_r362.jar
b3042000-b3045000 ---p 00000000 00:00 0
b3045000-b3092000 rwxp 00000000 00:00 0
b3092000-b309a000 r--s 00115000 08:15 2099202 /opt/jdk1.6.0_25/jre/lib/resources.jar
b309a000-b309f000 r--s 00038000 08:15 1067766 /opt/eclipse362/plugins/org.eclipse.text_3.5.0.v20100601-130 0.jar
b309f000-b30a3000 r--s 0003b000 08:15 1066931 /opt/eclipse362/plugins/org.eclipse.help_3.5.0.v20100524.jar
b30a3000-b30ab000 r--s 00049000 08:15 1067149 /opt/eclipse362/plugins/org.eclipse.ui.cheatsheets_3.4.0.v20 100427.jar
b30ab000-b30b0000 r--s 0002a000 08:15 1067255 /opt/eclipse362/plugins/org.eclipse.ui.browser_3.3.1.r36_201 01216.jar
b30b0000-b30b3000 ---p 00000000 00:00 0
b30b3000-b3100000 rwxp 00000000 00:00 0
b3100000-b31fe000 rw-p 00000000 00:00 0
b31fe000-b3200000 ---p 00000000 00:00 0
b3200000-b3201000 r--s 00007000 08:15 1067074 /opt/eclipse362/plugins/org.eclipse.jdt.apt.pluggable.core_1 .0.301.R36_v20100727-0110.jar
b3201000-b3204000 r--s 00023000 08:15 1067069 /opt/eclipse362/plugins/org.eclipse.jdt.compiler.apt_1.0.300 .v20100513-0845.jar
b3204000-b3208000 r--s 00023000 08:15 1067170 /opt/eclipse362/plugins/org.eclipse.pde.runtime_3.4.200.v201 00601.jar
b3208000-b3212000 r--s 0006e000 08:15 1067839 /opt/eclipse362/plugins/org.eclipse.help.ui_3.5.3.r36_201011 16.jar
b3212000-b323b000 r--s 00425000 08:15 1067859 /opt/eclipse362/plugins/org.eclipse.jdt.core_3.6.2.v_A76_R36 x.jar
b323b000-b323e000 r--s 00013000 08:15 1066923 /opt/eclipse362/plugins/org.eclipse.core.expressions_3.4.200 .v20100505.jar
b323e000-b3247000 r--s 00056000 08:15 1067831 /opt/eclipse362/plugins/org.eclipse.team.core_3.5.101.R36x_v 20110203-1036.jar
b3247000-b324a000 ---p 00000000 00:00 0
b324a000-b3297000 rwxp 00000000 00:00 0
b3297000-b32a0000 r-xp 00000000 08:15 1068234 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-atk-gtk-3659.so
b32a0000-b32a1000 rw-p 00008000 08:15 1068234 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-atk-gtk-3659.so
b32a1000-b32c2000 r--s 00607000 08:15 1067180 /opt/eclipse362/plugins/com.ibm.icu_4.2.1.v20100412.jar
b32c2000-b32ca000 r--s 0003b000 08:15 1067844 /opt/eclipse362/plugins/org.eclipse.core.databinding.observa ble_1.3.0.I20100601-0800.jar
b32ca000-b32d2000 r--s 0003a000 08:15 1067813 /opt/eclipse362/plugins/org.eclipse.jface.databinding_1.4.0. I20100601-0800.jar
b32d2000-b32d5000 ---p 00000000 00:00 0
b32d5000-b3322000 rwxp 00000000 00:00 0
b3322000-b3325000 r--s 00014000 08:15 1067834 /opt/eclipse362/plugins/org.eclipse.core.contenttype_3.4.100 .v20100505-1235.jar
b3325000-b3327000 r-xp 00000000 08:15 1068243 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/30/1/ .cp/os/linux/x86/libunixfile_1_0_0.so
b3327000-b3328000 rw-p 00001000 08:15 1068243 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/30/1/ .cp/os/linux/x86/libunixfile_1_0_0.so
b3328000-b332a000 r--s 0000b000 08:15 1067275 /opt/eclipse362/plugins/org.eclipse.core.filesystem_1.3.1.R3 6x_v20100727-0745.jar
b332a000-b3336000 r--s 000b2000 08:15 1067056 /opt/eclipse362/plugins/org.eclipse.core.resources_3.6.1.R36 x_v20110131-1630.jar
b3336000-b335c000 r--s 0020a000 08:15 1067761 /opt/eclipse362/plugins/org.eclipse.ui.ide_3.6.2.M20101201-0 800.jar
b335c000-b3360000 r-xp 00000000 08:15 824323 /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
b3360000-b3361000 rw-p 00003000 08:15 824323 /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
b3361000-b3366000 r-xp 00000000 08:15 824308 /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
b3366000-b3367000 rw-p 00004000 08:15 824308 /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
b3367000-b33ff000 r--p 00000000 08:15 827224 /usr/share/fonts/TTF/DejaVuSans.ttf
b33ff000-b340f000 r--s 00000000 08:15 3934805 /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-le32d 4.cache-3
b340f000-b3419000 r--s 00000000 08:15 3934782 /var/cache/fontconfig/d62e99ef547d1d24cdb1bd22ec1a2976-le32d 4.cache-3
b3419000-b341d000 r-xp 00000000 08:15 344490 /usr/lib/libXtst.so.6.1.0
b341d000-b341e000 rw-p 00003000 08:15 344490 /usr/lib/libXtst.so.6.1.0
b341e000-b3421000 r-xp 00000000 08:15 262240 /usr/lib/libgthread-2.0.so.0.2200.5
b3421000-b3422000 rw-p 00003000 08:15 262240 /usr/lib/libgthread-2.0.so.0.2200.5
b3422000-b3424000 r--s 0000c000 08:15 1067964 /opt/eclipse362/plugins/org.eclipse.jdt.compiler.tool_1.0.10 0.v_A76_R36x.jar
b3424000-b3426000 r-xp 00000000 08:15 1584745 /usr/local/lib/pango/1.6.0/modules/pango-basic-fc.so
b3426000-b3427000 rw-p 00001000 08:15 1584745 /usr/local/lib/pango/1.6.0/modules/pango-basic-fc.so
b3427000-b3440000 r--s 00000000 08:15 3934778 /var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-le32d 4.cache-3
b3440000-b3445000 r--s 00000000 08:15 3932175 /var/cache/fontconfig/f349e9996a5320f6dd491cedd2b1f964-le32d 4.cache-3
b3445000-b3449000 rwxp 00000000 00:00 0
b3449000-b34a2000 r-xp 00000000 08:15 1068224 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-pi-gtk-3659.so
b34a2000-b34a4000 rw-p 00058000 08:15 1068224 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-pi-gtk-3659.so
b34a4000-b34a5000 rw-p 00000000 00:00 0
b34a5000-b34b9000 r--s 00213000 08:15 1067753 /opt/eclipse362/plugins/org.eclipse.swt.gtk.linux.x86_3.6.2. v3659b.jar
b34b9000-b3500000 r--s 003ab000 08:15 1067193 /opt/eclipse362/plugins/org.eclipse.ui.workbench_3.6.2.M2011 0210-1200.jar
b3500000-b3600000 rw-p 00000000 00:00 0
b3600000-b3601000 r--s 00002000 08:15 1067192 /opt/eclipse362/plugins/org.eclipse.core.filesystem.linux.x8 6_1.4.0.v20100505-1235.jar
b3601000-b3604000 r-xp 00000000 08:15 1068223 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-gtk-3659.so
b3604000-b3605000 rw-p 00002000 08:15 1068223 /opt/eclipse362/configuration/org.eclipse.osgi/bundles/151/1 /.cp/libswt-gtk-3659.so
b3605000-b3606000 rw-p 00000000 00:00 0
b3606000-b360a000 r--s 00017000 08:15 1067828 /opt/eclipse362/plugins/org.eclipse.core.commands_3.6.0.I201 00512-1500.jar
b360a000-b360f000 r--s 00021000 08:15 1067991 /opt/eclipse362/plugins/org.eclipse.ui_3.6.2.M20110203-1100. jar
b360f000-b3610000 r--s 00004000 08:15 1067271 /opt/eclipse362/plugins/org.eclipse.swt_3.6.2.v3659c.jar
b3610000-b3625000 r--s 000f1000 08:15 1068009 /opt/eclipse362/plugins/org.eclipse.jface_3.6.2.M20110210-12 00.jar
b3625000-b3627000 r--s 00001000 08:15 1067950 /opt/eclipse362/plugins/org.eclipse.ui.workbench.compatibili ty_3.2.100.I20100511-0800/compatibility.jar
b3627000-b3629000 r--s 0000e000 08:15 1066935 /opt/eclipse362/plugins/org.eclipse.ui.ide.application_1.0.2 01.M20100707-0800.jar
b3629000-b362c000 r--s 0000e000 08:15 1067757 /opt/eclipse362/plugins/org.eclipse.equinox.p2.core_2.0.3.R3 6x_v20110111.jar
b362c000-b362d000 r--s 00007000 08:15 1067273 /opt/eclipse362/plugins/org.eclipse.equinox.p2.directorywatc her_1.0.203.R36x_v20101220.jar
b362d000-b362e000 r--s 0000a000 08:15 1067063 /opt/eclipse362/plugins/org.eclipse.equinox.p2.reconciler.dr opins_1.1.2.R36x_v20110114.jar
b362e000-b3630000 r--s 00015000 08:15 1067962 /opt/eclipse362/plugins/org.eclipse.core.runtime.compatibili ty_3.2.100.v20100505.jar
b3630000-b3632000 r--s 00013000 08:15 1067163 /opt/eclipse362/plugins/org.eclipse.equinox.app_1.3.1.R36x_v 20100803.jar
b3632000-b3635000 r--s 00014000 08:15 1067269 /opt/eclipse362/plugins/org.eclipse.core.jobs_3.5.1.R36x_v20 100824.jar
b3635000-b3638000 r--s 00019000 08:15 1067971 /opt/eclipse362/plugins/org.eclipse.equinox.preferences_3.3. 0.v20100503.jar
b3638000-b3639000 r--s 00005000 08:15 1067738 /opt/eclipse362/plugins/org.eclipse.core.runtime.compatibili ty.auth_3.2.200.v20100517.jar
b3639000-b363d000 r--s 00029000 08:15 1067958 /opt/eclipse362/plugins/org.eclipse.equinox.registry_3.5.0.v 20100503.jar
b363d000-b363f000 r--s 00010000 08:15 1067263 /opt/eclipse362/plugins/org.eclipse.core.runtime_3.6.0.v2010 0505.jar
b363f000-b3642000 ---p 00000000 00:00 0
b3642000-b368f000 rwxp 00000000 00:00 0
b368f000-b3692000 ---p 00000000 00:00 0
b3692000-b36df000 rwxp 00000000 00:00 0
b36df000-b36e1000 r--s 00006000 08:15 1067756 /opt/eclipse362/plugins/org.eclipse.equinox.event_1.2.0.v201 00503.jar
b36e1000-b36e4000 r--s 0000e000 08:15 1067976 /opt/eclipse362/plugins/org.eclipse.osgi.services_3.2.100.v2 0100503.jar
b36e4000-b36e6000 r--s 00011000 08:15 1067062 /opt/eclipse362/plugins/org.eclipse.equinox.util_1.0.200.v20 100503.jar
b36e6000-b36e8000 r--s 0002b000 08:15 1067836 /opt/eclipse362/plugins/org.eclipse.equinox.ds_1.2.1.R36x_v2 0100803.jar
b36e8000-b36ea000 r--s 00017000 08:15 1067042 /opt/eclipse362/plugins/org.eclipse.equinox.common_3.6.0.v20 100503.jar
b36ea000-b36ed000 ---p 00000000 00:00 0
b36ed000-b373a000 rwxp 00000000 00:00 0
b373a000-b373d000 ---p 00000000 00:00 0
b373d000-b378a000 rwxp 00000000 00:00 0
b378a000-b378d000 ---p 00000000 00:00 0
b378d000-b37da000 rwxp 00000000 00:00 0
b37da000-b37ee000 r-xp 00000000 08:15 2099110 /opt/jdk1.6.0_25/jre/lib/i386/libnet.so
b37ee000-b37ef000 rw-p 00013000 08:15 2099110 /opt/jdk1.6.0_25/jre/lib/i386/libnet.so
b37ef000-b3800000 r--s 00108000 08:15 1067143 /opt/eclipse362/plugins/org.eclipse.osgi_3.6.2.R36x_v2011021 0.jar
b3800000-b3900000 rw-p 00000000 00:00 0
b3900000-b3902000 r--s 00008000 08:15 1067187 /opt/eclipse362/plugins/org.eclipse.equinox.simpleconfigurat or_1.0.200.v20100503.jar
b3902000-b3909000 r-xp 00000000 08:15 2099111 /opt/jdk1.6.0_25/jre/lib/i386/libnio.so
b3909000-b390a000 rw-p 00006000 08:15 2099111 /opt/jdk1.6.0_25/jre/lib/i386/libnio.so
b390a000-b390b000 ---p 00000000 00:00 0
b390b000-b398a000 rwxp 00000000 00:00 0
b398a000-b398d000 ---p 00000000 00:00 0
b398d000-b39da000 rwxp 00000000 00:00 0
b39da000-b39dd000 ---p 00000000 00:00 0
b39dd000-b3a5a000 rwxp 00000000 00:00 0
b3a5a000-b3a5d000 ---p 00000000 00:00 0
b3a5d000-b3aaa000 rwxp 00000000 00:00 0
b3aaa000-b3aad000 ---p 00000000 00:00 0
b3aad000-b3afa000 rwxp 00000000 00:00 0
b3afa000-b3afd000 ---p 00000000 00:00 0
b3afd000-b3b4a000 rwxp 00000000 00:00 0
b3b4a000-b3b7e000 rw-p 00000000 00:00 0
b3b7e000-b3d16000 r--s 0302a000 08:15 2104382 /opt/jdk1.6.0_25/jre/lib/rt.jar
b3d16000-b3d17000 ---p 00000000 00:00 0
b3d17000-b3d96000 rwxp 00000000 00:00 0
b3d96000-b3db7000 rw-p 00000000 00:00 0
b3db7000-b3e24000 rw-p 00000000 00:00 0
b3e24000-b3e33000 rw-p 00000000 00:00 0
b3e33000-b3ea5000 rw-p 00000000 00:00 0
b3ea5000-b3ead000 rw-p 00000000 00:00 0
b3ead000-b3ee5000 rw-p 00000000 00:00 0
b3ee5000-b3ef4000 rw-p 00000000 00:00 0
b3ef4000-b3f65000 rw-p 00000000 00:00 0
b3f65000-b3f79000 rw-p 00000000 00:00 0
b3f79000-b3fe5000 rw-p 00000000 00:00 0
b3fe5000-b3fff000 rw-p 00000000 00:00 0
b3fff000-b4071000 rw-p 00000000 00:00 0
b4071000-b43e9000 rwxp 00000000 00:00 0
b43e9000-b6071000 rw-p 00000000 00:00 0
b6071000-b6094000 r-xp 00000000 08:15 2099102 /opt/jdk1.6.0_25/jre/lib/i386/libjava.so
b6094000-b6096000 rw-p 00023000 08:15 2099102 /opt/jdk1.6.0_25/jre/lib/i386/libjava.so
b6096000-b609d000 r-xp 00000000 08:15 4063321 /lib/librt-2.11.1.so
b609d000-b609e000 r--p 00006000 08:15 4063321 /lib/librt-2.11.1.so
b609e000-b609f000 rw-p 00007000 08:15 4063321 /lib/librt-2.11.1.so
b609f000-b60a1000 r--s 0000a000 08:15 1067204 /opt/eclipse362/plugins/org.eclipse.equinox.launcher_1.1.1.R 36x_v20101122_1400.jar
b60a1000-b60b0000 r-xp 00000000 08:15 2099106 /opt/jdk1.6.0_25/jre/lib/i386/libzip.so
b60b0000-b60b2000 rw-p 0000e000 08:15 2099106 /opt/jdk1.6.0_25/jre/lib/i386/libzip.so
b60b2000-b60ba000 rw-s 00000000 08:15 3670041 /tmp/hsperfdata_root/4053
b60ba000-b60c5000 r-xp 00000000 08:15 2099101 /opt/jdk1.6.0_25/jre/lib/i386/libverify.so
b60c5000-b60c6000 rw-p 0000b000 08:15 2099101 /opt/jdk1.6.0_25/jre/lib/i386/libverify.so
b60c6000-b65a7000 r-xp 00000000 08:15 2099095 /opt/jdk1.6.0_25/jre/lib/i386/client/libjvm.so
b65a7000-b65ca000 rw-p 004e1000 08:15 2099095 /opt/jdk1.6.0_25/jre/lib/i386/client/libjvm.so
b65ca000-b69e6000 rw-p 00000000 00:00 0
b69e6000-b6a46000 rw-s 00000000 00:04 42631172 /SYSV00000000 (deleted)
b6a46000-b6aa9000 rw-p 00000000 00:00 0
b6aa9000-b6aac000 r-xp 00000000 08:15 824320 /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
b6aac000-b6aad000 rw-p 00002000 08:15 824320 /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
b6aad000-b6ac8000 r--s 00000000 08:15 567527 /usr/share/mime/mime.cache
b6ac8000-b6ad3000 r-xp 00000000 08:15 4063314 /lib/libnss_files-2.11.1.so
b6ad3000-b6ad4000 r--p 0000a000 08:15 4063314 /lib/libnss_files-2.11.1.so
b6ad4000-b6ad5000 rw-p 0000b000 08:15 4063314 /lib/libnss_files-2.11.1.so
b6ad5000-b6aea000 r-xp 00000000 08:15 4063311 /lib/libnsl-2.11.1.so
b6aea000-b6aeb000 r--p 00014000 08:15 4063311 /lib/libnsl-2.11.1.so
b6aeb000-b6aec000 rw-p 00015000 08:15 4063311 /lib/libnsl-2.11.1.so
b6aec000-b6aee000 rw-p 00000000 00:00 0
b6aee000-b6aef000 r--s 00002000 08:15 1067848 /opt/eclipse362/plugins/org.eclipse.core.runtime.compatibili ty.registry_3.3.0.v20100520/runtime_registry_compatibility.j ar
b6aef000-b6af0000 rw-p 00000000 00:00 0
b6af0000-b6b15000 r--p 00000000 08:15 332047 /usr/share/locale/en_GB/LC_MESSAGES/gtk20-properties.mo
b6b15000-b6b2d000 r-xp 00000000 08:15 330548 /usr/lib/libatk-1.0.so.0.3009.1
b6b2d000-b6b2f000 rw-p 00018000 08:15 330548 /usr/lib/libatk-1.0.so.0.3009.1
b6b2f000-b6ed6000 r-xp 00000000 08:15 331888 /usr/lib/libgtk-x11-2.0.so.0.1800.9
b6ed6000-b6edc000 rw-p 003a7000 08:15 331888 /usr/lib/libgtk-x11-2.0.so.0.1800.9
b6edc000-b6edd000 rw-p 00000000 00:00 0
b6edd000-b6ef9000 r-xp 00000000 08:15 262225 /usr/lib/libgcc_s.so.1
b6ef9000-b6efa000 rw-p 0001b000 08:15 262225 /usr/lib/libgcc_s.so.1
b6efa000-b6fde000 r-xp 00000000 08:15 264505 /usr/lib/libstdc++.so.6.0.13
b6fde000-b6fe2000 r--p 000e3000 08:15 264505 /usr/lib/libstdc++.so.6.0.13
b6fe2000-b6fe3000 rw-p 000e7000 08:15 264505 /usr/lib/libstdc++.so.6.0.13
b6fe3000-b6fea000 rw-p 00000000 00:00 0
b6fea000-b700f000 r-xp 00000000 08:15 349311 /usr/local/lib/libpangoft2-1.0.so.0.2800.1
b700f000-b7010000 rw-p 00025000 08:15 349311 /usr/local/lib/libpangoft2-1.0.so.0.2800.1
b7010000-b7034000 r-xp 00000000 08:15 4063309 /lib/libm-2.11.1.so
b7034000-b7035000 r--p 00023000 08:15 4063309 /lib/libm-2.11.1.so
b7035000-b7036000 rw-p 00024000 08:15 4063309 /lib/libm-2.11.1.so
b7036000-b7038000 r-xp 00000000 08:15 262261 /usr/lib/libgmodule-2.0.so.0.2200.5
b7038000-b7039000 rw-p 00002000 08:15 262261 /usr/lib/libgmodule-2.0.so.0.2200.5
b7039000-b704c000 r-xp 00000000 08:15 4063320 /lib/libresolv-2.11.1.so
b704c000-b704d000 r--p 00012000 08:15 4063320 /lib/libresolv-2.11.1.so
b704d000-b704e000 rw-p 00013000 08:15 4063320 /lib/libresolv-2.11.1.so
b704e000-b7050000 rw-p 00000000 00:00 0
b7050000-b70de000 r-xp 00000000 08:15 331119 /usr/lib/libgio-2.0.so.0.2200.5
b70de000-b70e0000 rw-p 0008e000 08:15 331119 /usr/lib/libgio-2.0.so.0.2200.5
b70e0000-b70f7000 r-xp 00000000 08:15 331875 /usr/lib/libgdk_pixbuf-2.0.so.0.1800.9
b70f7000-b70f8000 rw-p 00016000 08:15 331875 /usr/lib/libgdk_pixbuf-2.0.so.0.1800.9
b70f8000-b710f000 r-xp 00000000 08:15 344696 /usr/lib/libxcb.so.1.1.0
b710f000-b7110000 rw-p 00016000 08:15 344696 /usr/lib/libxcb.so.1.1.0
b7110000-b7227000 r-xp 00000000 08:15 343785 /usr/lib/libX11.so.6.3.0
b7227000-b722b000 rw-p 00116000 08:15 343785 /usr/lib/libX11.so.6.3.0
b722b000-b723e000 r-xp 00000000 08:15 262257 /usr/lib/libz.so.1.2.3
b723e000-b723f000 rw-p 00012000 08:15 262257 /usr/lib/libz.so.1.2.3
b723f000-b7247000 r-xp 00000000 08:15 344189 /usr/lib/libXrender.so.1.3.0
b7247000-b7248000 rw-p 00007000 08:15 344189 /usr/lib/libXrender.so.1.3.0
b7248000-b726d000 r-xp 00000000 08:15 262243 /usr/lib/libpng14.so.14.2.0
b726d000-b726e000 rw-p 00024000 08:15 262243 /usr/lib/libpng14.so.14.2.0
b726e000-b728c000 r-xp 00000000 08:15 262232 /usr/lib/libexpat.so.1.5.2
b728c000-b728e000 rw-p 0001d000 08:15 262232 /usr/lib/libexpat.so.1.5.2
b728e000-b7300000 r-xp 00000000 08:15 262228 /usr/lib/libfreetype.so.6.4.0
b7300000-b7304000 rw-p 00071000 08:15 262228 /usr/lib/libfreetype.so.6.4.0
b7304000-b7330000 r-xp 00000000 08:15 342890 /usr/lib/libfontconfig.so.1.4.4
b7330000-b7332000 rw-p 0002b000 08:15 342890 /usr/lib/libfontconfig.so.1.4.4
b7332000-b737f000 r-xp 00000000 08:15 345127 /usr/lib/libpixman-1.so.0.16.6
b737f000-b7381000 rw-p 0004c000 08:15 345127 /usr/lib/libpixman-1.so.0.16.6
b7381000-b73ed000 r-xp 00000000 08:15 330706 /usr/lib/libcairo.so.2.10800.8
b73ed000-b73ef000 rw-p 0006c000 08:15 330706 /usr/lib/libcairo.so.2.10800.8
b73ef000-b73f3000 r-xp 00000000 08:15 343990 /usr/lib/libXfixes.so.3.1.0
b73f3000-b73f4000 rw-p 00003000 08:15 343990 /usr/lib/libXfixes.so.3.1.0
b73f4000-b73f6000 r-xp 00000000 08:15 343900 /usr/lib/libXdamage.so.1.1.0
b73f6000-b73f7000 rw-p 00001000 08:15 343900 /usr/lib/libXdamage.so.1.1.0
b73f7000-b7404000 r-xp 00000000 08:15 343983 /usr/lib/libXext.so.6.4.0
b7404000-b7405000 rw-p 0000d000 08:15 343983 /usr/lib/libXext.so.6.4.0
b7405000-b7407000 r-xp 00000000 08:15 343859 /usr/lib/libXcomposite.so.1.0.0
b7407000-b7408000 rw-p 00001000 08:15 343859 /usr/lib/libXcomposite.so.1.0.0
b7408000-b7410000 r-xp 00000000 08:15 343896 /usr/lib/libXcursor.so.1.0.2
b7410000-b7411000 rw-p 00007000 08:15 343896 /usr/lib/libXcursor.so.1.0.2
b7411000-b7415000 r-xp 00000000 08:15 343905 /usr/lib/libXdmcp.so.6.0.0
b7415000-b7416000 rw-p 00003000 08:15 343905 /usr/lib/libXdmcp.so.6.0.0
b7416000-b7418000 r-xp 00000000 08:15 343826 /usr/lib/libXau.so.6.0.0
b7418000-b7419000 rw-p 00001000 08:15 343826 /usr/lib/libXau.so.6.0.0
b7419000-b741f000 r-xp 00000000 08:15 344184 /usr/lib/libXrandr.so.2.2.0
b741f000-b7420000 rw-p 00005000 08:15 344184 /usr/lib/libXrandr.so.2.2.0
b7420000-b742c000 r-xp 00000000 08:15 344086 /usr/lib/libXi.so.6.1.0
b742c000-b742d000 rw-p 0000b000 08:15 344086 /usr/lib/libXi.so.6.1.0
b742d000-b746c000 r-xp 00000000 08:15 349303 /usr/local/lib/libpango-1.0.so.0.2800.1
b746c000-b746e000 rw-p 0003f000 08:15 349303 /usr/local/lib/libpango-1.0.so.0.2800.1
b746e000-b74fe000 r-xp 00000000 08:15 331890 /usr/lib/libgdk-x11-2.0.so.0.1800.9
b74fe000-b7501000 rw-p 00090000 08:15 331890 /usr/lib/libgdk-x11-2.0.so.0.1800.9
b7501000-b75d0000 r-xp 00000000 08:15 262235 /usr/lib/libglib-2.0.so.0.2200.5
b75d0000-b75d1000 rw-p 000cf000 08:15 262235 /usr/lib/libglib-2.0.so.0.2200.5
b75d1000-b760a000 r-xp 00000000 08:15 262227 /usr/lib/libgobject-2.0.so.0.2200.5
b760a000-b760b000 rw-p 00039000 08:15 262227 /usr/lib/libgobject-2.0.so.0.2200.5
b760b000-b760c000 r--p 00000000 08:15 331265 /usr/share/locale/en_GB/LC_MESSAGES/libc.mo
b760c000-b7615000 r-xp 00000000 08:15 4063316 /lib/libnss_nis-2.11.1.so
b7615000-b7616000 r--p 00008000 08:15 4063316 /lib/libnss_nis-2.11.1.so
b7616000-b7617000 rw-p 00009000 08:15 4063316 /lib/libnss_nis-2.11.1.so
b7617000-b761e000 r-xp 00000000 08:15 4063312 /lib/libnss_compat-2.11.1.so
b761e000-b761f000 r--p 00006000 08:15 4063312 /lib/libnss_compat-2.11.1.so
b761f000-b7620000 rw-p 00007000 08:15 4063312 /lib/libnss_compat-2.11.1.so
b7620000-b7632000 r--p 00000000 08:15 332048 /usr/share/locale/en_GB/LC_MESSAGES/gtk20.mo
b7632000-b7671000 r--p 00000000 08:15 817685 /usr/lib/locale/en_GB.utf8/LC_CTYPE
b7671000-b7673000 rw-p 00000000 00:00 0
b7673000-b77cf000 r-xp 00000000 08:15 4063305 /lib/libc-2.11.1.so
b77cf000-b77d0000 ---p 0015c000 08:15 4063305 /lib/libc-2.11.1.so
b77d0000-b77d2000 r--p 0015c000 08:15 4063305 /lib/libc-2.11.1.so
b77d2000-b77d3000 rw-p 0015e000 08:15 4063305 /lib/libc-2.11.1.so
b77d3000-b77d6000 rw-p 00000000 00:00 0
b77d6000-b77d8000 r-xp 00000000 08:15 4063308 /lib/libdl-2.11.1.so
b77d8000-b77d9000 r--p 00001000 08:15 4063308 /lib/libdl-2.11.1.so
b77d9000-b77da000 rw-p 00002000 08:15 4063308 /lib/libdl-2.11.1.so
b77da000-b77ef000 r-xp 00000000 08:15 4063319 /lib/libpthread-2.11.1.so
b77ef000-b77f0000 r--p 00014000 08:15 4063319 /lib/libpthread-2.11.1.so
b77f0000-b77f1000 rw-p 00015000 08:15 4063319 /lib/libpthread-2.11.1.so
b77f1000-b77f3000 rw-p 00000000 00:00 0
b77f3000-b77f4000 r--s 00000000 08:15 1180143 /root/.local/share/mime/mime.cache
b77f4000-b77f5000 r--p 00000000 00:00 0
b77f5000-b77f7000 r-xp 00000000 08:15 344097 /usr/lib/libXinerama.so.1.0.0
b77f7000-b77f8000 rw-p 00001000 08:15 344097 /usr/lib/libXinerama.so.1.0.0
b77f8000-b7802000 r-xp 00000000 08:15 349319 /usr/local/lib/libpangocairo-1.0.so.0.2800.1
b7802000-b7803000 rw-p 00009000 08:15 349319 /usr/local/lib/libpangocairo-1.0.so.0.2800.1
b7803000-b780f000 r-xp 00000000 08:15 1067983 /opt/eclipse362/plugins/org.eclipse.equinox.launcher.gtk.lin ux.x86_1.1.2.R36x_v20101019_1345/eclipse_1310.so
b780f000-b7810000 rw-p 0000c000 08:15 1067983 /opt/eclipse362/plugins/org.eclipse.equinox.launcher.gtk.lin ux.x86_1.1.2.R36x_v20101019_1345/eclipse_1310.so
b7810000-b7811000 r--p 00000000 08:15 817724 /usr/lib/locale/en_GB.utf8/LC_NUMERIC
b7811000-b7812000 r--p 00000000 08:15 817948 /usr/lib/locale/en_GB.utf8/LC_TIME
b7812000-b7813000 r--p 00000000 08:15 815487 /usr/lib/locale/en_GB.utf8/LC_MONETARY
b7813000-b7814000 r--p 00000000 08:15 817813 /usr/lib/locale/en_GB.utf8/LC_MESSAGES/SYS_LC_MESSAGES
b7814000-b7815000 r--p 00000000 08:15 817682 /usr/lib/locale/en_GB.utf8/LC_PAPER
b7815000-b7816000 r--p 00000000 08:15 817946 /usr/lib/locale/en_GB.utf8/LC_NAME
b7816000-b7817000 r--p 00000000 08:15 815750 /usr/lib/locale/en_GB.utf8/LC_ADDRESS
b7817000-b7818000 r--p 00000000 08:15 815485 /usr/lib/locale/en_GB.utf8/LC_TELEPHONE
b7818000-b7819000 r--p 00000000 08:15 817686 /usr/lib/locale/en_GB.utf8/LC_MEASUREMENT
b7819000-b781a000 r--p 00000000 08:15 815751 /usr/lib/locale/en_GB.utf8/LC_IDENTIFICATION
b781a000-b781b000 rw-p 00000000 00:00 0
b781b000-b7838000 r-xp 00000000 08:15 4063347 /lib/ld-2.11.1.so
b7838000-b7839000 r--p 0001d000 08:15 4063347 /lib/ld-2.11.1.so
b7839000-b783a000 rw-p 0001e000 08:15 4063347 /lib/ld-2.11.1.so
bff19000-bff1c000 ---p 00000000 00:00 0
bff1c000-bff69000 rwxp 00000000 00:00 0 [stack]
bff69000-bff6a000 rw-p 00000000 00:00 0
VM Arguments:
jvm_args: -Xms40m -Xmx384m -vm /opt/java/bin/java -XX:MaxPermSize=256m
LD_LIBRARY_PATH=/opt/jdk1.6.0_25/jre/lib/i386/client:/opt/jd k1.6.0_25/jre/lib/i386:/usr/lib/seamonkey/:/usr/lib/seamonke y/
Signal Handlers:
SIGSEGV: [libjvm.so+0x469d20], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x469d20], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x38bd70], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGXFSZ: [libjvm.so+0x38bd70], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x38bd70], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR2: [libjvm.so+0x38efb0], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x38eb90], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: [libjvm.so+0x38eb90], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x38eb90], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x38eb90], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
OS:Linux
rlimit: STACK 8192k, CORE 0k, NPROC 16055, NOFILE 1024, AS infinity
load average:0.23 0.14 0.10
/proc/meminfo:
MemTotal: 2057248 kB
MemFree: 359276 kB
Buffers: 63240 kB
Cached: 1229172 kB
SwapCached: 0 kB
Active: 898236 kB
Inactive: 735028 kB
Active(anon): 349824 kB
Inactive(anon): 0 kB
Active(file): 548412 kB
Inactive(file): 735028 kB
Unevictable: 0 kB
Mlocked: 0 kB
HighTotal: 1183528 kB
HighFree: 1736 kB
LowTotal: 873720 kB
LowFree: 357540 kB
SwapTotal: 4192924 kB
SwapFree: 4192924 kB
Dirty: 412 kB
Writeback: 16 kB
AnonPages: 340872 kB
Mapped: 64432 kB
Shmem: 8972 kB
Slab: 46668 kB
SReclaimable: 40236 kB
SUnreclaim: 6432 kB
KernelStack: 1920 kB
PageTables: 1588 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 5221548 kB
Committed_AS: 687620 kB
VmallocTotal: 122880 kB
VmallocUsed: 23080 kB
VmallocChunk: 90772 kB
DirectMap4k: 20472 kB
DirectMap4M: 884736 kB
CPU:total 2 (2 cores per cpu, 1 threads per core) family 15 model 6 stepping 4, cmov, cx8, fxsr, mmx, sse, sse2, sse3
/proc/cpuinfo:
processor : 0
vendor_id : GenuineIntel
cpu family : 15
model : 6
model name : Intel(R) Pentium(R) D CPU 2.80GHz
stepping : 4
cpu MHz : 2790.967
cache size : 2048 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 6
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx lm constant_tsc pebs bts pni dtes64 monitor ds_cpl est cid cx16 xtpr pdcm lahf_lm
bogomips : 5581.93
clflush size : 64
cache_alignment : 128
address sizes : 36 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 15
model : 6
stepping : 4
cpu MHz : 2790.967
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 1
initial apicid : 1
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 6
wp : yes
bogomips : 5581.32
clflush size : 64
power management:
Memory: 4k page, physical 2057248k(359276k free), swap 4192924k(4192924k free)
vm_info: Java HotSpot(TM) Client VM (20.0-b11) for linux-x86 JRE (1.6.0_25-b06), built on Apr 14 2011 01:32:00 by "java_re" with gcc 3.2.1-7a (J2SE release)
time: Tue May 3 16:22:24 2011
elapsed time: 33 seconds
Re: Eclipse crashes [message #668072 is a reply to message #668070] Tue, 03 May 2011 11:40 Go to previous message
As a solution, in a terminal window try:
#export LD_LIBRARY_PATH
This will get read of some implicit un-wanted 'dependencies'.
I suspect that in my case at least, eclipse finds and uses some libraries from mozilla/seamonkey that are not really compatible with it.
Previous Topic:Communication between command handlers in the same plugin
Next Topic:Adding new packages
Current Time: Sat Jul 26 12:43:55 EDT 2025
Powered by FUDForum. Page generated in 0.09379 seconds
