Home » Eclipse Projects » Rich Client Platform (RCP) » how to specify the path of a file bundled in the package
how to specify the path of a file bundled in the package [message #649334] Tue, 18 January 2011 14:11 Go to next message
I am trying to load an external dll file into my java program, however if I give the absolute path (for example "lib"), eclipse will look for this file under the eclipse installation directory rather than in the package itself.
I'd like to have something like
Activator.getImageDescriptor("icons/myimage.gif")...
but how does it work for general files?
Francesca
Re: how to specify the path of a file bundled in the package [message #649336 is a reply to message #649334] Tue, 18 January 2011 14:22 Go to previous messageGo to next message
If you have a file in your bundle, you can use Bundle.getEntry(*) to get
a URL to that file and FileLocator API to make sure it points to a file
on your filesystem.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: how to specify the path of a file bundled in the package [message #649343 is a reply to message #649336] Tue, 18 January 2011 15:05 Go to previous messageGo to next message
Thanks Paul.
I am not sure if I am doing the right way...
I have written
Bundle bundle = org.eclipse.core.runtime.Platform.getBundle"idofmyplugin");
String path = bundle.getEntry("lib").getPath();
The string path is returned as C:\lib
However there's no lib under C:
The folder lib is in the workspace at the same level as other folders like "icons" or "src"
Any clue?
Thank you very much for the quick reply!!
Francesca
Re: how to specify the path of a file bundled in the package [message #649495 is a reply to message #649343] Wed, 19 January 2011 08:18 Go to previous messageGo to next message
On 01/18/2011 03:05 PM, fran81 wrote:
> Thanks Paul.
> I have written
Don't use getPath(*) in the URL, instead use FileLocator to turn it into
an absolute file system path
PW
Paul Webster
Re: how to specify the path of a file bundled in the package [message #649606 is a reply to message #649495] Wed, 19 January 2011 16:32 Go to previous message
Thanks Paul, it's working now.
I have
try {
String path = FileLocatior.resolve(bundle.getEntry("lib")).getPath();
} catch (IOException e) {
Previous Topic:Remove Web Browser View
Next Topic:Workaround for Bug 139064 on Linux (JNI: UnsatisfiedLinkError)?
Current Time: Sun Jul 27 01:56:40 EDT 2025
Powered by FUDForum. Page generated in 0.25969 seconds
