Home » Eclipse Projects » GEF » Rendering SVG Image in GEF
Rendering SVG Image in GEF [message #520170] Thu, 11 March 2010 07:38 Go to next message
I am trying to display a svg image in an edit part in my gef application. I am trying to get the figure like below
RenderInfo renderInfo = RenderedImageFactory.createInfo(20, 40, false, false, new RGB(255, 255, 255), new RGB(0, 0, 0));
figure = new ScalableImageFigure(RenderedImageFactory.getInstance("C:\\temp1\\test.svg ",renderInfo));
However the quality of the image being rendered is very bad. Is there any better way to have an svg image in my edit part with quality.
I would also like to say that the image quality is as expected when i export the image to another svg. I export as below
Rectangle rootFigureBounds = rootFigure.getBounds();
GraphicsSVG graphics = GraphicsSVG.getInstance(rootFigureBounds.getTranslated(rootF igureBounds.getLocation().negate()));
graphics.translate(rootFigureBounds.getLocation().negate());
rootFigure.paint(graphics);
OutputStream outputStream;
try {
outputStream = new FileOutputStream (saveLocation);
graphics.getSVGGraphics2D().stream(new BufferedWriter(new OutputStreamWriter(outputStream)));
} catch (Exception e) {
e.printStackTrace();
[The resultant svg image out of the above code is as expected though the svg contents in editor were distorted]
Could anyone please point me in the direction of displaying the svg image in gef .
Thanks in advance for help
Bhat
Re: Rendering SVG Image in GEF [message #649242 is a reply to message #520170] Tue, 18 January 2011 05:55 Go to previous messageGo to next message
I have same question. Can we use SVG fimages in drawing the images(figures) for drawing the GEF Figures.
In some blogs, somebody has mentioned that GMF can use SVG Images for rendering via the ScalableImageFigure class.
But is it possible use SVG Image in GEF Figures (that used Draw2D) for rendering its figures.
If possible, give any hint or sample code.
Thanks in advance.
Deepak
Re: Rendering SVG Image in GEF [message #649244 is a reply to message #649242] Tue, 18 January 2011 06:14 Go to previous messageGo to next message
Hello Deepak,
Below is a small snippet which i created that exports a Ifigure created from draw2d into an svg
public void exportToSVG(String saveLocation, IFigure rootFigure, IProgressMonitor monitor) {
SubProgressMonitor subProgressMonitor = new SubProgressMonitor(monitor, 10);
subProgressMonitor.setTaskName("Creating SVG image...");
SVGIDGenerator generator = new SVGIDGenerator();
subProgressMonitor.worked(2);
graphics.getSVGGraphics2D().getGeneratorContext().setIDGener ator(generator);
OutputStream outputStream = null;
try {
subProgressMonitor.worked(4);
subProgressMonitor.done();
Hope it helps.
Bhat
Re: Rendering SVG Image in GEF [message #649248 is a reply to message #649244] Tue, 18 January 2011 06:42 Go to previous messageGo to next message
Hi Bhat,
Thanks for your reply.
Right now we are using draw2d for rendering the figures in GEF Editor.
But my question is that can we use SVG Images for rendering our images on the GEF Editor.
Any ides or sample code would be helpful.
Deepak Singla
Re: Rendering SVG Image in GEF [message #649249 is a reply to message #649248] Tue, 18 January 2011 06:49 Go to previous messageGo to next message
I guess in GMF you can render a svg image. So if you look at the way how gmf does it, you could use the same thing.
Bhat
Re: Rendering SVG Image in GEF [message #649266 is a reply to message #649248] Tue, 18 January 2011 08:26 Go to previous messageGo to next message
http://dev.eclipse.org/viewcvs/viewvc.cgi/org.eclipse.gmp/or g.eclipse.gmf.tooling/plugins/org.eclipse.gmf.runtime.lite.s vg/src/org/eclipse/gmf/runtime/lite/svg/SVGFigure.java?view= markup&root=Modeling_Project
Seems like there is no dependency over GMF. You can re-use this Figure as-it.
HTH
Le 18/01/2011 12:42, Deepak Singla a écrit :
> Hi Bhat,
> Right now we are using draw2d for rendering the figures in GEF Editor. But my question is that can we use SVG Images for rendering our images on the GEF Editor.
> Regards
> Deepak Singla
Mickael Istria -- BonitaSoft S.A.
http://www.bonitasoft.com/products/BPM_download.php
Re: Rendering SVG Image in GEF [message #1495817 is a reply to message #649249] Tue, 02 December 2014 09:41 Go to previous message
Hey,
Could you please let me know on how i could bring in the SVG / .JPG figures in my GEF palette? Thanks in advance
Previous Topic:Add a MouseListener to a GraphNode
Next Topic: startup opening editor exception
Current Time: Sun Jul 27 07:59:08 EDT 2025
Powered by FUDForum. Page generated in 0.04777 seconds
