Home » Eclipse Projects » Standard Widget Toolkit (SWT) » "window closing" event?
"window closing" event? [message #649060] Mon, 17 January 2011 08:26 Go to next message
AWT's Window class provides both "windowClosing" and "windowClosed" events. The former is useful when you want to intercept the close and allow a user to cancel. Does the Shell class provide a similar capability? I only saw ShellListener#windowClosed(), but I was wondering if there might be another way to do it.
Greg
Re: "window closing" event? [message #649071 is a reply to message #649060] Mon, 17 January 2011 08:59 Go to previous messageGo to next message
Seems as though I may be able to cancel the windowClosed() event by setting the doit property of the event to false. Is this correct?
Re: "window closing" event? [message #649196 is a reply to message #649071] Tue, 18 January 2011 02:09 Go to previous messageGo to next message
I assume you mean the method shellClosed(). And I agree that this looks
like the right event to use for this.
HTH & Greetings from Bremen,
Daniel Krügler
Re: "window closing" event? [message #649256 is a reply to message #649196] Tue, 18 January 2011 07:26 Go to previous message
Oops, yes - I meant shellClosed(). windowClosed() is the AWT method. Thanks.
Greg
Previous Topic:SWT blocking AWT?
Next Topic:Text Viewer with pagination - the way to go?
Current Time: Sat Jul 26 15:21:38 EDT 2025
Powered by FUDForum. Page generated in 0.09320 seconds
