Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » ChangeCommand Test(How it works, is it in working condition ?)
ChangeCommand Test [message #648556] Thu, 13 January 2011 09:03 Go to next message
http://dev.eclipse.org/newslists/news.eclipse.platform/msg69 415.html
how to run it ?
As facing error at imports ie
import org.eclipse.emf.test.models.ref.E;
import org.eclipse.emf.test.models.ref.RefFactory;
import org.eclipse.emf.test.models.ref.RefPackage;
import org.eclipse.emf.test.models.ref.provider.RefItemProviderAdap terFactory;
How it uses ChangeRecorder internally ?
Re: ChangeCommand Test [message #648640 is a reply to message #648556] Thu, 13 January 2011 13:09 Go to previous messageGo to next message
You could try to install the unit test by extracting them from CVS:
http://wiki.eclipse.org/EMF/Getting_Source
> how to run it ?
> terFactory;
Re: ChangeCommand Test [message #648682 is a reply to message #648640] Thu, 13 January 2011 20:53 Go to previous messageGo to next message
i get errors at import after i have checked out through cvs.
i put in MANIFEST.MF
org.eclipse.emf.test.common;resolution:=optional,
org.eclipse.emf.common,
org.eclipse.emf.edit,
org.eclipse.emf.transaction;resolution:=optional,
org.eclipse.emf.validation;resolution:=optional,
org.eclipse.emf.edit.ui
first one ie test one was red, as fix it suggested to be optional.
where i am going wrong as unable to run ChangeCommand.
Re: ChangeCommand Test [message #648692 is a reply to message #648682] Thu, 13 January 2011 22:33 Go to previous messageGo to next message
I do the same thing but don't get errors. Those tests don't depend on
transaction nor validation.
> terFactory;
Re: ChangeCommand Test [message #648753 is a reply to message #648692] Fri, 14 January 2011 07:25 Go to previous messageGo to next message
i get at the time of import only!!! Sad
Re: ChangeCommand Test [message #648821 is a reply to message #648753] Fri, 14 January 2011 11:25 Go to previous messageGo to next message
Your sentences are short.
tenor wrote:
> i get at the time of import only!!! :(
Re: ChangeCommand Test [message #648856 is a reply to message #648556] Fri, 14 January 2011 13:19 Go to previous messageGo to next message
Right at the checkout level, those imports are having red mark.
I have not run the test yet as unable to run.
Re: ChangeCommand Test [message #648887 is a reply to message #648856] Fri, 14 January 2011 17:44 Go to previous messageGo to next message
What exactly have you all checked out?
PS. Don't expect me to spend more time answering your questions than you
spend asking them.
Re: ChangeCommand Test [message #648969 is a reply to message #648887] Sun, 16 January 2011 17:40 Go to previous messageGo to next message
Merks.Thanks.
These were missing in the check out.
org.eclipse.emf.test.edit
NOW, it runs fine. Smile
But, i want to know
1) Does doing applyAndReverse again and again will result in undo ? but i did two times, and pressed undo button in my app, it resulted as it was!!![ ie using ChangeRecorder]
2) using ChangeCommand vs ChangeRecorder, who scores over and why?
Much Thanks.
Re: ChangeCommand Test [message #648970 is a reply to message #648969] Sun, 16 January 2011 17:52 Go to previous messageGo to next message
Comments below.
tenor wrote:
> Merks.Thanks.
> NOW, it runs fine. :)
> But, i want to know
Calling applyAndReverse applies the changes and reverses the change
description such that calling applyAndReverse a second time will be the
same as not calling it at all. I.e., it helps implement undo and redo.
A ChangeCommand uses a ChangeRecorder to keep track of all changes made
when executing the command. The resulting ChangeDescription is then
used by ChangeCommand to implement undo/redo.
> Much Thanks.
Re: ChangeCommand Test [message #649170 is a reply to message #648970] Mon, 17 January 2011 19:35 Go to previous messageGo to next message
Vide in the book.
Notice that calling applyAndReverse() repeatedly provides a convenient undo/redo capability for a change description.
I was under impression, it can lead me to undo the "Each Step Changes" back to original state, but it does NOT!!
It goes in one shot to original.
So, Merks, my Q is
1) How i can write for before press of OK button, it should call startRecording and on press of OK button, it should call endRecording, and save changes happened in between, to a stack. And if user presses undo , at this point of time, it should revert the change, to last sequential value. if again pressed undo, again till last value from this reverted back value, ie journey back and tracing back.
2)if so, any close example?
Thanks.
Re: ChangeCommand Test [message #649171 is a reply to message #649170] Mon, 17 January 2011 19:47 Go to previous messageGo to next message
Comments below.
tenor wrote:
> Vide in the book.
Yes, call it once is undo, call it twice is redo, call it three times is
undo again...
No, that's what a command stack does.
> So, Merks, my Q is
Are you writing a wizard or dialog? It's best that such a thing make no
changes to the actual model until you press OK. When you press OK, you
should execute a command that makes all the changes.
The problem is if you make changes to the actual objects before pressing
okay, the rest of the editor will see those changes.
> Thanks.
Re: ChangeCommand Test [message #649173 is a reply to message #649171] Mon, 17 January 2011 20:24 Go to previous messageGo to next message
We will have UI with N tabs , each tab having say X fields.
we are not saving to model.
you
Which command i should execute? ChangeCommand? Does it do incremental undo?
Thanks.
Re: ChangeCommand Test [message #649320 is a reply to message #649173] Tue, 18 January 2011 12:49 Go to previous messageGo to next message
Tenor,
Comments below.
> no changes to the actual model until you press OK. When you press OK,
> you should execute a command that makes all the changes.
So how does the OK button fit into the picture.
The data being edited is completely transient?
Whatever works well for you. It sounds like changing individual fields
is just like editing properties in the properties view and can make use
of things like SetCommand
> ChangeCommand?
If that works best.
It will undo whatever is done during execute.
> Thanks.
Re: ChangeCommand Test [message #649352 is a reply to message #649320] Tue, 18 January 2011 16:16 Go to previous messageGo to next message
yes, data is transient.
Based on ChangeCommandTest, i tried to replicate the test but i could not meet any success!!
protected void doExecute() {
service = Proxy.getManagementService();
List<Name> names = service.getAllNames);
for (Name name : namess) {
AggregateKey ak = DomainFactory.eINSTANCE
.createAggregateKey();
ak.setClassifier(mult.eClass().getClassifierID());
ak.setId(EcoreUtil.getID(mult));
resource.getContents().add(mult);
keyList.add(ak);
And then
editingDomain.getCommandStack().execute(changeCommand);
editingDomain.getCommandStack().undo();
How to achieve incremental undo ie at each step like Unit of Work with ChangeCommand?
Re: ChangeCommand Test [message #649365 is a reply to message #649352] Tue, 18 January 2011 16:40 Go to previous messageGo to next message
Comments below.
> keyList.add(ak);
Have you specified suitable notifiers such that all the above changes
will be recorded?
> And then
> ChangeCommand?
Re: ChangeCommand Test [message #649369 is a reply to message #649365] Tue, 18 January 2011 18:02 Go to previous messageGo to next message
Merks,
What are those suitable Notifers as i am unable to find them in ChangeCommandTest.
AND
MOST FUNDAMENTALLY, Can i get undo capability for each of Change? step back , one step at a time?
If so, how to achieve this with ChangeCommand?
Re: ChangeCommand Test [message #649373 is a reply to message #649369] Tue, 18 January 2011 19:02 Go to previous messageGo to next message
Comments below.
tenor wrote:
> Merks,
> ChangeCommandTest.
You'll see that there are three tests that test changes made to an
EObject, a Resource, and a ResourceSet.
> AND
It will undo exactly the things you did during doExecute. If you do
only one thing, it will undo only one thing. If you do many things, it
will undo them all...
Re: ChangeCommand Test [message #649838 is a reply to message #649373] Thu, 20 January 2011 12:38 Go to previous messageGo to next message
1.Do we necessarily have to generate the Editor code if we are going for EMF.edit approach?
Can we mimic redo/undo of EMF.edit without code generation? How i can have EditingDomain and other classes which are generated
out of code generation.
2.And can we use the "org.eclipse.emf.common.command.BasicCommandStack" for redo/undo.
Thanks.
Re: ChangeCommand Test [message #649856 is a reply to message #649838] Thu, 20 January 2011 13:13 Go to previous messageGo to next message
Tenor,
Comments below.
No.
Yes.
Do by hand what you see in the generated editor.
Yes.
> Thanks.
Re: ChangeCommand Test [message #650096 is a reply to message #649856] Fri, 21 January 2011 12:39 Go to previous messageGo to next message
Merks
I have generated editor code.
During debug of redo/undo of library editor code, [i set up break point at setName], i found that this line ie ((BasicCommandStack)editingDomain.getCommandStack()).saveIsD one(); is touched
and then
it goes in the BasicCommandStack.class
As i have to redo/undo on screen(UI) not attached to viewer etc.
I should bind button at UI to
A) DomainEditor.doSave(IProgressMonitor progressMonitor) ie i want to know which piece of code i should bind to?
B)if so, what can be passed as progressMonitor from UI side?
Thanks.
Re: ChangeCommand Test [message #650121 is a reply to message #650096] Fri, 21 January 2011 14:26 Go to previous messageGo to next message
Comments below.
tenor wrote:
> Merks
> touched and then
I really can't make sense out of the above comments. I know you said
you didn't need to persist any data so I'm not sure how save is coming up.
The platform has classes to create a progress monitor. They're not that
hard to find.
> Thanks.
Re: ChangeCommand Test [message #650143 is a reply to message #650121] Fri, 21 January 2011 17:32 Go to previous messageGo to next message
I am NOT saving any of changes, but only till SAVE button is clicked.
Which piece governs the undo/redo in editor code?
I thought
((BasicCommandStack)editingDomain.getCommandStack()).saveIsD one() , as that leads to BasicCommandStack in debug.
Re: ChangeCommand Test [message #650191 is a reply to message #650143] Sat, 22 January 2011 12:51 Go to previous messageGo to next message
You seem to have an endless stream of questions that are starting to
feel a little circular. Surely you've noticed that BasicCommandStack
has undo/redo methods and you're certainly capable of setting a
breakpoint in those methods. In addition, you have a fully functional
editor that supports undo/redo and a feature rich debugger than can help
answer any question you could possibly ask about how it works. Use
those tools and try to ask questions that demonstrate you've done your
own homework first.
> I thought ((BasicCommandStack)editingDomain.getCommandStack()).saveIsD
Re: ChangeCommand Test [message #650398 is a reply to message #650191] Mon, 24 January 2011 12:47 Go to previous messageGo to next message
Dont despair on me.
I am trying to get it right, but miss basics.
I had a look at following generated editor class. ie
LibraryEditor
LibraryActionBarContributor
And
public class LibraryActionBarContributor
extends EditingDomainActionBarContributor
And i notice , that there is following method in the EditingDomainActionBarContributor
protected UndoAction createUndoAction()
return new UndoAction();
Now in UndoAction.class, i set bp here, it breakspoint here
public void run()
domain.getCommandStack().undo();
Further debugging, takes to BasicCommandStack class.
So i need domain, as domain has commandstack.
First set of questions
1. If LibraryEditor.java can be subclassed to provide redo/undo functionality?
2. How to put button there, if LibraryEditor is to do calling for redo/undo ?
And as in the link
http://www.eclipsezone.com/eclipse/forums/t115960.html
the last part ie
Furthermore EMF global undo/redo etc actions are only added to the actual
Actions in eclipse via the ActionHandler mechanism, which is called from
the EditorActionBar.init function or from the shareGlobalActions function
if you are attaching them via a View such as an Outline or PropertySheet.
The shareGlobalActions function is in turn called from setActionBars on
the Page class, which you will have in your View? If you look at how the
generated Editor's ContentOutlinePage and PropertySheetPage handle these
things, you could incorporate this into your code, bearing in mind that
you need to be an EditorPart to use the EMF ActionBarContributor as is.
Second set of Qs
1. Where to hook for redo/undo button, if i have NOTHING to do with Property sheet, as i will have my own view.
So, in this view, if i place a button which bit of piece i should hook to ?
2. As above, EditorPart is MUST ? if so,
menuManager.add(new ActionContributionItem(undoAction)); is one of means to achieve a button on my view?
3. Unrelated to this, in the copy by EMF.edit, does it copy contained references?
Re: ChangeCommand Test [message #650416 is a reply to message #650398] Mon, 24 January 2011 13:38 Go to previous message
Tenor,
Comments below.
tenor wrote:
> Dont despair on me.
I'm not generally a patient person despite appearances to the contrary.
> LibraryEditor
> And
> @Override
> public void run()
> functionality?
It already directly supports it.
> redo/undo ?
There's a menu action in the edit menu. Ho to provide button for the
same thing isn't an EMF question.
> And as in the link http://www.eclipsezone.com/eclipse/forums/t115960.html
> the last part ie
> actual Actions in eclipse via the ActionHandler mechanism, which is
> called from the EditorActionBar.init function or from the
> shareGlobalActions function if you are attaching them via a View such
> as an Outline or PropertySheet. The shareGlobalActions function is in
> turn called from setActionBars on the Page class, which you will have
> in your View? If you look at how the generated Editor's
> ContentOutlinePage and PropertySheetPage handle these things, you
> could incorporate this into your code, bearing in mind that you need
> to be an EditorPart to use the EMF ActionBarContributor as is. Second
> set of Qs
> to ?
You can see that the action just calls undo on the command stack so you
can do the same thing from any button you decide to put anywhere.
No.
> if so, menuManager.add(new ActionContributionItem(undoAction)); is one
Make the button any way you want (it's not an EMF question) and invoke
undo on the command stack (simple).
Yes it does.
Previous Topic:[EEF] Absolute paths in components model
Next Topic:[EEF] RAP Support
Current Time: Sun Jul 27 03:52:48 EDT 2025
Powered by FUDForum. Page generated in 0.08307 seconds
