[Fixed] NPE when using LAZY loading on ManyToOne relationship [message #649113] |
Mon, 17 January 2011 12:55  |
I got the following entities:
@Entity
public class A implements Serializable {
@Id
@GeneratedValue
private long id;
private String value;
public String getValue() {
return value;
public void setValue(String value) {
this.value = value;
public long getId() {
return id;
public void setId(long id) {
this.id = id;
and
@Entity
public class B implements Serializable {
@Id
@GeneratedValue
private long id;
@ManyToOne(fetch = FetchType.LAZY)
private A a;
return id;
this.id = id;
public A getA() {
return a;
public void setA(A a) {
this.a = a;
When I deploy those entities, I got the following error:
Local Exception Stack:
Exception [EclipseLink-60] (Eclipse Persistence Services - 2.1.2.v20101206-r8635): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: The method [_persistence_set_a_vh] or [_persistence_get_a_vh] is not defined in the object [ili.ili4.entities.B].
Internal Exception: java.lang.NoSuchMethodException: ili.ili4.entities.B._persistence_get_a_vh()
Mapping: org.eclipse.persistence.mappings.ManyToOneMapping[a]
Descriptor: RelationalDescriptor(ili.ili4.entities.B --> [DatabaseTable(B)])
at org.eclipse.persistence.exceptions.DescriptorException.noSuchMethodWhileInitializingAttributesInMethodAccessor(DescriptorException.java:1154)
at org.eclipse.persistence.internal.descriptors.MethodAttributeAccessor.initializeAttributes(MethodAttributeAccessor.java:175)
at org.eclipse.persistence.internal.descriptors.MethodAttributeAccessor.initializeAttributes(MethodAttributeAccessor.java:156)
at org.eclipse.persistence.mappings.DatabaseMapping.preInitialize(DatabaseMapping.java:1241)
at org.eclipse.persistence.mappings.ForeignReferenceMapping.preInitialize(ForeignReferenceMapping.java:1004)
at org.eclipse.persistence.mappings.ObjectReferenceMapping.preInitialize(ObjectReferenceMapping.java:925)
at org.eclipse.persistence.descriptors.ClassDescriptor.preInitialize(ClassDescriptor.java:3360)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:429)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:406)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.postConnectDatasource(DatabaseSessionImpl.java:666)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:615)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:228)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:389)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getServerSession(EntityManagerFactoryImpl.java:164)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:221)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:209)
at ili.ili4.tests.ConsultationTest.setUp(ConsultationTest.java:31)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:27)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:76)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Caused by: java.lang.NoSuchMethodException: ili.ili4.entities.B._persistence_get_a_vh()
at java.lang.Class.getDeclaredMethod(Class.java:1937)
at org.eclipse.persistence.internal.security.PrivilegedAccessHelper.findMethod(PrivilegedAccessHelper.java:61)
at org.eclipse.persistence.internal.security.PrivilegedAccessHelper.getMethod(PrivilegedAccessHelper.java:252)
at org.eclipse.persistence.internal.helper.Helper.getDeclaredMethod(Helper.java:1055)
at org.eclipse.persistence.internal.descriptors.MethodAttributeAccessor.initializeAttributes(MethodAttributeAccessor.java:168)
... 38 more
Runtime Exceptions:
at org.eclipse.persistence.internal.security.PrivilegedAccessHelper.getMethodReturnType(PrivilegedAccessHelper.java:326)
at org.eclipse.persistence.internal.descriptors.MethodAttributeAccessor.getGetMethodReturnType(MethodAttributeAccessor.java:112)
at org.eclipse.persistence.mappings.ForeignReferenceMapping.validateBeforeInitialization(ForeignReferenceMapping.java:1709)
at org.eclipse.persistence.descriptors.ClassDescriptor.validateBeforeInitialization(ClassDescriptor.java:5310)
at org.eclipse.persistence.descriptors.ClassDescriptor.preInitialize(ClassDescriptor.java:3366)
I an not sure if it is a bug in EclipseLink or if I made a mistake in my entities declarations.
[Updated on: Thu, 20 January 2011 17:29] by Moderator
FUDForum. Page generated in 0.04612 seconds
