Home » Eclipse Projects » Rich Client Platform (RCP) » Selection Problem after Perspective switching
Selection Problem after Perspective switching [message #649038] Mon, 17 January 2011 06:35 Go to next message
I have defined a View with an TableViewer, who works as
ISelectionProvider, and a Command and Handler for the ViewToolbar.
The View is used in diffrent perspectives (defined inside the
PerspectiveExtensions).
If I select somtehing from the TableViewer and push the CommandIcon my
Handler get (by using HandlerUtil.getCurrentSelection()) the correct
selection.
Now I do switch the perspective, the View has also the focus and I see
the current selection inside the Viewer but if I push the Command again
I get a >null< for the selection.
Why do the ISelection Service don't hold the current selection?
Have somebody a tip how I get this selection back into the SelectionSevice?
Thanks in advance
Heiko
Re: Selection Problem after Perspective switching [message #649054 is a reply to message #649038] Mon, 17 January 2011 07:32 Go to previous messageGo to next message
What version of eclipse are you using? The source provider were
re-worked in 3.6 (Helios). If it fails there, I would open a bug at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Selection Problem after Perspective switching [message #649093 is a reply to message #649054] Mon, 17 January 2011 10:51 Go to previous message
Hi Paul,
thanks for your quick answer.
Yes, I user Eclipse 3.6.1
I have filed a bug -> https://bugs.eclipse.org/bugs/show_bug.cgi?id=334524
Greeting
Heiko
Am 17.01.2011 13:32, schrieb Paul Webster:
> PW
Previous Topic:how to create different sections in Preferences Pages
Next Topic:How to add help to Wizard
Current Time: Sun Jul 27 07:57:42 EDT 2025
Powered by FUDForum. Page generated in 0.04289 seconds
