| Re: serverside OSGi property org.eclipse.equinox.servlet.bridge.enabled [message #64912 is a reply to message #64891] |
Tue, 11 April 2006 23:52  |
Originally posted by: skaegi.sympatico.ca
Hi Jim,
Yes, I agree for the typical use case this setting should not be necessary.
Less config is a good thing.
So, if not explicitly specified in "launch.ini" then
"org.eclipse.equinox.servlet.bridge.enabled" will be set "true" in the
FrameworkLauncher.
Should be available in tonight's build.
-Simon
"Jim D'Anjou" <danjou@us.ibm.com> wrote in message
news:94c780d95406a3aa78abe239120268f4$1@www.eclipse.org...
> We discovered this property and have to explicitly set it to true to
> enable proxy servlets...that took some figuring out.
> set JAVA_OPTS=-Dorg.eclipse.equinox.servlet.bridge.enabled=true
> Is there any reason why the default could not be true if unspecified?
> Thanks...Jim
FUDForum. Page generated in 0.03079 seconds
