Home » Archived » BIRT » dynamic parameter using Internationalization(3 out of 4 dynamic parameters are already setup but 4th having issues)
dynamic parameter using Internationalization [message #648698] Thu, 13 January 2011 23:29 Go to next message
Confused
Working on a bug for a report someone else created that using a dynamic cascading parameter group. Each parameter is using a different dataset to generate lists for the user to pick from. In the datasets there are UNION joins to be able to add "ALL" to the top of the parameter list.
Here's where the problem comes in - the "ALL" is updated to the French word for "ALL" ("Tous") within the dataset preview results for 3 of the 4 datasets. There is a resource file associated to the report, however I'm not seeing anything setup for the parameters or the datasets to have them convert? So I can't see how this is happening? I need to get the 4th parameter setup the same way though.
When I try to modify the property of the parameter and reference the key in the resource file, it updates the parameters display name instead of the value? Does anyone have any ideas what I'm missing? Thanks in advance!!!
Re: dynamic parameter using Internationalization [message #648833 is a reply to message #648698] Fri, 14 January 2011 11:28 Go to previous messageGo to next message
Can you post the report? Does it contain any script?
Jason
> advance!!!
Re: dynamic parameter using Internationalization [message #648870 is a reply to message #648698] Fri, 14 January 2011 14:02 Go to previous message
O
M
G
there was a script, it was doing the following:
this.queryText.replaceFirst("PROMPT_ALL",reportContext.getMessage("All", reportContext.getLocale()));
removing the "First" out of the line was the needed change! THANK YOU!!!!
Previous Topic:How insert date into Tex Box by JavaScript
Next Topic:Re-use of DataCube
Current Time: Wed Jul 23 11:57:51 EDT 2025
Powered by FUDForum. Page generated in 0.03411 seconds
