Home » Archived » BIRT » Set label of marker in a chart
Set label of marker in a chart [message #648738] Fri, 14 January 2011 06:00 Go to next message
I want to change the label of a marker in a chart via script. I use
beforeDrawMarkerLine function (see below). The following (setLabel) does
not work (this error:
Can't find method
org.eclipse.birt.chart.model.component.impl.MarkerLineImpl.s etLabel(string).
at line 19 of chart script:'')
Perhaps anybody can give me a hint. thanks.
function beforeDrawMarkerLine(axis, markerLine, icsc)
importPackage( Packages.org.eclipse.birt.chart.model.data.impl );
var min_value =
icsc.getExternalContext().getScriptable().getPersistentGloba lVariable( "min_val");
markerLine.setValue(NumberDataElementImpl.create(min_value)) ;
markerLine.setLabel("Value: " + min_value);
Re: Set label of marker in a chart [message #648832 is a reply to message #648738] Fri, 14 January 2011 11:27 Go to previous messageGo to next message
Add
importPackage(Packages.org.eclipse.birt.chart.model.componen t.impl)
right above where you calculate the min_value.
Jason
On 1/14/2011 6:00 AM, Klaus Meisl wrote:
> Can't find method
> var min_value =
Re: Set label of marker in a chart [message #648873 is a reply to message #648832] Fri, 14 January 2011 13:34 Go to previous messageGo to next message
Jason,
setting the line works fine, it just does not set the label of the line.
My script now looks like this, but the error remains.
importPackage(Packages.org.eclipse.birt.chart.model.data.imp l);
importPackage(Packages.org.eclipse.birt.chart.model.componen t.impl);
var min_value =
// works fine so far
// this does not work
markerLine.setLabel("This is the line");
Am 14.01.11 17:27, schrieb Jason Weathersby:
> Add
> Jason
>> Hi,
>> Can't find method
>> var min_value =
Re: Set label of marker in a chart [message #649119 is a reply to message #648873] Mon, 17 January 2011 13:32 Go to previous message
Try:
markerLine.getLabel().getCaption().setValue("Test");
On 1/14/2011 1:34 PM, Klaus Meisl wrote:
> Jason,
> var min_value =
>> Add
>> Jason
>>> Hi,
>>> Can't find method
>>> var min_value =
Previous Topic:Multi Value Rows
Next Topic:myeclipse reporting issue
Current Time: Sat Jul 26 07:56:21 EDT 2025
Powered by FUDForum. Page generated in 0.03788 seconds
