Create object on dropping connection to diagram [message #648722] |
Fri, 14 January 2011 04:18  |
the tutorial contains a section about creating connections with drag & drop from anchors. It is mentioned that if several create connection features are exposed as drag and drop features, the user is presented a choice of applicable features on drop.
There is a similar use case where the user drops the connection to the diagram and is presented a choice of possible objects to create. When an object is picked, a new object is created plus the connection is created and connected to the anchor of the new object.
What would be the recommended implementation of this use case? Should I use custom features?
Thanks in advance!
Markus
Re: Create object on dropping connection to diagram [message #649007 is a reply to message #648722] |
Mon, 17 January 2011 03:16  |
Markus,
for the first use case you should use CreateConnectionFeatures and add all
possibilities to one create new connection entry (class
ConnectionCreationToolEntry) in the palette. I haven't tried the second
thing, but that will probable work just the same way.
The general recommendation would be to use the most specific feature type
possible.
Michael
"Markus Muenkel" <ultra_nebula@yahoo.de> wrote in message
news:igp42f$h5$1@news.eclipse.org...
> Hello,
> Thanks in advance!
> Markus
FUDForum. Page generated in 0.03614 seconds
