Home » Archived » BIRT » radius attribute for dials
radius attribute for dials [message #648540] Thu, 13 January 2011 07:58 Go to next message
Originally posted by: anders.hessellund.gmail.com
I've spent a lot of time trying to perfect a BIRT dial for a RCP
application, i.e., using the Java API. One thing that puzzles me is what
the unit of some of the API methods are. Specifically, what is the unit
for the dial radius? Is it points? Or is it some sort of percentage of
the size of the dial?
The API docs are here:
* Returns the value of the '<em><b>Radius</b></em>' attribute.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* <!-- begin-model-doc -->
* Specifies the radius of the dial.
* <!-- end-model-doc -->
* @return the value of the '<em>Radius</em>' attribute.
* @see #isSetRadius()
* @see #unsetRadius()
* @see #setRadius(double)
* @see
org.eclipse.birt.chart.model.component.ComponentPackage#getD ial_Radius()
* @model unsettable="true" dataType="org.eclipse.emf.ecore.xml.type.Double"
* extendedMetaData="kind='element' name='Radius'"
* @generated
double getRadius( );
Anders
Re: radius attribute for dials [message #648637 is a reply to message #648540] Thu, 13 January 2011 12:58 Go to previous message
Anders,
It is in bounds points but its used in a complex equation. From the
DialRenderer class
if ( dRadius > 0
&& ( dRadius + dExtraSpacing + dSafeSpacing * 2 ) < dFullRadius )
dFullRadius = dRadius + dExtraSpacing + dSafeSpacing * 2;
final ArcRenderEvent are = ( (EventObjectCache) idr ).getEventObject(
StructureSource.createUnknown( dialComponent ),
ArcRenderEvent.class );
// Dial full outline
Bounds fullBounds = goFactory.createBounds( boCA.getLeft( )
+ ( boCA.getWidth( ) - 2 * dFullRadius )
/ 2, ( boCA.getTop( ) + ( boCA.getHeight( ) - ( bFullDisc ? 2
: 1 )
* dFullRadius ) / 2 ), 2 * dFullRadius, 2 * dFullRadius );
if ( !bDialSuperimposed || bFirstSeries )
final Fill dialFill = dialComponent.getFill( );
double safeAngle = Math.toDegrees( Math.abs( Math.asin( dSafeSpacing
/ dFullRadius ) ) );
are.setBounds( fullBounds );
are.setStartAngle( bFullDisc ? 0 : -safeAngle );
are.setAngleExtent( bFullDisc ? 360 : ( 180 + 2 * safeAngle ) );
are.setOutline( dialComponent.getLineAttributes( ) );
are.setBackground( dialFill );
are.setStyle( ArcRenderEvent.CLOSED );
idr.fillArc( are );
idr.drawArc( are );
The dRadius value is the one set by you. This value is used to
calculate the full radius of the draw arc and fill arc drawing commands.
Jason
On 1/13/2011 7:58 AM, Anders Hessellund wrote:
> * @see
> * @generated
> Cheers,
> Anders
Previous Topic:Birt Report Viewer content
Next Topic:How insert date into Tex Box by JavaScript
Current Time: Wed Jul 23 06:44:08 EDT 2025
Powered by FUDForum. Page generated in 0.04727 seconds
