Home » Archived » M2M (model-to-model transformation) » [ATL] ATL transformation output(Two issues about ATL transformation output.)
[ATL] ATL transformation output [message #648566] Thu, 13 January 2011 09:40 Go to next message
Hi all,
I would like to ask you a few things about ATL. I'm doing a trasformation and I have some puzzles to solve:
1) In output I get an xml file whose structure is like this:
<?xml version="1.0" encoding="ISO-8859-1"?>
<spmif:DocumentRoot xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:spmif="spmif">
  <project projectName="RequestPatientInfoPages">
  </project>
</spmif:DocumentRoot>
while I would like to have no tags DocumentRoot. The ATL-rule that generates the whole output (ie the first is executed) is:
rule Project {
    from
        i : UML2!UseCase (i.name = thisModule.defaultUseCase)
    to
        o : spmif!DocumentRoot (
    do {
        o.project <- thisModule.Scenarios(i);
        o;
where
is the name of an UML <UseCase> and
Scenarios (i)
is the call to a rule that generates the elements within the project element.
Do you know how to avoid the insertion of the DocumentRoot tag?
2) Consider the following XSD fragment from which the target metamodel derives:
<xs:element name="Node" type="spmif:Node_type"/>
<xs:element name="ProcessingNode" type="spmif:ProcessingNode_type" substitutionGroup="spmif:Node"/>
<xs:element name="BasicNode" type="spmif:BasicNode_type" substitutionGroup="spmif:Node"/>
<xs:element name="LinkNode" type="spmif:LinkNode_type" substitutionGroup="spmif:ProcessingNode"/>
<xs:element name="SynchronizationNode" type="spmif:SynchronizationNode_type" substitutionGroup="spmif:ProcessingNode"/>
<xs:element name="ExpandedNode" type="spmif:ExpandedNode_type" substitutionGroup="spmif:ProcessingNode"/>
<xs:element name="CompoundNode" type="spmif:CompoundNode_type" substitutionGroup="spmif:Node"/>
<xs:element name="RepetitionNode" type="spmif:RepetitionNode_type" substitutionGroup="spmif:CompoundNode"/>
<xs:element name="SplitNode" type="spmif:SplitNode_type" substitutionGroup="spmif:CompoundNode"/>
<xs:element name="PardoNode" type="spmif:PardoNode_type" substitutionGroup="spmif:CompoundNode"/>
<xs:element name="CaseNode" type="spmif:CaseNode_type" substitutionGroup="spmif:CompoundNode"/>
<xs:complexType name="EG_type">
    <xs:sequence>
        <xs:element name="Node" type="spmif:Node_type" maxOccurs="unbounded"/>
        <xs:element name="Arc" type="spmif:Arc_type" minOccurs="0" maxOccurs="unbounded"/>
    </xs:sequence>
    <xs:attribute name="EGname" type="xs:string" use="required"/>
    <xs:attribute name="EGId" type="xs:ID" use="required"/>
    <xs:attribute name="StartNode" type="xs:IDREF" use="required" ecore:reference="spmif:Node_type"/>
    <xs:attribute name="ModificationDateTime" type="xs:dateTime" use="optional"/>
    <xs:attribute name="SWmodelname" type="xs:string" use="optional"/>
    <xs:attribute name="SWdescription" type="xs:string" use="optional"/>
    <xs:attribute name="Deadline" type="spmif:positivefloat" use="optional"/>
</xs:complexType>
As you can see, the complexType EG_type is composed of Node(s) and Arc(s). Node is the most generic and it is "extended" by several other types of elements.
The transformation obtains EG_type(s) that are structurally correct, but the output is not how I would like it was. In fact, each node is inserted as follows:
<node xsi:type="spmif:xxxNodeType" ATTRIBUTES>
</node>
In practice, it inserts a node element, then it sets its type. Instead, I would like it was something like this:
<xxxNode ATTRIBUTES/>
This means I would like the tag on the node was already the name of its type, such as
<BasicNode ATTRIBUTES/>
Do you have any suggestion about this?
That's all, folks. I hope you can help me. If something is not clear, then let me know, so I'll explain it better.
Thank in advance for your time and consideration,
Dave.
Re: [ATL] ATL transformation output [message #648573 is a reply to message #648566] Thu, 13 January 2011 09:55 Go to previous messageGo to next message
This is an EMF question not an ATL one.
ATL delegates to EMF and the corresponding Resources for serialization.
Re: [ATL] ATL transformation output [message #648592 is a reply to message #648566] Thu, 13 January 2011 10:17 Go to previous messageGo to next message
Le 13/01/2011 15:40, Dave a écrit :
> Hi all,
As said Sylvain, the internal structure of the model file is for EMF
(and you manage your model through EMF tools, like ATL)
> </project>
So just generate projects:
> rule Project {
> from
> i : UML2!UseCase
> to
> p : spmif!Scenario (
.... and it is simpler :-)
> derives:
> <xs:sequence>
> </xs:sequence>
> use="optional"/>
> </xs:complexType>
> types of elements.
> </node>
I suppose you have generated your metamodel from the XSD schema using
EMF genmodel for that. It is not a good tool because it only proposes a
flat metamodel with no containment heirarchy, which is a mess...
I had always rewrite my metamodels by hand (using Ecore diagram modeler)
and reading the DSL specifications.
> type, such as
> Dave.
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: [ATL] ATL transformation output [message #648638 is a reply to message #648573] Thu, 13 January 2011 13:23 Go to previous messageGo to next message
Hi Sylvain,
sorry for the mistake.
Dave.
Re: [ATL] ATL transformation output [message #648642 is a reply to message #648592] Thu, 13 January 2011 13:36 Go to previous message
Hi Vincent,
thanks for your reply.
> </project>
> rule Project {
> from
> i : UML2!UseCase
> to
.... and it is simpler Smile
It's not so simple, because Scenario elements are generated by the rule Scenarios, that is called by the rule Project.
So, I would like to generate the Project element (tag in the xml resulting file) without generating DocumentRoot. As I said, Scenarios are correctly generated by the namesake rule.
Conceptually, from an UseCase a Project is generated; for this issue, what is inside Project is not important; what is really important, instead, is the DocumentRoot elimination. I think the problem is in the fact that Project is a child of DocumentRoot.
If I modify the generated meta-model (from the XML-Schema, as you guessed), I think I could resolve this issue and also the second one, but I would like to avoid an excessive modification of what has been generated.
Thanks a lot for your interesting,
Dave.
Previous Topic:[MARTE profile] Stereotypes conceptual mapping
Next Topic:[QVTO] Mapping to an Element Value instead of an Attribute
Current Time: Sat Jul 26 09:01:07 EDT 2025
Powered by FUDForum. Page generated in 0.04102 seconds
