Home » Archived » Buckminster » [Resolved]Problem during meta-data refresh "Profile TARGET_DEFINITION is not current"
icon14.gif  [Resolved]Problem during meta-data refresh "Profile TARGET_DEFINITION is not current" [message #648135] Tue, 11 January 2011 06:50 Go to next message
Hi all.
When I build my rcp application using buckminster, sometimes the error [Problem during meta-data refresh "Profile TARGET_DEFINITION is not current."] is occurred.This error has occurred high frequency.It is maybe once every two times occurred.
The build log is bellow
Started by an SCM change
Checkout:workspace / /var/lib/hudson/jobs/JAM Circle CI/workspace - hudson.remoting.LocalChannel@1ddaf92
Using strategy: Default
Last Built Revision: Revision 560327f9e39263ecad3da8c885c2d471ecd86180 (origin/master)
GitAPI created
Fetching changes from the remote Git repository
Fetching upstream changes from git://github.com/kompiro/jamcircle.git
[workspace] $ /usr/bin/git fetch -t git://github.com/kompiro/jamcircle.git +refs/heads/*:refs/remotes/origin/*
[workspace] $ /usr/bin/git ls-tree HEAD
Seen branch in repository origin/buckminster
Seen branch in repository origin/master
Seen branch in repository origin/local
Seen branch in repository origin/build-test
Commencing build of Revision 4782dd6e37fab2d867771f83771039ab2b9ffcb0 (origin/master)
GitAPI created
Checking out Revision 4782dd6e37fab2d867771f83771039ab2b9ffcb0 (origin/master)
[workspace] $ /usr/bin/git checkout -f 4782dd6e37fab2d867771f83771039ab2b9ffcb0
[workspace] $ /usr/bin/git tag -a -f -m "Hudson Build #145" hudson-JAM_Circle_CI-145
Recording changes in branch origin/master
[workspace] $ /usr/bin/git whatchanged --no-abbrev -M --pretty=raw 560327f9e39263ecad3da8c885c2d471ecd86180..4782dd6e37fab2d867771f83771039ab2b9ffcb0
Starting xvnc
[workspace] $ vncserver :14 -geometry 1024x768 -PasswordFile /var/lib/hudson/vnc.passwd
New 'www12071u:14 (hudson)' desktop is www12071u:14
Starting applications specified in /var/lib/hudson/.vnc/xstartup
Log file is /var/lib/hudson/.vnc/www12071u:14.log
[workspace] $ /bin/sh -xe /tmp/hudson2511215691013036618.sh
+ [ -d buckminster.output ]
+ rm -R buckminster.output
[workspace] $ /usr/lib/jvm/java-6-openjdk/bin/java "-Dbuckminster.output.root=/var/lib/hudson/jobs/JAM Circle CI/workspace/buckminster.output" "-Dbuckminster.temp.root=/var/lib/hudson/jobs/JAM Circle CI/workspace/buckminster.temp" -Xmx448m -jar /var/lib/hudson/tools/Default/buckminster/plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar -application org.eclipse.buckminster.cmdline.headless -data "/var/lib/hudson/jobs/JAM Circle CI/workspace" --loglevel info -S "/var/lib/hudson/jobs/JAM Circle CI/workspace/commands.txt"
INFO:  clean
INFO:  importtargetdefinition '-A' '/var/lib/hudson/jobs/JAM Circle CI/workspace/features/org.kompiro.jamcircle.buckminster-feature/jamcircle.target'
WARN:  Problem during meta-data refresh: Profile TARGET_DEFINITION:resource:/org.kompiro.jamcircle.buckminster-feature/jamcircle.target is not current. Expected timestamp 1294726358064 but was 1294726342786.
java.lang.IllegalStateException: Profile TARGET_DEFINITION:resource:/org.kompiro.jamcircle.buckminster-feature/jamcircle.target is not current. Expected timestamp 1294726358064 but was 1294726342786.
	at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.lockProfile(SimpleProfileRegistry.java:742)
	at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:65)
	at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
	at org.eclipse.pde.internal.core.target.IUBundleContainer.resolveWithSlicer(IUBundleContainer.java:447)
	at org.eclipse.pde.internal.core.target.IUBundleContainer.resolveBundles(IUBundleContainer.java:197)
	at org.eclipse.pde.internal.core.target.AbstractBundleContainer.resolve(AbstractBundleContainer.java:97)
	at org.eclipse.pde.internal.core.target.TargetDefinition.resolve(TargetDefinition.java:239)
	at org.eclipse.buckminster.pde.internal.PDETargetPlatform.doWithActivePlatform(PDETargetPlatform.java:168)
	at org.eclipse.buckminster.pde.internal.PDETargetPlatform.getOS(PDETargetPlatform.java:303)
	at org.eclipse.buckminster.core.RMContext.getGlobalPropertyAdditions(RMContext.java:201)
	at org.eclipse.buckminster.core.RMContext.<init>(RMContext.java:246)
	at org.eclipse.buckminster.core.RMContext.<init>(RMContext.java:242)
	at org.eclipse.buckminster.core.resolver.ResolutionContext.<init>(ResolutionContext.java:52)
	at org.eclipse.buckminster.core.resolver.ResolutionContext.<init>(ResolutionContext.java:47)
	at org.eclipse.buckminster.core.metadata.MetadataSynchronizer.refreshProject(MetadataSynchronizer.java:294)
	at org.eclipse.buckminster.core.metadata.MetadataSynchronizer.workspaceCatchUp(MetadataSynchronizer.java:394)
	at org.eclipse.buckminster.core.metadata.MetadataSynchronizer$WorkspaceCatchUpJob.run(MetadataSynchronizer.java:185)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
WARN:  Problem during meta-data refresh: null
org.eclipse.core.runtime.OperationCanceledException
	at org.eclipse.buckminster.runtime.MonitorUtils.checkedTestCancelStatus(MonitorUtils.java:195)
	at org.eclipse.buckminster.runtime.MonitorUtils.subMonitor(MonitorUtils.java:102)
ERROR: Project refresh on org.kompiro.jamcircle.web-feature failed: null
	at org.eclipse.buckminster.core.metadata.MetadataSynchronizer.refreshProject(MetadataSynchronizer.java:315)
	at org.eclipse.buckminster.core.metadata.MetadataSynchronizer$MetadataRefreshJob.run(MetadataSynchronizer.java:126)
java.lang.IllegalStateException: Profile TARGET_DEFINITION:resource:/org.kompiro.jamcircle.buckminster-feature/jamcircle.target is not current. Expected timestamp 1294726374225 but was 1294726364270.
Terminating xvnc.
$ vncserver -kill :14
Killing Xvnc4 process ID 28567
Recording test results
Finished: FAILURE
The target environment's information are:
Eclipse 3.6.1
GEF
SWTBot
Babel
Jetty
and using target file to specify target environment
The build environment's information are:
OS: Ubuntu Linux 10.04
Java: OpenJDK 1.6.0_20-b20
Hudson: 1.392
Hudson's Plugin
Buckminster 1.0.5
Hudson disk-usage plugin 0.1.2
Git Plugin 1.1.3
Hudson JavaNCSS plugin 1.0
JobConfigHistory Plugin 1.5
Maven 2 Project Plugin 1.392
SCP plugin 1.7
Hudson SSH Slaves plugin 0.14
Subversion Plugin 1.20
Twitter plugin 0.6
Hudson Xvnc plugin 1.10
Does someone has any information about it?
[Updated on: Mon, 17 January 2011 22:48] by Moderator
Re: Problem during meta-data refresh "Profile TARGET_DEFINITION is not current" [message #648156 is a reply to message #648135] Tue, 11 January 2011 09:16 Go to previous messageGo to next message
I'm not sure if this is related to your problem, but if you are using Hudson then the clocks on the Hudson build master, slave (if the build occurs on a slave), and the subversion server MUST all be synchronised (i.e. you should be using NTP), otherwise you get weird errors.
You're using Git rather than subversion, but given there's some kind of timestamp mismatch, I suggest checking the clocks of all machines involved.
Matthew
Re: Problem during meta-data refresh "Profile TARGET_DEFINITION is not current" [message #648324 is a reply to message #648156] Wed, 12 January 2011 07:43 Go to previous messageGo to next message
Thank you for replying.
But the problem is still occurred when I set the daily cron to run ntpdate yesterday...
Re: Problem during meta-data refresh "Profile TARGET_DEFINITION is not current" [message #648509 is a reply to message #648324] Thu, 13 January 2011 05:26 Go to previous messageGo to next message
I don't really know what the message is trying to tell you, but here are a few thoughts:
* check that the clocks are synchronized, don't just assume they are
* change the loglevel from INFO to DEBUG
* issue a listtargetdefinitions before the importtargetdefinition
* what happens if you pause for a few seconds after the clean? I wonder if some prior thread has not completed properly before the import starts, and that is confusing things.
Sorry I can't be of more help, I'm new to Buckminster myself.
Matthew
Re: Problem during meta-data refresh "Profile TARGET_DEFINITION is not current" [message #648977 is a reply to message #648509] Sun, 16 January 2011 22:18 Go to previous message
Thank you, Matthew.
It seems to solve the problem on my build server.
I added to run listtargetdefinitions before importtargetdefinition.
The server needs to sleep I think.
Previous Topic:Can the component name in a CQUERY be overridden?
Next Topic:Cannot Generate RCP for macosx (solved)
Current Time: Sat Jul 19 03:57:46 EDT 2025
Powered by FUDForum. Page generated in 0.06953 seconds
