Home » Eclipse Projects » JFace » [DataBinding] add non-model intermediary elements with ObservableListTreeContentProvider
[DataBinding] add non-model intermediary elements with ObservableListTreeContentProvider [message #648350] Wed, 12 January 2011 09:23 Go to next message
Originally posted by: matthias.koester.numberfour.eu
I'm using ObservableListTreeContentProvider to create a tree view for an
EMF based model. Everything works fine, I especially like the EMF edit
integration. Now I want to group my object eContents based on their
feature. So currently my tree looks like:
Car
+Engine
+Tire
+Tire
Engine belongs to the feature engine and both Tire objects belong to the
tires feature. I want to display them as:
Car
+engine
+Engine
+tires
+Tire
+Tire
How can I achive sth. like that? Via a DelegatingListProperty? Does an
example exist for this use case?
Matthias
Re: [DataBinding] add non-model intermediary elements with ObservableListTreeContentProvider [message #648352 is a reply to message #648350] Wed, 12 January 2011 09:49 Go to previous messageGo to next message
You can take a look at my e4 model editor who adds such virtual nodes.
There are 2 tricks I'm using to make it work:
a) I create virtual elements named VirtualEntry who them selves simply
wrap an IObservableList in my IObservableFactory
b) The IObservableSet I use to create IObservableMap is not the one I
retrieve from IObservableTreeContentProvider#getKnownElements() but
one that is cleared from the VirtualEntry instances
The code is in:
/cvsroot/eclipse/e4/org.eclipse.e4.tools/bundles/org.eclipse .e4.tools.emf.ui
Tom
Am 12.01.11 15:23, schrieb Matthias Köster:
> Car
> +Engine
> +Tire
> +Tire
> Car
> +engine
> +Engine
> +tires
> +Tire
> +Tire
> Regards,
> Matthias
Re: [DataBinding] add non-model intermediary elements with ObservableListTreeContentProvider [message #648507 is a reply to message #648352] Thu, 13 January 2011 05:12 Go to previous message
Hi Tom,
Thanks for your hint, I already had a similar idea on my mind when I
wrote my post. But your example really helped, thx a lot!
Now I "just" need to hook up commands for adding and removing feature.
And copy & Paste.
Matthias
Am 12.01.11 15:49, schrieb Tom Schindl:
> The code is in:
> Tom
>> Hi,
>> Car
>> +Engine
>> +Tire
>> +Tire
>> Car
>> +engine
>> +Engine
>> +tires
>> +Tire
>> +Tire
>> Regards,
>> Matthias
Previous Topic:TitleAreaDialog using databinding validation to disable the OK button
Next Topic:[DataBinding] ComboViewer binding Items and Text in Master/Detail
Current Time: Wed Jul 23 18:19:22 EDT 2025
Powered by FUDForum. Page generated in 0.04683 seconds
