Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SashForm children width
SashForm children width [message #648333] Wed, 12 January 2011 08:37 Go to next message
I've got an horizontal SashForm with two children. The one on the left should always be, at least, 200 pixels width.
I've disallowed dragging the sash below 200px, but the problem comes when the shell is resized. I've added a ControlListener to the left component. In its controlResized event I check the component width. When it's smaller than 200, I set its bounds' width to 200. It apparently works as the component gets resized to that width, but the sashform stops working - the sash is no longer visible, it remains under the component.
Does anybody know what am I missing?
Thanks in advance
Re: SashForm children width [message #648498 is a reply to message #648333] Thu, 13 January 2011 04:16 Go to previous messageGo to next message
SashForm manages the position and size of its children automatically based on the weights you set.
I think the problem you are seeing may be because you are trying to set the bounds of the components directly. Instead you could recompute and reset the weights in the controlResized event.
The example in this thread may be useful --> http://www.eclipse.org/forums/index.php?t=msg&th=198780& amp; amp;start=0&S=3348500362cdfe2a528b4cce8c01f18f
HTH,
Lakshmi
[Updated on: Thu, 13 January 2011 04:17] by Moderator
Re: SashForm children width [message #648537 is a reply to message #648333] Thu, 13 January 2011 08:00 Go to previous messageGo to next message
Thanks for your reply, Lakshmi
I preferred not to touch weights, because I would like the sashform to maintain the original user aspect ratio if he enlarged the window again, so the components looked the same as before. But anyway, I gave it a try without success. Here's my fragment using your snippet:
leftComponent.addControlListener(new ControlAdapter() {
	public void controlResized(ControlEvent event) {
		if (leftComponent.getBounds().width < 200) {
			int totalWidth = sashForm.getClientArea().width;
			sashForm.setWeights(new int[] {200, totalWidth - 200});
But the effect is the same: no visible sash. What's wrong with my code?
Re: SashForm children width [message #649067 is a reply to message #648537] Mon, 17 January 2011 08:37 Go to previous messageGo to next message
Which platform are you using? Can you paste an example snippet showing your problem?
Re: SashForm children width [message #649987 is a reply to message #648333] Fri, 21 January 2011 05:07 Go to previous messageGo to next message
I'm using Linux/GTK, although this should work on other platforms (win32 and macosx). Here's the snippet:
public class SashExample {
		final int MIN_SIZE = 150;
		Display display = new Display();
		Shell shell = new Shell(display);
		shell.setLayout(new FillLayout());
		final SashForm sashForm = new SashForm(shell, SWT.NONE);
		final Composite left = new Composite(sashForm, SWT.BORDER);
		final Composite right = new Composite(sashForm, SWT.BORDER);
		left.setLayout(new RowLayout());
		right.setLayout(new RowLayout());
		new Label(left, SWT.NONE).setText("Left side");
		new Label(right, SWT.NONE).setText("Right side");
		left.addControlListener(new ControlAdapter() {
				if (left.getBounds().width < MIN_SIZE) {
					sashForm.setWeights(new int[] {MIN_SIZE, totalWidth - MIN_SIZE});
		sashForm.setWeights(new int [] {1, 3});
		shell.setSize(1000, 600);
		shell.open();
		while (!shell.isDisposed()) {
			if (!display.readAndDispatch()) {
				display.sleep();
		display.dispose();
Thanks!
Re: SashForm children width [message #650018 is a reply to message #649987] Fri, 21 January 2011 08:33 Go to previous message
The same workaround/fix suggested in the other thread ( http://www.eclipse.org/forums/index.php?t=msg&th=198780& amp;start=0&S=3348500362cdfe2a528b4cce8c01f18f) should work for your example too.
Call sashform.layout() inside display.asyncExec() after resetting the weights in the control listener.
Previous Topic:Hyperlinks in tree node text?
Next Topic:Accelerator key for a widget placed before a label?
Current Time: Wed Jul 23 02:42:20 EDT 2025
Powered by FUDForum. Page generated in 0.30575 seconds
