Regressions with Graphiti 0.8.0M4 and GEF 3.7 [message #647887] |
Mon, 10 January 2011 05:32  |
I noticed two issues while testing the last milestone of Graphiti
(0.8.0M4 from the CVS) against GEF 3.7.
- The zoom animation does not work anymore when a graphic object is
selected. You can observe this behavior using the tutorial sample.
- With a zoom level different than 100%, it is difficult to create a
shape of an expected area (seems to not match the zoom level). Using the
tutorial sample:
* Set a zoom level of 1000%
* Click on a UMLClass in the palette.
* Mouse down and drag operation in the diagram.
* Drop, the object has not the expected size.
There have been refactorings done in GEF (impacting the CreationTool),
which can explain such issue.
Romain
Re: Regressions with Graphiti 0.8.0M4 and GEF 3.7 [message #648504 is a reply to message #648269] |
Thu, 13 January 2011 04:47  |
Hello Michael,
Here is the bugzilla for the zoom animation issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=334233
Romain
Le 12/01/2011 09:36, Michael Wenz a écrit :
> I had another closer look into issue 1 (zoom animation with selected object)
> and found that i probably mixed up my installations and targetd yesterday
> It works with Graphiti 0.7.0 running against GEF 3.6, but it does not work
> correctly with the head version also running against GEF 3.6. So there
> indeed is a regression. Could you please open a bugzilla to track that?
> The other issue I still can't reproduce using the tutorial.
> Michael
> "Romain Raugi"<romain.raugi@fr.ibm.com> wrote in message
> news:igemse$biu$1@news.eclipse.org...
>> Hi,
>> I noticed two issues while testing the last milestone of Graphiti (0.8.0M4
>> - With a zoom level different than 100%, it is difficult to create a shape
>> tutorial sample:
>> Thanks,
>> Romain
FUDForum. Page generated in 0.07055 seconds
