Problem Running Greenpages under STS/Eclipse [message #647613] |
Fri, 07 January 2011 06:05  |
I am having problems running Greenpages under STS.
I have successfully build and run Greenpages from the command line. I then deleted the .par file from Virgo, and tried to run it via STS. Here is part of the error log:
[2011-01-07 12:00:13.624] TCP Connection(2)-127.0.0.1 <ME0003I> Dump 'serviceability/dump/2011-01-07-12-00-077' generated
[2011-01-07 12:00:13.629] TCP Connection(2)-127.0.0.1 <DE0002E> Installation of par 'greenpages-solution' version '0.0.0' failed. java.lang.UnsupportedOperationException: Cannot open an input stream for '/opt/java/OSGi/virgo-web-server-2.1.0.RELEASE/work/org.ecli pse.virgo.kernel.deployer_2.1.0.RELEASE/staging/greenpages-s olution-0/bundle/greenpages-solution-0-greenpages.db-solutio n/0.0.0/greenpages.db-solution.jar/META-INF/MANIFEST.MF' as it does not exist
at org.eclipse.virgo.kernel.artifact.fs.internal.FileArtifactFS Entry.getInputStream(FileArtifactFSEntry.java:59)
at org.eclipse.virgo.kernel.install.artifact.internal.ServiceSc oper.loadManifest(ServiceScoper.java:186)
at org.eclipse.virgo.kernel.install.artifact.internal.ServiceSc oper.loadBundleManifests(ServiceScoper.java:175)
at org.eclipse.virgo.kernel.install.artifact.internal.ServiceSc oper.doScope(ServiceScoper.java:156)
at org.eclipse.virgo.kernel.install.artifact.internal.ServiceSc oper.scope(ServiceScoper.java:88)
at org.eclipse.virgo.kernel.install.artifact.internal.PlanScope r.scope(PlanScoper.java:137)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardP lanInstallArtifact.scope(StandardPlanInstallArtifact.java:17 5)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.in ternal.ScopingTransformer.processScopedPlanInstallArtifact(S copingTransformer.java:50)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.in ternal.ScopedPlanIdentifyingTreeVisitor.visit(ScopedPlanIden tifyingTreeVisitor.java:32)
at org.eclipse.virgo.util.common.ThreadSafeArrayListTree.visit( ThreadSafeArrayListTree.java:165)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.in ternal.ScopingTransformer.transform(ScopingTransformer.java: 41)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.in ternal.TransformationStage.doProcessTree(TransformationStage .java:55)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipe lineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardP ipeline.doProcessTree(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.Compensat ingPipeline.doProcessTree(CompensatingPipeline.java:72)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApp licationDeployer.driveInstallPipeline(PipelinedApplicationDe ployer.java:271)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApp licationDeployer.doInstall(PipelinedApplicationDeployer.java :151)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApp licationDeployer.install(PipelinedApplicationDeployer.java:1 23)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApp licationDeployer.deploy(PipelinedApplicationDeployer.java:19 0)
at org.eclipse.virgo.kernel.deployer.management.StandardDeploye r.deploy(StandardDeployer.java:52)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:613)
at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenRetur n(ConvertingMethod.java:192)
at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenRetur n(ConvertingMethod.java:174)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIn trospector.java:117)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIn trospector.java:54)
at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntro spector.java:235)
at com.sun.jmx.mbeanserver.PerInterface.invoke(PerInterface.jav a:138)
at com.sun.jmx.mbeanserver.MBeanSupport.invoke(MBeanSupport.jav a:250)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke (DefaultMBeanServerInterceptor.java:819)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer .java:791)
at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RM IConnectionImpl.java:1447)
at javax.management.remote.rmi.RMIConnectionImpl.access$200(RMI ConnectionImpl.java:89)
at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOper ation.run(RMIConnectionImpl.java:1292)
at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOp eration(RMIConnectionImpl.java:1380)
at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConn ectionImpl.java:812)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.ja va:322)
at sun.rmi.transport.Transport$1.run(Transport.java:177)
at sun.rmi.transport.Transport$1.run(Transport.java:174)
at sun.rmi.transport.Transport.serviceCall(Transport.java:173)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTranspo rt.java:553)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TC PTransport.java:808)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCP Transport.java:667)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPool Executor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:603)
at java.lang.Thread.run(Thread.java:732)
[2011-01-07 12:00:13.633] TCP Connection(2)-127.0.0.1 <DE0003E> Install failed for bundle 'greenpages.web-solution' version '0.0.0'.
[2011-01-07 12:00:13.636] TCP Connection(2)-127.0.0.1 <DE0003E> Install failed for bundle 'greenpages-solution-0-greenpages.app-solution' version '0.0.0'.
[2011-01-07 12:00:13.638] TCP Connection(2)-127.0.0.1 <DE0003E> Install failed for bundle 'greenpages-solution-0-greenpages.jpa-solution' version '0.0.0'.
[2011-01-07 12:00:13.640] TCP Connection(2)-127.0.0.1 <DE0003E> Install failed for bundle 'greenpages-solution-0-greenpages.db-solution' version '0.0.0'.
[2011-01-07 12:00:13.642] TCP Connection(2)-127.0.0.1 <DE0003E> Install failed for par 'greenpages-solution' version '0.0.0'.
[2011-01-07 12:00:13.646] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.virgo.apps.admin-2.1.0.RELEASE.plan' is already deployed.
[2011-01-07 12:00:13.648] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE.par'.
[2011-01-07 12:00:13.650] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE.par' is already deployed.
[2011-01-07 12:00:13.655] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.splash-2.1.0.RELEASE.war'.
[2011-01-07 12:00:13.661] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.virgo.apps.splash-2.1.0.RELEASE.war' is already deployed.
I have noticed that there is a directory structure under /stage directory of the Virgo web server:
stage/
|-- greenpages-solution.par
| |-- greenpages.app-solution.jar
| | |-- greenpages
| | | `-- internal
| | `-- META-INF
| | `-- spring
| |-- greenpages.db-solution.jar
| | `-- META-INF
| | `-- spring
| |-- greenpages.jpa-solution.jar
| | |-- greenpages
| | | `-- jpa
| | `-- META-INF
| | `-- spring
| |-- greenpages.web-solution.war
| | |-- images
| | |-- META-INF
| | |-- styles
| | `-- WEB-INF
| | |-- classes
| | | |-- greenpages
| | | | `-- web
| | | `-- META-INF
| | | `-- spring
| | |-- ftl
| | `-- lib
| `-- META-INF
`-- org.eclipse.virgo.repository.properties
but as you can see, there are no files. Has anyone else had this problem and/or a possible solution?
I am running Eclipse 3.6.1 64 bit/STS 2.5.1 with Virgo 2.1.0.RELEASE and Maven 3.0.1 under Linux (Ubuntu 10.10 AMD 64).
Mike
FUDForum. Page generated in 0.07080 seconds
