Getting Java (DynWeb) Build Path to work correctly [message #647401] |
Wed, 05 January 2011 20:35  |
Regarding the build path for a Java ( Dynamic Web Project )
What's the difference between ext jar and jar in WEB-INF/lib ?
I assumed (and had previously running apps) based on a build path that included external jars. ( not in WEB-INF/lib )
After getting a ClassNotFoundException,
I moved the jar into WEB-INF/lib and included it from there, and was able to get past the error.
The issue came up while I was working on a Spring MVC tutorial app. Can someone clarify ?
Re: Getting Java (DynWeb) Build Path to work correctly [message #647987 is a reply to message #647402] |
Mon, 10 January 2011 12:14  |
I just went through this process myself. While I may not be the best source on this, as I am still learning how to use Eclipse/Tomcat, if this is off base, I suspect the corrections will flow
My application has 2 projects A and B. A has some higher level Java model classes, needing several jars. I set this up as a Java project, with a lib folder. To get proper compilation, I needed to specify the jars via the prefs|JBP|library "external jars" option, as the other options seemed inappropriate.
Project B has java and jsp classes, so I set this up as a DynamicWebProject. In the JavaBuildPath, I specified A as required. I then needed to specify project A's jars and source as exportable, so that B could use them.
I initially used this same external jars approach for project B's jars under WEB-INF/lib. However, at some point I noticed that these jars were already specified (in prefs | JBP|libraries WebApp libraries) so I removed the external jars references. So it appears that Eclipse will automatically find the WEB-INF/lib jars, at least in a DynamicWebProject.
Also these Export options seem to be for compilation only, Deploying has a separate process. When I build the .war file (File|export|web|War file), I needed to specify the prefs|DeployAssembly options: A needed src, and the jars in its lib file; B needed jsp path, and A jar
FUDForum. Page generated in 0.03857 seconds
