Home » Archived » Buckminster » Missing CSpec source required by component type osgi.bundle(can't get the project to materialize )
Missing CSpec source required by component type osgi.bundle [message #647716] Fri, 07 January 2011 19:05 Go to next message
I am following the tutorial http://www.ralfebert.de/blog/eclipsercp/rcp_builds I got the code to build inside of Eclipse. Now I'm trying to get it to run on disk. ( I eventually will get it building in a CI system, not Hudson). So I exported the code to a disk location.
Here is my cquery:
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="site.rmap">
<cq:rootRequest name="com.example.mail.site" componentType="osgi.bundle"/>
</cq:componentQuery>
and my rmap:
<rmap xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0" xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
xmlns:pp="http://www.eclipse.org/buckminster/PDEMapProvider-1.0">
<searchPath name="resources">
<provider readerType="local" componentTypes="osgi.bundle,eclipse.feature"
mutable="true" source="true">
<uri format="file:{0}/{1}">
<bc:propertyRef key="workspace.root" />
<bc:propertyRef key="buckminster.component" />
</uri>
</provider>
</searchPath>
<locator searchPathRef="resources" />
</rmap>
here is my script file I pass to Buckminster:
clean
importtargetdefinition -A com.example.mail.site/rcp.target
import --continueonerror com.example.mail.site/site.cquery
build
I run Buckminster in the parent directory of all of the plugins/features. Here is what I get when I run Buckminster:
~/wip/mail$ ../buckminster/buckminster --loglevel INFO --scriptfile mail.buckminster.commands -data buckWs
INFO: clean
INFO: importtargetdefinition '-A' 'com.example.mail.site/rcp.target'
INFO: import '--continueonerror' 'com.example.mail.site/site.cquery'
ERROR [0001] : No suitable provider for component com.example.mail.site:osgi.bundle was found in resourceMap file:/usr/local/google/home/mrrussell/wip/mail/com.example.m ail.site/site.rmap
ERROR [0001] : No suitable provider for component com.example.mail.site:osgi.bundle was found in searchPath resources
ERROR [0001] : Resolution attempt ended with exception: Provider local(file:/usr/local/google/home/mrrussell/wip/mail/buckWs/ com.example.mail.site): Missing CSpec source required by component type osgi.bundle
ERROR Provider local(file:/usr/local/google/home/mrrussell/wip/mail/buckWs/ com.example.mail.site): Missing CSpec source required by component type osgi.bundle
INFO: TAG-ID 0001 = Query for com.example.mail.site:osgi.bundle
ERROR [0000] : Attempt to use an unresolved node. Request is com.example.mail.site:osgi.bundle
ERROR: Errors and Warnings
org.eclipse.core.runtime.CoreException: Errors and Warnings
at org.eclipse.buckminster.runtime.BuckminsterException.wrap(Bu ckminsterException.java:96)
at org.eclipse.buckminster.core.materializer.MaterializationJob .internalRun(MaterializationJob.java:149)
at org.eclipse.buckminster.core.materializer.MaterializationJob .run(MaterializationJob.java:125)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Contains: [0000] : Attempt to use an unresolved node. Request is com.example.mail.site:osgi.bundle
I'm trying to prove to some of my coworkers we should move to buckminster. I have to show them something on Monday so any help would be appreciated.
Thanks in Advance for all of the help.
Re: Missing CSpec source required by component type osgi.bundle [message #647723 is a reply to message #647716] Sat, 08 January 2011 01:28 Go to previous messageGo to next message
Hi Mark,
You get the message:
" local(file:/usr/local/google/home/mrrussell/wip/mail/buckWs/ com.example.mail.site): Missing CSpec source required by
component type osgi.bundle"
This means two things:
1. Buckminster is looking for an OSGi bundle that is named com.example.mail.site. Is that really a bundle? Perhaps your
CQUERY should be changed to query for a feature?
2. Buckminster does find the folder, but once there, it cannot locate what it needs in order to make sense of the bundle
it was expected to find. I.e. there's no META-INF/MANIFEST.MF in the buckWS/com.example.mail.site folder.
HTH,
- thomas
> Here is my cquery:
> and my rmap:
> </uri>
> </provider>
> </searchPath>
> </rmap>
> clean
> importtargetdefinition -A com.example.mail.site/rcp.target import --continueonerror com.example.mail.site/site.cquery
> build
> ~/wip/mail$ ../buckminster/buckminster --loglevel INFO --scriptfile mail.buckminster.commands -data buckWs INFO: clean
Re: Missing CSpec source required by component type osgi.bundle [message #647846 is a reply to message #647723] Sun, 09 January 2011 19:54 Go to previous messageGo to next message
Thomas, thanks for getting back to me. You are correct com.example.mail.site was a feature so I changed the CQUERY to be an eclipse feature.
it now looks like this:
<cq:rootRequest name="com.example.mail.site" componentType="eclipse.feature"/>
here is a directory listing of com.example.mail.site:
drwxr-x--- 2 mrrussell eng 4096 Jan 9 15:26 ./
drwxr-x--- 6 mrrussell eng 4096 Jan 9 15:32 ../
-rw-r----- 1 mrrussell eng 376 Jan 9 15:26 .project
-rw-r----- 1 mrrussell eng 301 Jan 9 15:26 buckminster.properties
-rw-r----- 1 mrrussell eng 27 Jan 9 15:26 build.properties
-rw-r----- 1 mrrussell eng 590 Jan 9 15:26 feature.xml
-rw-r----- 1 mrrussell eng 503 Jan 9 15:26 rcp.target
-rw-r----- 1 mrrussell eng 244 Jan 9 15:26 site.cquery
-rw-r----- 1 mrrussell eng 718 Jan 9 15:26 site.rmap
Platform install location: /usr/local/google/home/mrrussell/wip/buckminster
Target platform provided by class org.eclipse.buckminster.pde.internal.PDETargetPlatform
com.example.mail.site:eclipse.feature: Using resolver rmap
com.example.mail.site:eclipse.feature: Using resolver Local resolver
com.example.mail.site:eclipse.feature: Trying provider local(materialized)
No materialization found for com.example.mail.site:eclipse.feature
com.example.mail.site:eclipse.feature: Trying provider local(workspace)
No open workspace project found that corresponds to com.example.mail.site:eclipse.feature
com.example.mail.site:eclipse.feature: Trying provider local(target)
com.example.mail.site:eclipse.feature: Rejecting provider eclipse.platform(feature/com.example.mail.site): No component match was found
com.example.mail.site:eclipse.feature: Using resource map file:/usr/local/google/home/mrrussell/wip/mail/com.example.m ail.site/site.rmap
com.example.mail.site:eclipse.feature: Using search path resources
com.example.mail.site:eclipse.feature: Trying provider local(file:{0}/{1}[file:/usr/local/google/home/mrrussell/wip /mail/buckWs/com.example.mail.site])
com.example.mail.site:eclipse.feature: Found match
com.example.mail.site:eclipse.feature: Using provider local(file:{0}/{1}[file:/usr/local/google/home/mrrussell/wip /mail/buckWs/com.example.mail.site])
com.example.mail.site:eclipse.feature: Resolution attempt ended with exception: Provider local(file:/usr/local/google/home/mrrussell/wip/mail/buckWs/ com.example.mail.site): Missing CSpec source required by component type eclipse.feature
com.example.mail.site:eclipse.feature: No provider was found that could resolve the request
ERROR [0001] : No suitable provider for component com.example.mail.site:eclipse.feature was found in resourceMap file:/usr/local/google/home/mrrussell/wip/mail/com.example.m ail.site/site.rmap
ERROR [0001] : No suitable provider for component com.example.mail.site:eclipse.feature was found in searchPath resources
ERROR [0001] : Resolution attempt ended with exception: Provider local(file:/usr/local/google/home/mrrussell/wip/mail/buckWs/ com.example.mail.site): Missing CSpec source required by component type eclipse.feature
ERROR Provider local(file:/usr/local/google/home/mrrussell/wip/mail/buckWs/ com.example.mail.site): Missing CSpec source required by component type eclipse.feature
INFO: TAG-ID 0001 = Query for com.example.mail.site:eclipse.feature
ERROR [0000] : Attempt to use an unresolved node. Request is com.example.mail.site:eclipse.feature
Contains: [0000] : Attempt to use an unresolved node. Request is com.example.mail.site:eclipse.feature
It looks like com.example.mail.site is a feature and has the correct meta data to be a feature. But I can not get Buckminster to build it. I know I'm doing something wrong I just can't see it.
Thanks again
Mark R Russell
Google
Re: Missing CSpec source required by component type osgi.bundle [message #647856 is a reply to message #647846] Mon, 10 January 2011 02:08 Go to previous messageGo to next message
The only things I can think of is that you either have a corrupt feature.xml or build.properties. Does the feature.xml
contain a feature with another name than 'com.example.mail.site'? Does Buckminster have read permissions?
- thomas
> an eclipse feature.
> match was found
> ail.site/site.rmap
> com.example.mail.site:eclipse.feature: Found match com.example.mail.site:eclipse.feature: Using provider
> Thanks again
> Mark R Russell
> Google
Re: Missing CSpec source required by component type osgi.bundle [message #649757 is a reply to message #647856] Thu, 20 January 2011 09:32 Go to previous messageGo to next message
Sorry it took so long to get back. I've been burried in work for the past few weeks.
here is the feature.xml:
~/wip/mail$ cat com.example.mail.site/feature.xml
<feature
id="com.example.mail.site"
label="Site"
version="1.0.0.qualifier"
provider-name="EXAMPLE">
<description>
Mail Sample
</description>
<copyright url="http://google.com/copyright">
Copyright 2011
</copyright>
<license>
EPL
</license>
<includes
id="com.example.mail.feature"
version="0.0.0"/>
</feature>
it looks correct to me.
all files have read permission by me who is running Buckminster. Is there any way to turn on some tracing to see what is going on?
Re: Missing CSpec source required by component type osgi.bundle [message #649893 is a reply to message #647846] Thu, 20 January 2011 16:24 Go to previous messageGo to next message
> ail.site/site.rmap
> exception: Provider
> eclipse.feature
> resolve the request
> ail.site/site.rmap
> eclipse.feature
> ERROR Provider
> eclipse.feature
Hi Mark,
your feature 'com.example.mail.site' seems to be located at
'/usr/local/google/home/mrrussell/wip/mail/com.example.mail. site' but
the provider in your RMap does direct to
'/usr/local/google/home/mrrussell/wip/mail/buckWs/
com.example.mail.site'. So am I right if I say that there is no
'com.example.mail.site' feature in you 'buckWS' Workspace directory? If
that's the case you may move the 'com.example.mail.site' folder into
the 'buckWs'. Or you have to change your RMap.
Maybe I was able to help...
- Matthias
Re: Missing CSpec source required by component type osgi.bundle [message #649914 is a reply to message #649893] Thu, 20 January 2011 18:16 Go to previous message
Matthias:
thanks for pointing that out to me. I don't know how many hours I looked at that and still missed it. Thanks for a second set of eyes. It works now.
-Mark
[Updated on: Thu, 20 January 2011 18:17] by Moderator
Previous Topic:RMAP issue with prebuilt plugins (attempt 2)
Next Topic:Product installed with optional bundles not included in any of its features
Current Time: Sun Aug 31 14:04:30 EDT 2025
Powered by FUDForum. Page generated in 0.15040 seconds
