Home » Eclipse Projects » Remote Application Platform (RAP) » Profiling RAP Application
Profiling RAP Application [message #647520] Thu, 06 January 2011 13:39 Go to next message
I'm using VisualVM to monitor and profile a RAP application and I've noticed that some instances from the classes of the application are not garbage collected once the rap application and the client's browser have been closed.
For example the classes that extend from ActionBarAdvisor, WorkbenchAdvisor, WorkbenchWindowAdvisor are some of these instances.
Does these instances suppose to be alive once the application has been closed?
If not, is there a way to release them so they can be garbage collected?
[Updated on: Thu, 06 January 2011 14:03] by Moderator
Re: Profiling RAP Application [message #647662 is a reply to message #647520] Fri, 07 January 2011 11:33 Go to previous messageGo to next message
Any ideas?
Re: Profiling RAP Application [message #647675 is a reply to message #647520] Fri, 07 January 2011 12:25 Go to previous messageGo to next message
what is the session timeout you are using? I would expect some things to
stick around until the session times out.
Elias.
On 1/6/2011 10:39, Jesus Luna Quiroga wrote:
> Hi, I'm using VisualVM to monitor and profile a RAP application and I've
> been closed.
> closed?
> If not, is there a way to release so they can be garbage collected?
Re: Profiling RAP Application [message #648045 is a reply to message #647675] Mon, 10 January 2011 18:10 Go to previous messageGo to next message
I'm setting to a 1000 the field session timeout of the runtime settings in the launch configuration of the application. I don't really know if the value are seconds or milliseconds, but I'm guessing that are milliseconds.
Re: Profiling RAP Application [message #648117 is a reply to message #648045] Tue, 11 January 2011 04:47 Go to previous messageGo to next message
> milliseconds.
No, it's seconds, as the label says: "Session timeout [s]". To be able to
test session cleanup, you'll have to set it to a lower value. I'd
recommend ~30-60s, to be able to simulate some user interaction. Then you
wait for session timeout, create a heap dump, analyze it...
Regards, Ralf
Ralf Sternberg
Twitter: @ralfstx
Re: Profiling RAP Application [message #648232 is a reply to message #648117] Tue, 11 January 2011 17:49 Go to previous message
Ok thanks, I set to those values the session timeout and it worked the application instances were removed.
Previous Topic:Export RAP project as .WAR
Next Topic:Alternative to Text#setTopIndex
Current Time: Sun Jul 27 11:26:30 EDT 2025
Powered by FUDForum. Page generated in 0.86260 seconds
