Home » Language IDEs » ServerTools (WTP) » Tomcat 7 in Indigo.(Unable to create an instance.)
Tomcat 7 in Indigo. [message #646599] Tue, 28 December 2010 23:11 Go to next message
I have the Eclipse-Jee-Indigo-M4-win32 build.
On initial Tomcat 7 instance creation,I was successful to do so.
Later I changed the eclipse directory location,as such tried to remove the Server instance and reconfigure it from start.
I was unable to add a new Tomcat 7 instance,while all other were not grayed out,for Tomcat 7 the "Next " button was grayed out.
Later when I changed the location back to original location, the instance creation worked seamlessly. Is this a bug or the Directory Location in important and relative in all eclipse modules?
Re: Tomcat 7 in Indigo. [message #646745 is a reply to message #646599] Thu, 30 December 2010 12:02 Go to previous messageGo to next message
It's not clear to me exactly what you mean by "I changed the eclipse
directory location". Detailed steps of what you are doing would help.
Larry
Re: Tomcat 7 in Indigo. [message #647560 is a reply to message #646745] Thu, 06 January 2011 23:56 Go to previous messageGo to next message
I moved it from one directory to another.
Moved it from D:/ <Folder1>/<Folder2>/
to c:/<Folder1>/
Re: Tomcat 7 in Indigo. [message #647654 is a reply to message #647560] Fri, 07 January 2011 10:18 Go to previous messageGo to next message
> to c:/<Folder1>/
You should be able to _create_ Eclipse in either location, but on
Windows once you start Eclipse, the content of that location gets
modified and moving it is something I don't think Eclipse supports. If
you install at C:/<Folder1> what is installed at D:/<Folder1>/<Folder2>,
you should have no problem opening the same workspace.
Larry
Re: Tomcat 7 in Indigo. [message #658339 is a reply to message #646599] Mon, 07 March 2011 19:06 Go to previous message
Vipul Amler wrote on Wed, 29 December 2010 05:11
Maybe I'm wrong about what you expect from Eclipse but I think this is only because you believe that you can install Tomcat 7 as easily as Tomcat 6. For Tomcat 6, you can configure it without already having it locally. You just have to click on the button "Download and Install..." whereas this is not possible with Tomcat 7. You can't download it with the Eclipse wizard, you have to first download it manually, install it in a directory and then you can reference it from Eclipse. This is true for Helios then I guess it has not changed for Indigo.
Previous Topic:Extending moduleArtifactAdapters
Next Topic:project text encoding resetted each time
Current Time: Thu Jul 24 22:44:44 EDT 2025
Powered by FUDForum. Page generated in 0.27559 seconds
