Home » Archived » BIRT » Proper aggregated file sizes(Proper aggregated file sizes)
Proper aggregated file sizes [message #647629] Fri, 07 January 2011 08:25 Go to next message
I'm creating a report with a table that lists the size of a bunch of files. These files vary greatly in size between KBs and GBs. Their size is given to me in bytes. Currently I format the file sizes into correct KB/MB/GB units with the Expression Builder.
But I also want a sum of the file sizes at the end of the table. I have created a Aggregation in the end of the table that sums the file sizes in bytes together. But I want that aggregation to also display correct units in either KB, MB or GB. I have noticed that the Expression Builder behaves differently for aggregations so I can't use the same solution for them.
Re: Proper aggregated file sizes [message #647643 is a reply to message #647629] Fri, 07 January 2011 09:30 Go to previous messageGo to next message
In the aggregate items onCreate script use the setDisplayValue function
like:
//get the value
var myval =this.getValue();
//modify it and
this.setDisplayValue(myval +"Kb")
Jason
On 1/7/2011 8:26 AM, Daniel Ohlsson wrote:
> Hi
> for them.
Re: Proper aggregated file sizes [message #647793 is a reply to message #647629] Sun, 09 January 2011 04:46 Go to previous message
Thanks Jason. It did exactly what I needed.
Previous Topic:Data set window does not show synonym and nickname
Next Topic:REMOTE .rptdocument file
Current Time: Thu Jul 24 22:52:20 EDT 2025
Powered by FUDForum. Page generated in 0.07704 seconds
