Home » Modeling » M2T (model-to-text transformation) » [Xpand] Issues setting up project to generate text from UML2 profile metamodel
[Xpand] Issues setting up project to generate text from UML2 profile metamodel [message #647200] Tue, 04 January 2011 19:32 Go to next message
I have a UML2 model that uses a custom profile (UML stereotypes) that I would like to use Xpand to generate code from. It appears that Xpand does provide a UML2 profile metamodel support, but I can't get even a simple example to work.
Alternately, I tried doing a model-to-model transformation from a UML2 model to ecore, but the instance data from my custom profile properties was not being populated correctly when I use Xtend to transform the model.
Any advice from someone who has more experience with this would be greatly appreciated.
sedzen
Re: [Xpand] Issues setting up project to generate text from UML2 profile metamodel [message #647221 is a reply to message #647200] Wed, 05 January 2011 02:34 Go to previous messageGo to next message
Here a Working Sample Workflow:
<workflow>
	<bean class="org.eclipse.xtend.typesystem.uml2.Setup" standardUML2Setup="true" />
	<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" platformUri=".." />
	<component class="org.eclipse.emf.mwe.utils.Reader">
		<uri value="platform:/resource/xpand.uml.profile.sample/src/model/test.uml" />
		<modelSlot value="model" />
	</component>
	<component class="org.eclipse.emf.mwe.utils.DirectoryCleaner">
		<directory value="src-gen" />
	</component>
	<component class="org.eclipse.xpand2.Generator">
		<metaModel class="org.eclipse.xtend.typesystem.uml2.profile.ProfileMetaModel">
			<profile value="platform:/resource/xpand.uml.profile.sample/src/model/test.profile.uml" />
		</metaModel>
		<metaModel class="org.eclipse.xtend.typesystem.uml2.UML2MetaModel" />
		<expand value="template::Template::main FOR model" />
		<outlet path="src-gen" >
			<postprocessor class="org.eclipse.xpand2.output.JavaBeautifier" />
		</outlet>
	</component>
</workflow>
~Christian
Re: [Xpand] Issues setting up project to generate text from UML2 profile metamodel [message #647324 is a reply to message #647200] Wed, 05 January 2011 11:30 Go to previous messageGo to next message
You could also inspect the code from the UML2 cartridges hosted at fornax-platform.org for more samples.
~Karsten
Re: [Xpand] Issues setting up project to generate text from UML2 profile metamodel [message #647349 is a reply to message #647324] Wed, 05 January 2011 13:12 Go to previous messageGo to next message
Thanks, Christian! That helped me get a little further along in my pathfinding.
Now the problem I'm stuck on is trying to access a custom profile stereotype property.
I have found good examples to reference the stereotypes as "types" in the Xpand template, and have even gotten to the point where I can echo the name of a class that has the stereotype applied, but when I try to access the property values, I haven't had much success.
I've tried «MyProfile::MyService::MyProperty»
which results in "uml::Property" being output to the target file.
I've also tried using a modified example from the old oAW forums:
«FOREACH this.getAllAttributes().typeSelect(MyProfile::MyService) AS attr ITERATOR iter»
«attr.getValue(attr.getAppliedStereotype(MyProfile::MyServi ce.toString()), "index")»
«ENDFOREACH»
which results in the following errors:
2636 ERROR StereotypeType - Couldn't find type for EcorePrimitiveTypes::EString
(What I find encouraging is that I have 3 properties for the stereotype, so it does appear to be iterating correctly, even if the mechanism to produce the output is clearly missing something).
Any help would be greatly appreciated!!
Re: [Xpand] Issues setting up project to generate text from UML2 profile metamodel [message #647372 is a reply to message #647349] Wed, 05 January 2011 15:11 Go to previous messageGo to next message
the Mapping between the Typesystem (UML) and The Internal Xtend Typesystem is done manually in the UML2Metamodel.
So to be able to deal with this you could do something like this:
package model;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.emf.mwe.utils.Mapping;
import org.eclipse.xtend.typesystem.Type;
import org.eclipse.xtend.typesystem.uml2.UML2MetaModel;
public class ExtendedUML2Metamodel extends UML2MetaModel {
	private Map<String,String> mappings = new HashMap<String,String>();
	public void addMapping(Mapping mapping) {
		mappings.put(mapping.getFrom(), mapping.getTo());
	public Type getTypeForName(String typeName) {
		Type mappedType = null;
		String mappedTypeName = mappings.get(typeName);
		if (mappedTypeName != null) {
			mappedType = getTypeForName(mappedTypeName);
			if (mappedType != null) {
				return mappedType;
		return super.getTypeForName(typeName);
		</metaModel>
		<metaModel class="model.ExtendedUML2Metamodel">
			<mapping from="EcorePrimitiveTypes::EString" to="ecore::EString" />
		</metaModel>
		</outlet>
	</component>
Maybe there is a better solution but i cannot say
~Christian
Re: [Xpand] Issues setting up project to generate text from UML2 profile metamodel [message #647375 is a reply to message #647372] Wed, 05 January 2011 15:33 Go to previous messageGo to next message
Created https://bugs.eclipse.org/bugs/show_bug.cgi?id=333605 for the problem
Re: [Xpand] Issues setting up project to generate text from UML2 profile metamodel [message #647701 is a reply to message #647375] Fri, 07 January 2011 16:04 Go to previous message
Just to confirm, the workaround does appear to get us past the issue that the bug report was opened to address. At least, we are able to continue moving forward with our efforts.
Thanks!
Previous Topic:[XPand, MWE2] Why full xtext dependency?
Next Topic:[Acceleo 3] Protected section ERROR ?
Current Time: Sat Jul 26 03:19:49 EDT 2025
Powered by FUDForum. Page generated in 0.37446 seconds
