Home » Eclipse Projects » Standard Widget Toolkit (SWT) » A custom copy/paste operation
A custom copy/paste operation [message #647077] |
Tue, 04 January 2011 08:54  |
I have to develop the following scenario: when a user copies a bunch of cells (each containing an email address) in Excel and he pastes this selection into a SWT text field, the text field has to contain all email addresses seperated by a comma.
Using a Clipboard instance and a KeyListener I was able to implement this scenario: when Ctrl+V is hit, I get the current content of the clipboard instance, replace every white space occurence with a comma and set this altered text into the text field.
When the user clicks the right mouse button and chooses 'Paste' nothing happens (of course), but it should behave in exactly the same way as using Ctrl+V to paste the email addresses.
How can I solve this problem? Maybe there is a better way of handling a custom copy/paste operation which will work in both cases.
Kind regards,
Roel
[Updated on: Tue, 04 January 2011 08:55] by Moderator
Re: A custom copy/paste operation [message #647176 is a reply to message #647077] |
Tue, 04 January 2011 15:47   |
I will comment on both alternatives you suggested
1/ overwriting paste-method
I think that's a good alternative (which I wanted to implement), but when I had a look at the paste-method I saw something like this:public void paste () {
checkWidget ();
if ((style & SWT.READ_ONLY) != 0) return;
OS.SendMessage (handle, OS.WM_PASTE, 0, 0);
That's Chinese for me, I don't have any idea how I could modify this code to get the desired outcome.
2/ using a ModifyListener
I thought about this one too, but I don't think this one is the road you want to follow, because:
a) how can you know the user selected 'Paste' in the context menu (and not 'Cut' or 'Copy' or just clicked in the text field)
b) with a ModifyListener the code will also be executed when the user enters something in the text field (regular data entry). And when the clipboard contains some copied text (from any application) you'll end up with unwanted data.
On the internet you'll find tons of examples about how to copy/paste text from the clipboard, but they all have the same problem: a seperate Paste-button which you have to click to paste the clipboard contents into the Text-field. So I think implementing a custom copy/paste operation without such a button is really hard to do.
As a side note: if you copy from Excel you'll get a String with the actual cell contents mixed with tabs (to seperate columns) and new lines (to seperate rows).
I'm most grateful if someone has any sample code or tips/hints to override the paste-method. Other suggestions or alternatives are also appreciated.
Kind regards,
Roel
Re: A custom copy/paste operation [message #647346 is a reply to message #647176] |
Wed, 05 January 2011 13:04   |
Roel De Nijs wrote on Tue, 04 January 2011 15:47 | I will comment on both alternatives you suggested
Kind regards,
Roel
For b : I personally don't use clipboard, but I don't need excel data too. In my listener, I get the string by doing text.getText();
Here is how I do to parse string user enter with keyboard, or ctrl+V or menu paste :
text.addModifyListener(new ModifyListener() {
public void modifyText(ModifyEvent dummy) {
int selection = text.getSelection().x;
String checked = text.getText().trim().replaceAll("[\\\\/:*?\"<>|]", "");
if(!text.getText().equals(checked)) {
selection -= text.getText().length() - checked.length();
text.setText(checked); // will call this listener again, and perform the 'else' branch
text.setSelection(selection);
} else {
updateSomething();
There is certainly a much better way to do that, but it works.
What I want to suggest you (but may be that not a good idea), is to not try to know from where string come from, just parse it.
If the excel string contains some space and tab, you should be able to know it comes from excel.
But I think, is there is a real difference between what should stay in the text field depending on the source, may it's more an IHM bug.
Your user should be able to enter space and tab in that field ? That's maybe a bad idea...
checkWidget ();
Roel
This chinese just means the past is handled in another layer. Don't know more like u, and in that case the wiser should be to not change anything. Just use this place as a listener.
If this method is really called every time user performs mouse paste, then you can still do something using these two listeners (may be not very nice...) :
public String uglyHack = null;
if(you can know it's excell) {
uglyHack = get the clipboard parsed;
or just use boolean
super.paste();
if(uglyHack != null / false) {
uglyHack = null / false;
text.setText(parsed excell string);
} else {
// do the thing with other text
May be you could try this way....
I suppose clipboard help for handling thing like everything that is not basic text. If user mouse-past text from notepad for example, clipboard should be able to know it's different.
good luck
[Updated on: Wed, 05 January 2011 14:35] by Moderator
Re: A custom copy/paste operation [message #647434 is a reply to message #647077] |
Thu, 06 January 2011 05:38   |
When you want to use data from Excel you have to use a clipboard, because when you paste the content into a text field, only the content of the 1st cell is pasted (and that's not the desired behavior).
As you already indicated working with the paste-method is a possibility, but seems to be a bit of a hack, and so should be avoided. Because it's not a good programming practice and code like this which could fail after upgrading to the next version.
I guess we will use one of the following alternatives:
- disable mouse events in the text field
- use an extra button to perform the paste-operation from Excel
- use a multi-line text field (instead of a single line one), so you can just use regular paste (without any modifications). E-mail addresses will be seperated with white space (instead of a comma) and will not be on 1 line. So that's not the desired behavior but it's a rather small difference: main functionality (copy/paste from excel) is stiIl possible, but representation is a bit different. So I hope this alternative is satisfactory for the user (because from the developer's perspective it's the simplest and cleanest, no tweaks, solution).
Thanks for your ideas and suggestions!
Kind regards,
Roel
[Updated on: Thu, 06 January 2011 05:39] by Moderator
Re: A custom copy/paste operation [message #647521 is a reply to message #647434] |
Thu, 06 January 2011 13:45   |
I couldn't follow your question correctly, are you trying to override the default behavior when user selects paste from the context menu?
One way to do this is to show your own context menu (instead of the default menu) with the menu items you require such as cut, copy, paste. Then, you'll be able to control when the user selects paste from the menu.
Here is an example:
When the default context menu for theText is about to be shown your MenuDetect listener will be notified. You can create your own menu with menu items inside the listener.
text.addMenuDetectListener (new MenuDetectListener() {
public void menuDetected (MenuDetectEvent e) {
Menu menu = new Menu (shell, SWT.POP_UP);
MenuItem paste = new MenuItem (menu, SWT.PUSH);
paste.setText ("Paste");
text.setMenu (menu);
paste.addSelectionListener (new SelectionAdapter() {
public void widgetSelected (SelectionEvent e) {
//your paste logic
//create menu items for copy, cut
MenuItem copy = new MenuItem (menu, SWT.PUSH);
copy.setText ("Copy");
copy.addSelectionListener (new SelectionAdapter() {
text.selectAll ();
text.copy ();
Also, if you do not want to show the context menu at all, you can set event.doit = false inside the listener.
HTH,
Re: A custom copy/paste operation [message #647522 is a reply to message #647434] |
Here is an example:
//your paste logic
text.selectAll ();
text.copy ();
HTH,
Re: A custom copy/paste operation [message #647623 is a reply to message #647077] |
Fri, 07 January 2011 07:45  |
Hi Lakshmi,
My initial question was: what's the best way/practice to customize the paste-operation. For example: people copy email addresses (1 per cell) from Excel and paste it into a swt single-line text field (comma seperated).
I was able to perform this behavior when the user uses Ctrl+V, but not when the user uses the default context menu. So I was looking for the best practice or alternatives.
So your suggestions of overriding the default context menu (with a code sample) or disabling it are highly appreciated (and were also suggested in the previous post).
I proposed a lot of alternatives (the ones you suggested were included) to the responsible person and he decided to use another alternative: using a seperate button for pasting the e-mail addresses from the clipboard. This alternative is more conform with the "philosophy" of our application (deliver a consistent look-and-feel to the user)
Kind regards,
Roel
Current Time: Sun Jul 27 03:56:03 EDT 2025
Powered by FUDForum. Page generated in 0.05024 seconds
