Home » Archived » BIRT » help with multiple parameter drill through using php/java bridge(Only first parameter is being processed)
help with multiple parameter drill through using php/java bridge [message #647335] Wed, 05 January 2011 11:51 Go to next message
I have been following the examples from Integrating BIRT with php and from the BIRT examples in the java bridge itself, however when drilling into another report that accepts multiple parameters only the first parameter is being passed.
Here is the loop that sets the parameters before the report is run. This is almost identical to the code in the example in the javabridge and the above link.
for ($i=0; $i < $parmarraysize; $i++) {
	$parmhandle = $sh->get($i);
	$parmname = $parmhandle->getName();
	$dt = $parmhandle->getDataType();
	$passedinvalue = $_REQUEST[java_values($parmname)];
	echo $parmarraysize."<br>";
	echo $i."<br>";
	if (isset($passedinvalue)) {
		if( strcasecmp(java_values($dt), "integer") == 0 )
			$Parm = new Java("java.lang.Integer", (int)$passedinvalue);
			$task->setParameterValue($parmname, $Parm);
		}else if( strcasecmp(java_values($dt), "string") == 0 )
			$Parm = new Java("java.lang.String", $passedinvalue);
		}else if( strcasecmp(java_values($dt), "decimal") == 0 )
			$Parm = new Java("java.lang.Float", (float)$passedinvalue);
I'm echoing a few variables for debugging purposes. For a report with two parameters this results in
2
0
This means the report accepts two parameters, and the loop is in its first iteration. However, after this the code after the loop runs without the loop ever entering its second iteration.
I'm very confused by this as it appears that the loop should run for every parameter that the report accepts. Any help would be appreciated.
[Updated on: Wed, 05 January 2011 11:52] by Moderator
Re: help with multiple parameter drill through using php/java bridge [message #647364 is a reply to message #647335] Wed, 05 January 2011 14:09 Go to previous message
I've solved the problem the parmarraysize isn't an integer. After doing some type checking I found out that it is in fact an object. When it's used as an integer it defaults to 1, that's why the loop only iterates once. When it is echoed it uses some method to represent it as a string which is why it displayed the correct size. By casting this to a string and then checking it against $i the problem was alleviated.
Re: help with multiple parameter drill through using php/java bridge [message #647367 is a reply to message #647335] Wed, 05 January 2011 13:57 Go to previous message
Are you echoing parmarraysize?
Jason
> http://www.theserverside.com/news/1363642/Intergrating-BIRT- with-PHP and
> above link.
> echo $i."<br>";
> 2
> 0
Previous Topic:Parameter in XPATH DataSet
Next Topic:Drill-Through - Hide Parameter Pager
Current Time: Sun Jul 27 11:49:16 EDT 2025
Powered by FUDForum. Page generated in 0.04401 seconds
