[ATL]Unable to access name on OclUndefined [message #647263] |
Wed, 05 January 2011 08:11  |
Hello, ATL-Community!
Happy New Year 2011 for all!
May I ask you some question about ATL?
I try to perform this ATL-transformation-chain xml2PLM, PLM2ISyFMU, as you advised me for some time.
Now I have some difficulties with the PLM2ISyFMU part.
In my mapping I have to map the same source-class (PLM!Item) to two different target-classes (ISyFMU!Element and ISyFMU!Attribute, whereby Attribute has to be put inside the Element).
Here is the snplet of the ATL-Code, where I tried to do that:
rule Item2Element
from s: PLM!Item
to t: ISyFMU!Element(
name<-'item',
attributes<-thisModule.Item2Attribute()
lazy rule Item2Attribute
from s: PLM!Item
to t: ISyFMU!Attribute
name<-s.name,
id<-s.id -- Hier Fehlermeldung: Unable to access names on OclUndefined
For some reason it doesn't work, because of this error message:
org.eclipse.m2m.atl.engine.emfvm.VMException: Unable to access name on OclUndefined (at line name<-s.name)
Do you have an idea, why I get the message?
Thanx a lot,
Greetings,
Alexey
[Updated on: Wed, 05 January 2011 08:25] by Moderator
Re: Unable to access name on OclUndefined [message #647275 is a reply to message #647263] |
Wed, 05 January 2011 08:44   |
> Happy New Year 2021 for all!
You can create more than one element in a rule:
> rule Item2Element
> from s: PLM!Item
> name<-'item',
> attributes<-attr
> attr: ISyFMU!Attribute (
> name<-s.name,
> id<-s.id
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: Unable to access name on OclUndefined [message #647279 is a reply to message #647277] |
Wed, 05 January 2011 09:28  |
Alexey wrote on Wed, 05 January 2011 09:21 | I know, i tried it out already! This doesnt work, because then I have both nodes at the same level, and I have to have them one inside another.
Oh, now I see!
U did it with referencing this "attr", now it works.
Thanx a lot!
FUDForum. Page generated in 0.04458 seconds
