Home » Modeling » EMF » Extending EMF Code Generator
| Extending EMF Code Generator [message #647243] |
Wed, 05 January 2011 05:27  |
in this message Ed gives the comment to use Dynamic Templates (DT) to change the existing templates and to create a plugin and write a Generator Adapter to add new files to the generation. The new one can be overwritten again by the DT.
Well I started in my EMF Addon project to write some DT for generation of a bit more structured EMF editor.
At one point now I have to add a new file, so i wrote a plugin for it based on org.eclipse.emf.examples.generator.validator.
Now the question now is how can I overwrite existing templates in the plugin, the sample shows only adding new one.
In the other case it is always both required the plugin and the configuration in the genmodel to use the DT templates.
To simplify this i like to merge all in the plugin and e.g. enabled it by an annotation in the genmodel.
Greetings
Stephan
[Updated on: Wed, 05 January 2011 05:29] by Moderator
| Re: Extending EMF Code Generator [message #647340 is a reply to message #647243] |
Wed, 05 January 2011 12:04   |
--------------010409070401000507060309
Stephan,
Notice that the class loader of your derived generator adapter is used
to find the compiled (static) template, so if you have compiled
templates with the same qualified names as provided by EMF's generator
they'll "override" the ones from the base.
protected JETEmitter createJETEmitter(JETEmitterDescriptor
jetEmitterDescriptor)
JETEmitter jetEmitter = new JETEmitter(getTemplatePath(),
jetEmitterDescriptor.templatePathName, getClass().getClassLoader());
try
setStaticTemplateClass(jetEmitter,
jetEmitterDescriptor.className);
Stephan Zehrer wrote:
> Hello,
> in
> http://www.eclipse.org/forums/index.php?t=msg&S=26948a75 00a8f8b49cfde1a577ad810c&th=155261&goto=489160
> Well I started in my http://code.google.com/a/eclipselabs.org/p/emf/
> In the other case it is always both required the plugin the
> Greetings
> Stephan
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
<title></title>
</head>
Stephan,<br>
<br>
they'll "override" the ones from the base.<small><br>
</small>
<blockquote><small> protected JETEmitter
createJETEmitter(JETEmitterDescriptor jetEmitterDescriptor)</small><br>
<small> {</small><br>
<small> JETEmitter jetEmitter = new JETEmitter(getTemplatePath(),
jetEmitterDescriptor.templatePathName, getClass().getClassLoader());</small><br>
<br>
<small> try</small><br>
<small> setStaticTemplateClass(jetEmitter,
jetEmitterDescriptor.className);</small><br>
</blockquote>
<br>
<blockquote cite="mid:ig1gph$u8b$1@news.eclipse.org" type="cite">Hello,
<br>
<br>
in
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/forums/index.php?t=msg&S=26948a75 00a8f8b49cfde1a577ad810c&th=155261&goto=489160">http://www.eclipse.org/forums/index.php?t=msg& ;S=26948a7500a8f8b49cfde1a577ad810c&th=155261&am p;goto=489160 </a>
again by the DT.
<br>
<br>
Well I started in my <a class="moz-txt-link-freetext" href="http://code.google.com/a/eclipselabs.org/p/emf/">http://code.google.com/a/eclipselabs.org/p/emf/</a> to
write some DT for generation of a bit more structured EMF editor. At
<br>
<br>
plugin, the sample shows only adding new one. <br>
<br>
<br>
<br>
Greetings
<br>
<br>
Stephan
<br>
</blockquote>
</body>
</html>
--------------010409070401000507060309--
| Re: Extending EMF Code Generator [message #647712 is a reply to message #647709] |
Fri, 07 January 2011 18:46   |
--------------010401080606050307030809
Stephan,
Comments below.
> Hi Ed,
> thx for your response ...
> Ed Merks wrote on Wed, 05 January 2011 12:04
>> used to find the compiled (static) template, so if you have compiled
>> generator they'll "override" the ones from the base.
>> try
> This sounds for me I just put the compiled temples into the plugin and
> it should work? ... Well tested and I does (in my case) not :)
All I can suggest is looking at determining why the class loader for
your derived generator adapter (hmmm, you do have one?) doesn't find
your versions of the classes. when setStaticTemplateClass is called.
try
> After that I added an generateJava call in my GenerationAdapter ...
> did not work either ..
> Now which of both is correct or is there a third option I just not see?
Look into what's happening when the template class is set...
> Btw ... why are the NL public in your compiled temples ... is there a
> special setting in JET?
Look at JETEmitter.getObject; it's important that the template can be
specialized to generate the right type of line feeds depending on
preferences.
> Greetings from Germany
> Stephan
<html>
<head>
</head>
Stephan,<br>
<br>
Comments below.<br>
<br>
<br>
<blockquote cite="mid:ig86ob$2gh$1@news.eclipse.org" type="cite">Hi Ed,
<br>
<br>
thx for your response ... <br>
<br>
<blockquote type="cite">Notice that the class loader of your derived
generator adapter is used to find the compiled (static) template, so if
you have compiled templates with the same qualified names as provided
by EMF's generator they'll "override" the ones from the base.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
try
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
your versions of the classes. when setStaticTemplateClass is called.<br>
<br>
</blockquote>
<br>
<blockquote cite="mid:ig86ob$2gh$1@news.eclipse.org" type="cite">After
that I added an generateJava call in my GenerationAdapter ... did not
work either .. <br>
<br>
</blockquote>
Look into what's happening when the template class is set...<br>
<blockquote cite="mid:ig86ob$2gh$1@news.eclipse.org" type="cite"><br>
<br>
</blockquote>
preferences.<br>
Greetings from Germany <br>
Stephan
<br>
</blockquote>
</body>
</html>
--------------010401080606050307030809--
| Re: Extending EMF Code Generator [message #647761 is a reply to message #647741] |
Sat, 08 January 2011 12:08   |
--------------070703050004010001020707
Stephan,
Comments below.
> Ed Merks wrote on Fri, 07 January 2011 18:46
> Yes I have one, but I think I need an example to explain what I want.
> I have an new template ResourceManager which is generated in my
> GenAdapter. (without a AdapterFactory)
> Now i have adapted the Editor.javajet template to use the
> ResourceManager.
> Just adding the editor template class to my plugin didn't work. It is
> still the GenPackageGeneratorAdapter of the ecore.codegen plugin which
> generate the editor and I see at the moment no way how this plugin
> should find my class. (correct??)
> So i expect i have to do more. (e.g. registration? )
I see. UML2 does this, but it has its own extended GenModel and
therefore has specialized adapters that kick in.
> You mean in the generateEditor method?
No, I keep pointing you to the specific class in which to set breakpoints.
> But at this time the editor is already generated.
> Where/When is it set?
> The JETEmitterDescriptors is provided only in the generateJava call
> as far as I see.
I have a feeling you're not taking much advantage of the debugger.
You'll understand the behavior of a framework much better if you set a
breakpoint and then look at all the calls that lead up to a specific
point in the code. That's what I've been prompting you to do. It's
much better to look at code in a running dynamic process then to do
endless static analysis.
>>> a special setting in JET?
>> preferences.
> Ok I'll take take a look
Another technique that should work well in your type of situation is to
use a platform:/plugin/<your-bundle>/templates in the GenModel's
Template Path. That should make this code kick in to create a class
loader that loads classes, i.e., the compiled templates, from your bundle.
else if (templateURI.isPlatformPlugin())
final Bundle bundle =
Platform.getBundle(templateURI.segment(1));
if (bundle != null)
// Define a class loader that will look up the class
in the bundle,
// and if it doesn't find it there, will look in the
parent.
theClassLoader =
new URLClassLoader(new URL [0], jetEmitter.classLoader)
public Class<?> loadClass(String className) throws
ClassNotFoundException
try
return bundle.loadClass(className);
catch (ClassNotFoundException
classNotFoundException)
return super.loadClass(className);
> thanks
> Stephan
<html>
<head>
</head>
Stephan,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:ig9qh8$amu$1@news.eclipse.org" type="cite">Ed
<br>
<blockquote type="cite">All I can suggest is looking at determining
why the class loader for your derived generator adapter (hmmm, you do
have one?) doesn't find your versions of the classes. when
<br>
</blockquote>
<br>
<br>
<br>
<br>
ResourceManager.
<br>
<br>
<br>
<br>
</blockquote>
therefore has specialized adapters that kick in. <br>
<blockquote cite="mid:ig9qh8$amu$1@news.eclipse.org" type="cite"><br>
<blockquote type="cite">Now which of both is correct or is there a
<br>
</blockquote>
<br>
</blockquote>
You mean in the generateEditor method?</blockquote>
breakpoints.<br>
<blockquote cite="mid:ig9qh8$amu$1@news.eclipse.org" type="cite"> But
<br>
<br>
The JETEmitterDescriptors is provided only in the generateJava call as
far as I see.
<br>
</blockquote>
endless static analysis.<br>
<br>
<blockquote type="cite">Btw ... why are the NL public in your
compiled temples ... is there a special setting in JET?
<br>
</blockquote>
preferences.
<br>
</blockquote>
<br>
</blockquote>
bundle.<br>
<small><br>
</small>
<blockquote><small> else if (templateURI.isPlatformPlugin())</small><br>
<small> final Bundle bundle =
Platform.getBundle(templateURI.segment(1));</small><br>
<small> if (bundle != null)</small><br>
<small> // Define a class loader that will look up the
class in the bundle,</small><br>
<small> // and if it doesn't find it there, will look in
the parent.</small><br>
<small> //</small><br>
<small> theClassLoader = </small><br>
<small> new URLClassLoader(new URL [0],
jetEmitter.classLoader)</small><br>
<small> @Override</small><br>
<small> public Class<?> loadClass(String
className) throws ClassNotFoundException</small><br>
<small> return bundle.loadClass(className);</small><br>
<small> }</small><br>
<small> catch (ClassNotFoundException
classNotFoundException)</small><br>
<small> return super.loadClass(className);</small><br>
<small> };</small><br>
</blockquote>
<br>
thanks
<br>
<br>
Stephan
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------070703050004010001020707--
| Re: Extending EMF Code Generator [message #647773 is a reply to message #647761] |
Sat, 08 January 2011 15:24   |
Hi Ed,
[quote title=Ed Merks wrote on Sat, 08 January 2011 12:08c
[/quote]
I guess this is a yes ...
| Quote: |
Well I did ... already on your last mail.
I put it on "setStaticTemplateClass"
And it get called for each template which is generated. (e.g. staring with ....templates.editor.Plugin if you generate the Editor".
In the line "Class<?> templateClass = getClass().getClassLoader().loadClass(className);" the classloader of getClass is used.
But getClass return, in the case of the Edior.javajet template (which i like replace), the class .... genmodel.generator.GenPackageGeneratorAdapter of the ecore plugin. That is the first time where the editor is generated.
So I see no change that in the first step he will ever find my template class because the plugin is always using the class loader of the generator adapter.
The second time it is called in my generator adapter now but it seems, even it uses the classloader of my gen adapter, it loads the wrong class.
I guess because the class is already loaded from the first time?
I will try it now with an other template name.
But the behavior of the first generation i can not change, or is there a mistake in my conclusion?
| Quote: |
> as far as I see.
Well I did ... hope your feeling changed now
| Quote: |
if (bundle != null)
in the bundle,
parent.
theClassLoader =
try
Ok that's maybe a solution, i can use it even as general switch for all generation task in the plugin.
The disadvantage of this, i can not use dynamicTemplates any more for development.
It is very time consuming always redeploy the plugin for testing. Mmm i have to think about this
Thanks..
Stephan
[Updated on: Sat, 08 January 2011 15:25] by Moderator
| Re: Extending EMF Code Generator [message #647778 is a reply to message #647773] |
Sat, 08 January 2011 16:41   |
Stephan,
You could switch from platform:/plugin to platform:/resource while
developing. Note that even with platform:/resource, if your project has
a JETNature and hence has compiled templates that the JETEmitter should
end up using those compiled versions...
> Hi Ed,
>> which generate the editor and I see at the moment no way how this
>> plugin should find my class. (correct??)
> therefore has specialized adapters that kick in. [/quote]
> Quote:
>> breakpoints.
> Well I did ... already on your last mail. I put it on
> getClass is used.
> I will try it now with an other template name. But the behavior of the
> conclusion?
> Quote:
>> call > as far as I see.
>> a breakpoint and then look at all the calls that lead up to a
>> specific point in the code. That's what I've been prompting you to
>> do. It's much better to look at code in a running dynamic process
>> then to do endless static analysis.
> Well I did ... hope your feeling changed now :)
> Quote:
>> to use a platform:/plugin/<your-bundle>/templates in the GenModel's
>> bundle.
>> if (bundle != null)
>> in the bundle,
>> parent.
>> theClassLoader =
>> @Override
>> try
> development. It is very time consuming always redeploy the plugin for
> testing. Mmm i have to think about this :)
> Thanks..
> Stephan
| Re: Extending EMF Code Generator [message #647957 is a reply to message #647857] |
Mon, 10 January 2011 10:26  |
--------------080701060707000208060801
Stephan,
Thanks for sharing your experience in the wiki!! Likely more folks
would find it from the EMF Recipes page:
http://wiki.eclipse.org/EMF/Recipes
> Ed,
> Thanks !!
> Ed Merks wrote on Sat, 08 January 2011 16:41
>> has a JETNature and hence has compiled templates that the JETEmitter
>> should end up using those compiled versions...
> After a hour debugging I understand now more or less what the
> JETEmitter is doing :)
> And I can confirm that the platform:/plugin method works. My problems
> were solved after the removing of the .JETEmitter project from my test
> environment workspace, without it always found old version's of the
> classes (maybe a bug? .... if so it will happen again I will open one)
> Nevertheless it works now !
> Btw. the NL problem was produced if you use M2T JET project in JET1
> mode :) and not the EMF version.
> I put some may experiences on the following wiki page
> http://wiki.eclipse.org/EMF/ExtendingCodeGeneration
> Greetings
> Stephan
<html>
<head>
</head>
Stephan,<br>
<br>
would find it from the EMF Recipes page:<br>
<blockquote><a href="http://wiki.eclipse.org/EMF/Recipes">http://wiki.eclipse.org/EMF/Recipes</a><br>
</blockquote>
<br>
<blockquote cite="mid:igecs2$s3b$1@news.eclipse.org" type="cite">Ed,
<br>
<br>
Thanks !!
<br>
<br>
<br>
<blockquote type="cite">You could switch from platform:/plugin to
platform:/resource while developing. Note that even with
platform:/resource, if your project has a JETNature and hence has
compiled templates that the JETEmitter should end up using those
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/EMF/ExtendingCodeGeneration">http://wiki.eclipse.org/EMF/ExtendingCodeGeneration</a>
<br>
<br>
Greetings
<br>
<br>
Stephan <br>
<br>
</blockquote>
</body>
</html>
--------------080701060707000208060801--
Current Time: Fri Nov 14 23:56:32 EST 2025
Powered by FUDForum. Page generated in 0.36548 seconds
