Home » Eclipse Projects » Rich Client Platform (RCP) » Programmatically add Buttons to Toolbar during runtime
Programmatically add Buttons to Toolbar during runtime [message #646194] Wed, 22 December 2010 10:53 Go to next message
Dear RCP folks,
I try to add Buttons programmatically during runtime to the Toolbar. Is
there a common way to do this? I cannot do it statically by giving
menuContributions in the plugin.xml.
My first try:
Added a "dynamic" menuContribution in my plugin.xml and implemented a
ContributionItem. I first tried to use CompoundContributionItem, but
this seems only to support menus and no toolbars.
Hence, I subclassed CompoundContributionItem and implemented
fill(ToolBarManager) instead of fill(MenuManager).
Is this a right way to do it?
Still I need to create the required CommandContributionItem objects.
However, I don't know how to create the corresponding Command
programmatically. API says I should use the CommandManager to
instantiate a Command. How do I get that manager?
Hauke
Re: Programmatically add Buttons to Toolbar during runtime [message #647171 is a reply to message #646194] Tue, 04 January 2011 15:18 Go to previous message
There might be layout problems with this approach. I also don't believe
the framework will try and re-create your dynamic item except at random
toolbarmanager updates. With Menus they can be updated on an SWT.Show
event, which is why CompoundContributionItem only applies to Menus.
You can generate CommandContributionItemParameters and CCIs just as
easily in your ContributionItem ... but what do you mean, generate
commands. You really don't know what commands you support until you
read a config file?
They can still be defined via:
org.eclipse.ui.commands.ICommandService.getCommand(String) but it's
generally not a good idea ... where are you going to activate a handler
for that command?
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:What is difference between parameters defined for Commands and Menu Contribs
Next Topic:ConfigurationScope is not working
Current Time: Fri Jul 25 06:05:02 EDT 2025
Powered by FUDForum. Page generated in 0.04381 seconds
