Home » Archived » BIRT » Arial font size changes randomly in BIRT report(Font sizes change from template design at runtime)
Arial font size changes randomly in BIRT report [message #647008] Mon, 03 January 2011 19:11 Go to next message
We use BIRT to generate correspondence notices to our clients. We run these during a batch run with over 100k generated using 4 JBoss servers each running a BIRT servlet implementation.
For most of the correspondence reports the PDF's generated are correct but there are a handful that fail randomly (e.g. 32 out of 100k have the font error). If we re-run these same correspondence they will not have the same error which makes it difficult for us to debug.
The BIRT template sets the font in a table to be Arial size 8 but for the ones that fail the font changes to a larger font (looks like Arial size 12).
The creates problems for our printing that is expecting a specific number of pages in the correspondence. The larger fonts create an extra page and the correspondence job fails at that point.
We are wondering if the problem is a concurrency issue with the fonts as we are running several report requests simultaneously.
Has anyone else experienced a problem with font sizes changing at run time? We are trying to find a good work around for this problem. Any suggestions would be greatly appreciated.
Brett
Re: Arial font size changes randomly in BIRT report [message #647016 is a reply to message #647008] Mon, 03 January 2011 23:06 Go to previous messageGo to next message
I should add that the JBoss server is running on an enterprise SUSE linux installation. The fonts were added to the OS and display correctly most of the time.
Brett
Re: Arial font size changes randomly in BIRT report [message #647099 is a reply to message #647016] Tue, 04 January 2011 10:32 Go to previous messageGo to next message
Brett,
Can you open a bugzilla entry for this?
Jason
> most of the time.
> Brett
Re: Arial font size changes randomly in BIRT report [message #647227 is a reply to message #647099] Wed, 05 January 2011 03:44 Go to previous message
Bugzilla ticket opened for this problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=333511
I will continue to add more information to that bug as we try to debug the problem.
Brett
Previous Topic:gradients in pie charts
Next Topic:RCP Report Designer via Java Web Start
Current Time: Sat Jul 26 08:46:50 EDT 2025
Powered by FUDForum. Page generated in 0.03644 seconds
