Home » Modeling » TMF (Xtext) » Loading a resource
Loading a resource [message #639116] Mon, 15 November 2010 06:15 Go to next message
I was trying to play around with the code given in the xtext Tutorial under Processing Xtext Models, Loading a Resource ( http://www.eclipse.org/Xtext/documentation/latest/xtext.html #processing_Xtext_models), but I cannot get it to work.
		// DomainmodelStandaloneSetup.doSetup();
		new DomainmodelStandaloneSetup().createInjectorAndDoEMFRegistration();
		ResourceSet rs = new ResourceSetImpl();
		File file = new File("C:/runtime-EclipseApplication/gettingstarted/my2.dmodel");
		Resource resource = rs.getResource(URI.createURI(file.toURI().toString()), true);
//		Resource resource = rs.getResource(URI.createURI("./my2.dmodel"), true);
		EObject eobject = resource.getContents().get(0);
		DomainModel domainModel = (DomainModel) eobject;
		EList<AbstractElement> elements = domainModel.getElements();
		for (AbstractElement abstractElement : elements) {
		  if (abstractElement instanceof Entity) {
		    Entity entity = ((Entity)abstractElement);
		    System.out.println("entity "
		     + entity.getName()
		     + " extends "
		     + entity.getSuperType().getName());
I get this error:
Exception in thread "main" java.lang.RuntimeException: Cannot create a resource for 'file:/C:/runtime-EclipseApplication/gettingstarted/my2.dmodel'; a registered resource factory is needed
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:394)
	at org.eclipse.xtext.example.Test.main(Test.java:26)
from the line:
I created the Java file in the org.eclipse.xtext.example.domainmodel project, in the package org.eclipse.xtext.example.
What am I missing?? Confused
Regard, Robin
Re: Loading a resource [message #639371 is a reply to message #639116] Tue, 16 November 2010 04:53 Go to previous messageGo to next message
Are you running your code from within Eclipse (not in a separate JVM)?
If so, you shouldn't call the DomainmodelStandaloneSetup. Otherwise, use
a debugger to make sure the line
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "dmodel",
resourceFactory);
in DomainmdodelStandaloneSetupGenerated is called. This is where the
resource factory should be registered.
Am 15.11.10 12:16, schrieb Robin:
> new DomainmodelStandaloneSetup().createInjectorAndDoEMFRegistrat ion();
> File file = new
> File("C:/runtime-EclipseApplication/gettingstarted/my2.dmodel ");
> Resource resource =
> + entity.getName()
> + " extends "
> I get this error:
> resource for
> 'file:/C:/runtime-EclipseApplication/gettingstarted/my2.dmod el'; a
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:394)
> from the line:
> Resource resource =
> What am I missing?? :?
> Regard, Robin
Re: Loading a resource [message #643566 is a reply to message #639371] Tue, 07 December 2010 08:15 Go to previous messageGo to next message
Since I am using the code generated by the MWE2 generation, I am running the Test.java in the same workspace. I don't see why this should be a problem, since nothing is actually running, when I run the Test.java.
How should I do this properly?? It doesn't say in the tutorial ( http://www.eclipse.org/Xtext/documentation/latest/xtext.html #processing_Xtext_models).
The line
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("dmodel ", resourceFactory);
in DomainmodelStandaloneSetupGenerated is called. I debugged it. But still then the ResourceSetImpl.getResource method falls through every case and eventually throws the RuntimeException. So, somehow the Resource is not properly registered??
I have absolutely no clue... Sad
Re: Loading a resource [message #644567 is a reply to message #643566] Mon, 13 December 2010 05:12 Go to previous messageGo to next message
Anyone?? Just some thoughts or clues to help me get in the right direction, please?? Sad
Re: Loading a resource [message #644773 is a reply to message #644567] Tue, 14 December 2010 03:28 Go to previous messageGo to next message
Hi Robin
did you try to use this URI:
rs.getResource(URI.createURI("my2.dmodel"), true);
Basically you code looks ok. However, I'd assume that the file uri has
to use two slashes: file://c:/..
Sebastian
Am 13.12.10 11:12, schrieb Robin:
> direction, please?? :(
Re: Loading a resource [message #644837 is a reply to message #639116] Tue, 14 December 2010 07:15 Go to previous messageGo to next message
Hi Robin,
maybe you could try this:
File file = new File("C:\\runtime-EclipseApplication\\gettingstarted\\my2.dmodel");
regards
Andy
Re: Loading a resource [message #646769 is a reply to message #639116] Thu, 30 December 2010 16:59 Go to previous messageGo to next message
Hi!
Thanks for the replies. Sadly none is working.
gives
Exception in thread "main" java.lang.RuntimeException: Cannot create a resource for 'my2.dmodel'; a registered resource factory is needed
File file = new File("//C:/runtime-EclipseApplication/gettingstarted/my2.dmodel");
gives
File file = new File("file://C:/runtime-EclipseApplication/gettingstarted/my2.dmodel");
also gives
Exception in thread "main" java.lang.RuntimeException: Cannot create a resource for 'file:/C:/eclipsew/org.eclipse.xtext.example.domainmodel/file:/C:/runtime-EclipseApplication/gettingstarted/my2.dmodel'; a registered resource factory is needed
maybe like this:
Resource resource = rs.getResource(URI.createURI("file://C:/runtime-EclipseApplication/gettingstarted/my2.dmodel"), true);
gives
Exception in thread "main" java.lang.RuntimeException: Cannot create a resource for 'file://C:/runtime-EclipseApplication/gettingstarted/my2.dmodel'; a registered resource factory is needed
or
also gives
Well, I guess it is not the File or URI object since this is valid. The factory simply seems not to be registered. How can that be??? Confused
Regards, Robin
Re: Loading a resource [message #646770 is a reply to message #646769] Thu, 30 December 2010 17:15 Go to previous messageGo to next message
hello robin,
can you post your complete code loading the model. seems you are not callling standalonesetup.
this code works nicely for me
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.xtext.example.DomainmodelStandaloneSetup;
import org.eclipse.xtext.example.domainmodel.DomainModel;
public class Test {
		Resource resource = rs.getResource(URI.createURI("./src/test.dmodel"), true);
		DomainModel model = (DomainModel) resource.getContents().get(0);
		System.out.println(model.getElements().size());
~Christian
Re: Loading a resource [message #654227 is a reply to message #646770] Mon, 14 February 2011 11:43 Go to previous messageGo to next message
Okay, trying again...
I plain tried your code (with the needed modifications of course), but it doesn't work. I think it's not a coding problem but more a how to do things kind of problem.
I am running the Test.java from here: org.eclipse.xtext.example.domainmodel\src\org\eclipse\xtext\ example\Test.java
Directly in the domainmodel, because the generated classes are there available. Maybe this is the wrong way??
Isn't there a full tutorial that covers the "whole way" of working with a DSL in xtext?? That truly would be great.
Regards, Robin
Re: Loading a resource [message #654257 is a reply to message #654227] Mon, 14 February 2011 14:19 Go to previous messageGo to next message
hi,
can you share a runnable example
~Christian
Re: Loading a resource [message #654820 is a reply to message #654257] Thu, 17 February 2011 05:00 Go to previous messageGo to next message
Well, OK, there isn't much, but I put the workspace and the runtime directory in an archive:
http://dl.dropbox.com/u/5602365/workspace_and_runtime.zip
My configuration is set up like this:
- the workspace is located on my machine at: C:\eclipsew
- the runtime environment is located on my machine at: C:\runtime-EclipseApplication
- eclipse-SDK-3.6-xtext-1.0.1-win32 is installed at: C:\eclipse
The test files are:
C:\eclipsew\org.eclipse.xtext.example.domainmodel\src\org\ec lipse\xtext\example\Test.java
and
C:\eclipsew\org.eclipse.xtext.example.domainmodel\src\org\ec lipse\xtext\example\Test2.java
Test.java is very messy and contains a lot of trying out but mostly just commented out code, Test2.java is the one with the code Christian provided.
Thanks for having a look!
Regards, Robin
Re: Loading a resource [message #654957 is a reply to message #654820] Thu, 17 February 2011 13:18 Go to previous messageGo to next message
the problem is simple but hard to find Smile you file extension is "dmodel " (ending with a blank) but your files have od course the extension "dmodel". so changing your workflow to
var grammarURI = "classpath:/org/eclipse/xtext/example/Domainmodel.xtext"
var file.extensions = "dmodel"
var projectName = "org.eclipse.xtext.example.domainmodel"
var runtimeProject = "../${projectName}"
might solve the problems Wink Note: you may have to merge plugin.xml and plugin.xml_gen
Feel free to file an enhancement request for a validation rule that complains on whitespace in the file extension.
~Christian
[Updated on: Thu, 17 February 2011 13:19] by Moderator
Re: Loading a resource [message #657564 is a reply to message #654957] Thu, 03 March 2011 05:15 Go to previous messageGo to next message
I 'd know if the org.eclipse.xtext.example.domainmodel.DomainModel interface is generated automatically or added manually because I don't find it in my project after generation in the src-gen folder
thanks
Re: Loading a resource [message #659956 is a reply to message #657564] Wed, 16 March 2011 07:13 Go to previous messageGo to next message
Christian, thank you so much. It works now. I just changed
var file.extensions = "dmodel "
to
in GenerateDomainmodel.mwe2.
@Faiez: I have the DomainModel.java interface in org.eclipse.xtext.example.domainmodel belonging to the src-gen folder. So it is generated automatically.
Regards, Robin
Re: Loading a resource [message #901064 is a reply to message #659956] Thu, 09 August 2012 11:17 Go to previous messageGo to next message
That's the key......change the extension
But why?
I read the xtext tutorial again and again but not find the source......
Robin wrote on Wed, 16 March 2011 07:13
to
Regards, Robin
Re: Loading a resource [message #901071 is a reply to message #901064] Thu, 09 August 2012 11:33 Go to previous message
Having a trailing blank got a big mess with internal registries -
giving a blank as file extension does not work in most OS but in java
storing it as a key in a hash map does work well
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Previous Topic:SyntacticSequencer
Next Topic:Xtext standalone application beginner tutorial
Current Time: Thu Jul 24 23:09:57 EDT 2025
Powered by FUDForum. Page generated in 0.08170 seconds
