Home » Archived » BIRT » Report Query Parameters
Report Query Parameters [message #646712] Thu, 30 December 2010 06:33 Go to next message
hello,
i have designed a BIRT report using dataset which uses following query to retrieve data.
SELECT account_code, description FROM ac_account WHERE status = ?
this filter parameter works fine while designing the report,
(i.e. the preview tab generates desired report according to the parameter values we provide)
also, we can preview the report in web-viewer using [Run -> View Report -> 1 In Web Browser] while designing the report.
finally, we save this report in [C:/insight/birt/ws/ac_account_codes.rptdesign]
however, when trying to invoke this report from RCP client application using web viewer;
the following method generates an error
METHOD :
final String reportFilePath = "C:/insight/birt/ws/ac_account_codes.rptdesign";
final HashMap reportParams = new HashMap();
final HashMap emitterParams = new HashMap();
reportParams.put("SERVLET_NAME_KEY", "frameset");
reportParams.put("FORMAT_KEY", "html");
reportParams.put("MAX_ROWS_KEY", "500");
reportParams.put("ALLOW_PAGE", "true");
reportParams.put("SHOW_PARAMETER_PAGE", "false");
reportParams.put("account_code_from", null);
emitterParams.put("Top Count", "100");
reportParams.put("EMITTER_OPTIONS_KEY", emitterParams);
WebViewer.display(reportFilePath, browser, reportParams);
ERROR
The following items have errors:
Table (id = 163):
- Can not load the report query: 163. Errors occurred when generating the report document for the report element with ID 163.
Error.ReportQueryLoadingError2 ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Can not load the report query: 163. Errors occurred when generating the report document for the report element with ID 163.
at org.eclipse.birt.report.engine.data.dte.DataPresentationEngi ne.doExecuteQuery(DataPresentationEngine.java:160)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1876)
at org.eclipse.birt.report.engine.internal.document.v4.ReportIt emExecutor.executeQuery(ReportItemExecutor.java:412)
at org.eclipse.birt.report.engine.internal.document.v4.TableIte mExecutor.doExecute(TableItemExecutor.java:72)
at org.eclipse.birt.report.engine.internal.document.v4.ReportIt emExecutor.execute(ReportItemExecutor.java:294)
at org.eclipse.birt.report.engine.internal.document.v4.Containe rExecutor.prepareChildExecutor(ContainerExecutor.java:226)
at org.eclipse.birt.report.engine.internal.document.v4.Containe rExecutor.hasNextChild(ContainerExecutor.java:110)
at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.hasNextChild(WrappedReportItemExecutor.j ava:86)
at org.eclipse.birt.report.engine.api.impl.RenderTask$ReportExe cutorWrapper.hasNextChild(RenderTask.java:782)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM$1.hasN extChild(HTMLPageLM.java:68)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:62)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRange Render.render(RenderTask.java:662)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(Re nderTask.java:284)
at org.eclipse.birt.report.service.ReportEngineService.renderRe port(ReportEngineService.java:1537)
at org.eclipse.birt.report.service.BirtViewerReportService.getP age(BirtViewerReportService.java:204)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.doExecution(AbstractGetPageActionHandler.java :238)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.__execute(AbstractGetPageActionHandler.java:1 05)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(AbstractBaseComponentProcessor .java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPage(BirtDocumentProcessor.java:87)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(AbstractBaseComponentProcessor.java: 112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:318)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl er.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl er.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapp er.java:152)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(Http Connection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr eadPool.java:582)
Re: Report Query Parameters [message #646756 is a reply to message #646712] Thu, 30 December 2010 13:18 Go to previous message
hello everyone,
i forgot to include the following in required plugins :
org.eclipse.birt.report.data.oda.jdbc
it's finally working. BIRT is great !
let me try this with RAP next..
regards,
sudesh
Previous Topic:Alignment of labels for meter chart
Next Topic:BIRT + RAP + WebViewer
Current Time: Wed Jul 23 04:06:04 EDT 2025
Powered by FUDForum. Page generated in 0.06949 seconds
