emf.Ecore2Java Ant task is flaky [message #646586] |
Tue, 28 December 2010 20:04  |
Hi all,
we're using the emf.Ecore2Java task in an external tools builder to generate the Java sources from a .genmodel file. Unfortunately, the task is producing somewhat inconsistent results and works only half of the time, it seems.
There is an Ant target that deletes the src-gen folder when the .ecore or .genmodel file is updated and another target that regenerates the src-gen folder if it is not present:
<target name="generate" depends="check-rebuild" unless="already-exists">
<mkdir dir="src-gen"/>
<eclipse.refreshLocal resource="com.intuit.eclipse.emf.tps.formset" depth="infinite"/>
<emf.Ecore2Java genmodel="model/formset.genmodel" reconcileGenModel="keep"
generateJavaCode="true"
generatetestsproject="false"
generateeditproject="false"
generateeditorproject="false"
generatemodelproject="true"
modelproject="com.intuit.eclipse.emf.tps.formset"
modelpluginid="com.intuit.eclipse.emf.tps.formset"
modelprojectfragmentpath="src-gen">
<model file="model/formset.ecore"/>
</emf.Ecore2Java>
</target>
First of all, without the eclipse.refreshLocal, the emf.Ecore2Java would report that it was generating all the source files, but the src-gen folder would still be empty after the task finished. Only when running the task a second time (?!) the src-gen folder was properly populated. Luckily (though somewhat inexplicably), adding the eclipse.refreshLocal task fixed that.
Now I have the problem that only a part of the sources is generated sometimes. Especially, the .util package with the base implementations of resources and resource factories often remains incomplete (i.e., a couple sources are generated while others are missing) after the project was just imported into the workspace. There are no indications on the console that would indicate that emf.Ecore2Java ran into any kind of trouble during execution, and the Ant build finishes successfully, so I'm not sure how to debug this.
Any ideas what's going here or how I could further debug this? I'm already running Ant with -d but nothing out of the ordinary is reported.
Mirko
Re: emf.Ecore2Java Ant task is flaky [message #646588 is a reply to message #646586] |
Tue, 28 December 2010 20:23   |
Mirko,
Comments below.
Mirko Raner wrote:
> Hi all,
> the time, it seems.
Which half? :-P
> depth="infinite"/>
> </emf.Ecore2Java>
> </target>
If the workspace is updated "externally" a refresh is needed to get the
state back in sync... Are there any problems reported in the error log?
> properly populated.
I suppose something in the first attempt is doing a refresh.
I imagine if there are failures, they'd be recorded in the error log.
Given that the generator is more generally running within the IDE,
writing to System.out/err wouldn't normally be a good way to inform the
user...
The error log; <workspace>/.metadata/.log, is likely to yield
informative traces.
> Mirko
Re: emf.Ecore2Java Ant task is flaky [message #646597 is a reply to message #646592] |
Tue, 28 December 2010 22:28   |
Mirko,
It sounds like the generator is trying to load dynamic templates.
You're making use of dynamic templates? Maybe a task that removes the
hidden .JETEmitters project so it can be regenerated cleanly will help...
Mirko Raner wrote:
> Good point, Ed! I forgot that emf.Ecore2Java actually runs inside the
> IDE and did not check the workspace log.
> There are a couple of warnings like this in the log:
> org.eclipse.emf.common.util.WrappedException:
> org.eclipse.emf.codegen.jet.JETException: ClassNotFoundException:
> org.eclipse.emf.codegen.ecore.templates.model.FactoryClass_
> at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAda
> pter.generateJava(AbstractGeneratorAdapter.java:1112)
> at org.eclipse.emf.codegen.ecore.genmodel.generator.GenPackageG
> eneratorAdapter.generateFactoryInterface(GenPackageGenerator
> Adapter.java:520)
> eneratorAdapter.generateModel(GenPackageGeneratorAdapter.jav a:220)
> at org.eclipse.emf.codegen.ecore.genmodel.generator.GenBaseGene
> ratorAdapter.doGenerate(GenBaseGeneratorAdapter.java:221)
> pter.generate(AbstractGeneratorAdapter.java:290)
> at org.eclipse.emf.codegen.ecore.generator.Generator.generate(G
> enerator.java:617)
> enerator.java:528)
> at org.eclipse.emf.codegen.ecore.Generator$PlatformRunnable$1.r
> un(Generator.java:424)
> at org.eclipse.core.internal.resources.Workspace.run(Workspace.
> java:1975)
> java:1957)
> at org.eclipse.emf.codegen.ecore.Generator$PlatformRunnable.run
> (Generator.java:458)
> at org.eclipse.emf.codegen.ecore.Generator.run(Generator.java:1 17)
> at org.eclipse.emf.ant.taskdefs.codegen.ecore.GeneratorTask.gen
> erateCodeFromGenModel(GeneratorTask.java:531)
> at org.eclipse.emf.ant.taskdefs.codegen.ecore.GeneratorTask.doE
> xecute(GeneratorTask.java:394)
> at org.eclipse.emf.ant.taskdefs.EMFTask.execute(EMFTask.java:76 )
> at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce
> ssorImpl.java:39)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe
> thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch
> Utils.java:106)
> at org.apache.tools.ant.Task.perform(Task.java:348)
> at org.apache.tools.ant.Target.execute(Target.java:357)
> at org.apache.tools.ant.Target.performTasks(Target.java:385)
> at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1337)
> at org.apache.tools.ant.Project.executeTarget(Project.java:1306 )
> at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D
> efaultExecutor.java:41)
> at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe
> cuteTargets(EclipseDefaultExecutor.java:32)
> at org.apache.tools.ant.Project.executeTargets(Project.java:118 9)
> at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte
> rnalAntRunner.java:662)
> rnalAntRunner.java:495)
> ssorImpl.java:39)
> at org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
> at org.eclipse.ant.internal.launching.launchConfigurations.AntL
> aunchDelegate.runInSameVM(AntLaunchDelegate.java:321)
> aunchDelegate.launch(AntLaunchDelegate.java:274)
> at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L
> aunchConfiguration.java:853)
> aunchConfiguration.java:702)
> aunchConfiguration.java:695)
> at org.eclipse.core.externaltools.internal.model.ExternalToolBu
> ilder.launchBuild(ExternalToolBuilder.java:181)
> ilder.doBuildBasedOnScope(ExternalToolBuilder.java:169)
> ilder.build(ExternalToolBuilder.java:88)
> at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan
> ager.java:629)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui
> ldManager.java:172)
> ldManager.java:203)
> at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan
> ager.java:255)
> ldManager.java:258)
> at org.eclipse.core.internal.events.BuildManager.basicBuildLoop
> (BuildManager.java:311)
> at org.eclipse.core.internal.events.BuildManager.build(BuildMan
> ager.java:343)
> at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu
> ildJob.java:144)
> at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ
> ob.java:242)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
> Caused by: org.eclipse.emf.codegen.jet.JETException:
> at org.eclipse.emf.codegen.jet.JETEmitter$EclipseHelper.initial
> ize(JETEmitter.java:883)
> at org.eclipse.emf.codegen.jet.JETEmitter.initialize(JETEmitter
> .java:397)
> at org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.j ava:459)
> pter.generateJava(AbstractGeneratorAdapter.java:981)
> .. 55 more
> Caused by: java.lang.ClassNotFoundException:
> at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
> at java.security.AccessController.doPrivileged(Native Method)
> at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:319)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:254)
> at org.eclipse.emf.codegen.jet.JETEmitter$EclipseHelper$3.loadC
> lass(JETEmitter.java:841)
> ize(JETEmitter.java:861)
> .. 58 more
> The affected class varies, though. In the log there are entries that
> report ValidatorClass_, XMLProcessorClass_, FactoryClass_, EnumClass_,
> or simply Class_ to be not found. So, apparently, this has to do with
> the generated .JETEmitters project.
Re: emf.Ecore2Java Ant task is flaky [message #646683 is a reply to message #646597] |
Wed, 29 December 2010 16:14  |
Indeed we're making use of dynamic templates. However, that was used only as a work-around for bug 317549, which is fixed for EMF 2.6.1. Since our product requires Helios SR1 anyway, we removed the dynamic templates.
For now, it seems that this change has made the problem disappear (though, I can't be sure yet because the problem was pretty intermittent to begin with).
Thanks a lot for the hints! I'll report back if the issue reoccurs or other problems start popping up.
FUDForum. Page generated in 0.08269 seconds
