Home » Archived » M2M (model-to-model transformation) » [ATL] Not updated transformation.
[ATL] Not updated transformation. [message #646322] Thu, 23 December 2010 05:50 Go to next message
Hi all,
while I was workin' on an ATL transformation, it happened a strange thing:
my Eclipse seems to execute always the same transformation, independently from my modifications.
Each modification I make doesn't effect the transformation execution, so it seems to execute the same version of the transformation. But the .atl file is effectively modified, so I don't understand why the output is always the same. This is an original problem for me, because I've never met it. There's someone who could help me, please?
Many thanks in advance,
Dave.
Re: [ATL] Not updated transformation. [message #646335 is a reply to message #646322] Thu, 23 December 2010 06:09 Go to previous messageGo to next message
Dave <davewilson@hotmail.it> writes:
Hey Dave,
> thing: my Eclipse seems to execute always the same transformation,
Hm, just a blind guess: Since ATL doesn't execute the ATL file but the
ASM file that is compiled from the ATL file, I'd say that this
compilation somehow fails.
But I have no clue how to fix that...
Bye,
Tassilo
Dipl.-Inform. Tassilo Horn | Room: B015
University of Koblenz-Landau, Campus Koblenz | Phone: +49 (261) 287-2745
Institute for Software Technology | Mail: horn@uni-koblenz.de
Universitätsstr. 1, 56070 Koblenz, Germany |
Re: [ATL] Not updated transformation. [message #646340 is a reply to message #646322] Thu, 23 December 2010 07:17 Go to previous messageGo to next message
Le 23/12/2010 11:51, Dave a écrit :
> Hi all,
> Dave.
It seems your ATL file is not compiled.
Check if your project:
- has the ATL nature
- has the ATL builder in its list
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: [ATL] Not updated transformation. [message #646345 is a reply to message #646340] Thu, 23 December 2010 07:32 Go to previous messageGo to next message
Hi guys, thanks for your replies!
The .project file is the following:
<projectDescription>
	<name>SDs2EGs</name>
	<comment></comment>
	<projects>
	</projects>
	<buildSpec>
		<buildCommand>
			<name>org.eclipse.m2m.atl.adt.builder.atlBuilder</name>
			<arguments>
			</arguments>
		</buildCommand>
	</buildSpec>
	<natures>
		<nature>org.eclipse.m2m.atl.adt.builder.atlNature</nature>
	</natures>
</projectDescription>
So, I think both the atl nature and the atl builder are verified.
Some other suggetions?
Dave.
Re: [ATL] Not updated transformation. [message #646351 is a reply to message #646345] Thu, 23 December 2010 07:59 Go to previous messageGo to next message
Hi Dave
> <comment></comment>
> <projects>
> </projects>
> <buildSpec>
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> </buildSpec>
> <natures>
> </natures>
Looks correct.
The first thing I'd do is check if a change to the ATL file causes a
change to the ASM file. If yes, then compiling seems to work, if not,
well, then not, but don't ask me why.
Bye,
Tassilo
Re: [ATL] Not updated transformation. [message #646355 is a reply to message #646351] Thu, 23 December 2010 08:24 Go to previous messageGo to next message
I've tried to do the following thing:
I had an older version of my project, so I've pasted the new version of my .atl file in the older version, for verifying if the old .asm file was affected by changes. The result was that the transformation gives the same output of the older version. I deduced that the .asm file has not been changed.
The thing that surprise me is that this problem arised from one day to the next...
Dave.
Re: [ATL] Not updated transformation. [message #646360 is a reply to message #646355] Thu, 23 December 2010 08:54 Go to previous messageGo to next message
Le 23/12/2010 14:24, Dave a écrit :
> Quote:
> not been changed.
> the next...
> Dave.
Verify in the properties dialog of your project that on 'Builders' page
the ATL builder is checked
Cordialement
Vincent MAHÉ
Re: [ATL] Not updated transformation. [message #646366 is a reply to message #646360] Thu, 23 December 2010 09:40 Go to previous messageGo to next message
Hi all and thanks for your fast replies Smile
I think I solved my issue.
There was an ATL code-block having some syntactic and/or semantic problems, but they wasn't detected by the compiler; so, the asm file wasn't updated when saving the atl file.
Deleting that piece of code, the asm was compiled correctly.
If I'll have some other issues, I'll not hesitate to ask you some helps.
Many thanks for your time and consideration,
Dave.
Re: [ATL] Not updated transformation. [message #646382 is a reply to message #646366] Thu, 23 December 2010 10:06 Go to previous messageGo to next message
Hi Dave,
I think it would be helpful if you provided the devs the problematic
code block.
Bye,
Tassilo
Re: [ATL] Not updated transformation. [message #646415 is a reply to message #646382] Thu, 23 December 2010 15:48 Go to previous messageGo to next message
Hi Tassilo,
code block.
I'll provide the code-block in the next days.
Bye,
Dave.
Re: [ATL] Not updated transformation. [message #647646 is a reply to message #646415] Fri, 07 January 2011 09:54 Go to previous message
I think that was an error dependig by my insufficient experience with ATL, so it couldn't be helpful to provide the problematic code-block.
Dave.
Previous Topic:[ATL]Unable to access name on OclUndefined
Next Topic:[QVTO] Problems using more than one qvto library.
Current Time: Sat Jul 19 03:59:41 EDT 2025
Powered by FUDForum. Page generated in 0.05002 seconds
