Home » Eclipse Projects » Virgo » Tests using Virgo Test Framework
Tests using Virgo Test Framework [message #646309] Thu, 23 December 2010 04:45 Go to next message
Dear Virgo team,
I am trying to implement integration tests over the Virgo test framework.
Is start a very basic unit test :
import org.eclipse.virgo.test.framework.dmkernel.DmKernelTestRunner;
import org.junit.Assert;
import org.junit.Test;
import org.junit.runner.RunWith;
@RunWith(DmKernelTestRunner.class)
public class IntegrationTest {
	@Test
	public void RunFirstTest() {
		Assert.assertTrue(true);
As simple as it is, I am not able to run this test. When starting, I get the following error :
java.lang.NoClassDefFoundError: org/osgi/framework/launch/Framework
	at java.lang.Class.getDeclaredMethods0(Native Method)
	at java.lang.Class.privateGetDeclaredMethods(Class.java:2427)
	at java.lang.Class.privateGetPublicMethods(Class.java:2547)
	at java.lang.Class.getMethods(Class.java:1410)
	at sun.misc.ProxyGenerator.generateClassFile(ProxyGenerator.java:409)
	at sun.misc.ProxyGenerator.generateProxyClass(ProxyGenerator.java:306)
	at java.lang.reflect.Proxy.getProxyClass(Proxy.java:501)
	at java.lang.reflect.Proxy.newProxyInstance(Proxy.java:581)
	at org.eclipse.virgo.test.framework.plugin.PluginManager.<init>(PluginManager.java:28)
	at org.eclipse.virgo.test.framework.OsgiTestRunner.<init>(OsgiTestRunner.java:42)
	at org.eclipse.virgo.test.framework.dmkernel.DmKernelTestRunner.<init>(DmKernelTestRunner.java:41)
	at org.eclipse.virgo.test.framework.dmkernel.DmKernelTestRunner.<init>(DmKernelTestRunner.java:37)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
	at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
	at org.junit.internal.builders.AnnotatedBuilder.buildRunner(AnnotatedBuilder.java:31)
	at org.junit.internal.builders.AnnotatedBuilder.runnerForClass(AnnotatedBuilder.java:24)
	at org.junit.runners.model.RunnerBuilder.safeRunnerForClass(RunnerBuilder.java:57)
	at org.junit.internal.builders.AllDefaultPossibilitiesBuilder.runnerForClass(AllDefaultPossibilitiesBuilder.java:29)
	at org.junit.internal.requests.ClassRequest.getRunner(ClassRequest.java:24)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.<init>(JUnit4TestReference.java:32)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestClassReference.<init>(JUnit4TestClassReference.java:25)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.createTest(JUnit4TestLoader.java:41)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.loadTests(JUnit4TestLoader.java:31)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:452)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Caused by: java.lang.ClassNotFoundException: org.osgi.framework.launch.Framework
	at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
	at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
	... 30 more
I tried to look around for the bundle exporting the class org.osgi.framework.launch.Framework, but didn't found it. Maybe this is where the error come from...
Any help would be appreciated.
Regards.
Re: Tests using Virgo Test Framework [message #646314 is a reply to message #646309] Thu, 23 December 2010 05:03 Go to previous messageGo to next message
I added org.eclipse.osgi to my POM dependencies.
The error now is a bit different :
java.lang.IllegalStateException: User region's bundle context was not available from the service registry within 60 seconds.
	at org.eclipse.virgo.test.framework.dmkernel.DmKernelTestRunner.getTargetBundleContext(DmKernelTestRunner.java:60)
	at org.eclipse.virgo.test.framework.OsgiTestRunner.run(OsgiTestRunner.java:69)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:49)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
Re: Tests using Virgo Test Framework [message #646318 is a reply to message #646314] Thu, 23 December 2010 05:28 Go to previous messageGo to next message
Sorry for the spaming.. As usual, as soon as you post a question, you get a bit of answer by yourself.
I have solved my problem by fixing my test.config.properties file in resources/META-INF folder.... (the launcher.bundles property was set with non accessible paths)..
Re: Tests using Virgo Test Framework [message #651348 is a reply to message #646318] Sat, 29 January 2011 12:50 Go to previous messageGo to next message
Lorie,
Could you please share the tests that you've developed with virgo test framework?
Re: Tests using Virgo Test Framework [message #651551 is a reply to message #651348] Mon, 31 January 2011 10:53 Go to previous messageGo to next message
Sorry Wesley, but I don't have much to share. I didn't get very far with the test framework (no much farer than launching a test method...).
Re: Tests using Virgo Test Framework [message #651554 is a reply to message #646309] Mon, 31 January 2011 11:08 Go to previous messageGo to next message
I would appreciate if you share even this as I can't succeed with this.
Re: Tests using Virgo Test Framework [message #654872 is a reply to message #651554] Thu, 17 February 2011 08:38 Go to previous message
Sorry for the (very) late answer. Did you get farer with the test framework?
Basically, all my code is already in the post.. What exactly is the problem running your tests?
Previous Topic:[FYI] log4j-1.2.16 has a duplicate import-package entries
Next Topic:Virgo as NT Service or Unix deamon using Java Service Wrapper
Current Time: Sun Jul 27 07:32:14 EDT 2025
Powered by FUDForum. Page generated in 0.04089 seconds
