Home » Language IDEs » PHP Development Tools (PDT) » Using Code Help after loading class with Doctrine_Core::getClass
Using Code Help after loading class with Doctrine_Core::getClass [message #642134] Mon, 29 November 2010 22:14 Go to next message
Hello!
I'm starting with Doctrine and Eclipse. Suppose that I have a model called Product.php with a getLastPrice() method. After I have instanciated the Product class, is it possible to make the code help show the methods of the loaded class? I'm using a Bootstrap.php file to store the Doctrine configurations, and those configurations load automatically (at runtime) the model classes and the Doctrine classes.
I'm doing this:
// This file make auto load the models classes and the Doctrine classes
require('DoctrineBootstrap.php');
$Product = Doctrine_Core::getClass('Product');
After this, I would like to write "$Product->" and then the code help of Eclipse should show me the list of available methods (in the example above, the getLastPrice() method).
Anyone know if is it possible?
One more information: if I do:
require('models/Product.php');
$Product = new Product();
The code help work as expected.
Thanks!
Juliano
Re: Using Code Help after loading class with Doctrine_Core::getClass [message #642662 is a reply to message #642134] Thu, 02 December 2010 03:57 Go to previous messageGo to next message
Add type comment as...
/* @var $Product Product */
$Product->
See also
Help > PDT User Guide > Concepts > Content Assist > Class Type Hints
Re: Using Code Help after loading class with Doctrine_Core::getClass [message #642691 is a reply to message #642662] Thu, 02 December 2010 06:40 Go to previous messageGo to next message
Hello Toshihiro!
It is exactly what I wanted. Thanks a lot!
Juliano
Re: Using Code Help after loading class with Doctrine_Core::getClass [message #646169 is a reply to message #642134] Wed, 22 December 2010 08:40 Go to previous message
On 2010-11-30 04:14, Juliano wrote:
> I'm doing this:
Doctrine will generate classes for each model and it's table, so You should be
able to type:
$product = new Product();
Then Eclipse will know what class is that.
dmc :)
Previous Topic:Web service Debugging?
Next Topic:XDebug JIT Breaking on first line of code
Current Time: Thu Jul 17 07:56:55 EDT 2025
Powered by FUDForum. Page generated in 0.05376 seconds
