Re: AspectJ LTW with Virgo [message #646168 is a reply to message #646155] |
Wed, 22 December 2010 09:00   |
Hello Frieder,
IANAE, but some thoughts here:
1. adding anything to the /lib folder will add that jar to the -cp of the java processes starting the framework/virgo
2. did you remove prior version of aspectj (com.springsource.org.aspectj.weaver-1.6.6.RELEASE.jar) from /repository/ext?
Virgo is split into two regions with support from embedded frameworks. You are deploying aspectj libraries and supporting libraries in kernel region. Depending on how you deploy your aspect bundle (assuming drop into pickup/or web interface) , it might not see required bundles or might get bound to a different instances of bundles. So there might be some classloading issues internally that are stoping aspect from working. These classloading issues might not be visible in logs, that is if there are checks like this:
if (object instaceof SomeClass) {
// do work
// otherwise don't do anything
Because object.class was loaded from userregion and SomeClass was loaded by kernel region - different classloader, instanceof will be false. Even if class.getName is the same for both.
Take a look in /config/org.eclipse.virgo.kernel.userregion.properties specifically at packageImports property. That property specifies packages that are exported from kernel into user region. org.aspectj.* is part of that list, but you might need others.
Also if you don't mind - can you create a bugzilla issue and attach your aspect bundle to it, including detailed steps to recreate. You gave a greave overview in this post, but if you could provide a more detailed instructions (if any) it would help also. For example, what do you mean by this comment:
Dmitry
Re: AspectJ LTW with Virgo [message #647446 is a reply to message #646177] |
Thu, 06 January 2011 07:55   |
Hi guys,
thx for your input on this topic. Unfortunately I was not able to get this working so far.
@Dmitry
Quote: | 2. did you remove prior version of aspectj (com.springsource.org.aspectj.weaver-1.6.6.RELEASE.jar) from /repository/ext?
Not until you asked me about that. Now I did but no change, still no output from the Aspect.
I meant that in the bundle there was an optional import statement with version 1.6.3 and I changed that to 1.6.8 (in fact I changed that to [1.6,1.7)). Not sure if that is necessary at all but wanted to be sure. I filed a bug, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=333646. To avoid difficulties I did not change any of the bundles except the provided sample bundles.
@Glyn
Quote: | One thing that looks a little wrong is the way you handle the AspectJ bundles. There is a lot of overlap between the weaver and runtime bundles and I doubt that you need then both.
You are right. I am used to using the AspectJ bundles that are shipped with the Eclipse AJDT installation (building my own OSGi-ready bundles to have the latest AspectJ/AJDT version available and to avoid version incompabilities) and there the Eclipse (AJDT?) team has two different bundles (runtime/weaver) with different packages (no overlap at all). I was not aware that the AspectJ libraries (and therefore the SpringSource EBR bundles too) follow a different approach than the bundles from the AJDT plugin (wondering what might be the reason for that). Thx for the hint.
Quote: | Also the packages org.aspectj.* are imported from the kernel region into the user region, so I doubt that you need to put the AspectJ bundle(s) in repository/ext.
Again thx for the info. The reason why I did that is because the weaver bundle from the kernel folder (com.springsource.org.aspectj.weaver-1.6.6.RELEASE.jar) is also available in repository/ext by default and therefore I thought that it is necessary to put the bundles there (Is there a reason why it is in the ext folder when all packages are exported to the user region anyways?). Another reason is that the Equinox Aspects quick start guide mentions the following: Use Require-Bundle to declare a dependency on org.aspectj.runtime and re-export this dependency. which requires the bundle to be in some repository folder (not sure if package import would be sufficient in this case, tried it but does not work either). Btw it looks like Spring IDE does not recognize any packages that are exported automatically from the lib/ folder as it keeps showing error markers stating that some package imports cannot be resolved. Hope that gets fixed once the tooling has been donated to Eclipse.
Any help for this issue is highly appreciated. Thank you guys.
Frieder
Re: AspectJ LTW with Virgo [message #647931 is a reply to message #647906] |
Mon, 10 January 2011 09:00   |
Frieder Heugel wrote on Mon, 10 January 2011 12:09 | Hi Glyn,
Thank you for the information.
You're welcome.
Quote: |
Glyn Normington wrote on Mon, 10 January 2011 04:40 |
Would you care to raise an enhancement bug to cover this as it may be a reasonable candidate for Virgo 3.0?
Done, see Bug 333855.
Thanks.
Quote: |
Glyn Normington wrote on Thu, 06 January 2011 08:54 | Quote: | Btw it looks like Spring IDE does not recognize any packages that are exported automatically from the lib/ folder as it keeps showing error markers stating that some package imports cannot be resolved. Hope that gets fixed once the tooling has been donated to Eclipse.
Me too, but you may like to raise a bug on this to increase the chances.
Could you please tell me where to raise that bug? Do I have to use https://jira.springframework.org/browse/IDE or is there already some place on the Eclipse website for that?
Since the Virgo tooling is being donated to Eclipse under the Virgo project, please raise the bug against Virgo.
The current user region design does not allow kernel bundles to be imported into the user region and so require-bundle won't work. I am currently looking at removing this restriction for the next release. Meanwhile, I'm afraid you'll have to make do with multiple package imports.
Could you please give me an estimate when you are planing to do that? Will it be available in the next milestone release? I am asking because at the moment I am stuck with this issue and the missing Require-Bundle header is the only reason I can think of right now that might be preventing the aspect from being executed properly. I think having AspectJ LTW support in a runtime environment like Virgo would be a really nice feature and is a perfect match with the modular characteristics of OSGi.
It might make the next milestone, but there's quite a lot of work remaining to get the prototype on the branch into good shape and add this feature. Meanwhile, I am going to take an initial look at bug 333646 in this week's sprint.
FUDForum. Page generated in 0.92254 seconds
