Home » Eclipse Projects » Plugin Development Environment (PDE) » execute the 'Build site' of site.xml via command line(site.xml Build site automation)
execute the 'Build site' of site.xml via command line [message #646077] Tue, 21 December 2010 16:27 Go to next message
is it possible to execute the 'Build site' of site.xml via command line?
i want to run the "Build site" of my site.xml in the Update Site project via command line.
thanks
Stefania
Re: execute the 'Build site' of site.xml via command line [message #660974 is a reply to message #646077] Tue, 22 March 2011 10:33 Go to previous message
this forum has been taken care in another
http://www.eclipse.org/forums/index.php?t=msg&goto=64621 8&S=5d35a84bde8e48f34eb9e4380124d30a#msg_646218
thanks to help of Paul Webster
with eclipse 3.5 i am able to build of feature project that contains 2 plugin projects . The build will generated the feature jar and with the p2 metadata y artifacts.xml and content.xml.
no site.xml update.
thanks
stefania
Previous Topic:Language keys in plugin.xml are not found when plugin is installed
Next Topic:change/add item images for exclusive menu item from editor
Current Time: Sat Jul 26 10:11:12 EDT 2025
Powered by FUDForum. Page generated in 0.06453 seconds
