Home » Archived » BIRT » DataException: The new column name or alias...
DataException: The new column name or alias... [message #646002] Tue, 21 December 2010 09:35 Go to next message
Hi all,
what does this error message means?
"The new column name or alias abc is already used by the column at index x"
I get this message several times when I run my report against another database, not the one used to create the report. The tables are identical but the column order is different.
I'm using Birt 2.5.2.
Please help
Helmut
[Updated on: Tue, 21 December 2010 09:57] by Moderator
Re: The new column name or alias... [message #646021 is a reply to message #646002] Tue, 21 December 2010 10:33 Go to previous messageGo to next message
Does the dataset have an alias on the columns?
Jason
On 12/21/2010 9:35 AM, swaczinna@wlp-systems.de wrote:
> Hi all,
> what does this error messager maens?
> Please help
> Regards
> Helmut
Re: The new column name or alias... [message #646039 is a reply to message #646021] Tue, 21 December 2010 12:06 Go to previous messageGo to next message
Hi Jason!
No, the query ist really simple:
select *
from hsverf_dreh
where hsv_f_pan = ?
and hsv_geloescht = 0
order by hsv_sort
In the meantime I found a workaround. I listed all columns in the select clause instead of using *. Now the column order is always the same. But using * is more convenient. I would think of a bug in BIRT 2.5.2.
Helmut
Re: The new column name or alias... [message #646052 is a reply to message #646039] Tue, 21 December 2010 13:07 Go to previous messageGo to next message
This sounds like a bug. Can you log it?
Jason
On 12/21/2010 12:06 PM, swaczinna@wlp-systems.de wrote:
> Hi Jason!
> select *
> from hsverf_dreh
> where hsv_f_pan = ?
> order by hsv_sort
> Regards
> Helmut
Re: The new column name or alias... [message #1800546 is a reply to message #646052] Wed, 02 January 2019 02:09 Go to previous message
Found walk around.
Copy and Paste the same Date Source.
Then Double click the Data Set.
Go to Date Source Tab.
Change it to New Date Source.
Save.
Again Double click the Data Set.
Change it to Old Date Source.
Save.
Report worked for me.
Previous Topic:Report Generation not working when creating a WAR
Next Topic:Calculate Cumulative value in cross tab
Current Time: Wed Jul 23 17:32:11 EDT 2025
Powered by FUDForum. Page generated in 0.31656 seconds
