Home » Modeling » EMF » URI Mapper example - resolve proxy: platform:/model
URI Mapper example - resolve proxy: platform:/model [message #645833] |
Mon, 20 December 2010 12:53  |
Hi @all,
can someone provide an example, how I can load an EMF with references to another meta model correctly?
My meta model (an UML extension) containst definitions like that:
<eClassifiers xsi:type="ecore:EClass" name="ClassExtension" eSuperTypes="platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Class">
I have the requirement to load my ecore file which contains the line above, and then I have to analyze all contained EClasses:
for ( Iterator<EObject> allIt = getResource().getAllContents(); allIt.hasNext(); ) {
EObject obj = (EObject) allIt.next();
if ( obj instanceof EClass ) {
EClass cl = (EClass) obj;
Unfortunately, the supertype can only be returned as proxy, e.g.
I need to resolve this proxy, and I don't know which is the best way, e.g. registering something before, so that the model is loading differently? Or is it good to resolve the proxy afterwards. However, I am not allowed to add the UML.ecore to any project (so "platform" has to be resolved somewhere).
Thanks in advance!
Re: URI Mapper example - resolve proxy: platform:/model [message #645852 is a reply to message #645833] |
Mon, 20 December 2010 14:17   |
Comments below.
vultur wrote:
> Hi @all,
Be sure to use an absolute URI to load the initial resource.
> eSuperTypes=" platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Clas s ">
Are you running this as an Equinox application? This URI will only work
if UML2 is installed in the running process...
> Thanks in advance!
Re: URI Mapper example - resolve proxy: platform:/model [message #645868 is a reply to message #645852] |
Mon, 20 December 2010 16:07   |
Comments below.
Ed Merks wrote:
> Comments below.
> vultur wrote:
> > Hi @all,
The initial ecore model (which then contains references like "eSuperTypes=" platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Clas s ") is loaded by the following code (the user selects an ecore file in a regular file chooser):
URI fileURI = URI.createURI(ecorePath.toURI().toString());
resource = resourceSet.getResource(fileURI, true);
resource.load(null);
> > My meta model (an UML extension) contains definitions like that:
No, I don't run an Equinox application.
I know that there is a problem resolving "platform:" then. However, this is the question I have: do I really have to build an equinox application (is this complicated again? I have much trouble anyway, so I want to avoid going further for such a "simple thing")? Or is there a solution with URI mapping, etc.?
> > Thanks in advance!
[Updated on: Mon, 20 December 2010 16:10] by Moderator
Re: URI Mapper example - resolve proxy: platform:/model [message #645880 is a reply to message #645868] |
Mon, 20 December 2010 17:31   |
Comments below.
vultur wrote:
> Comments below.
> Ed Merks wrote:
>> Comments below.
>> vultur wrote:
>> > Hi @all,
>> references > to another meta model correctly?
> The initial resource (my model) is loaded by the following code (the
What's a regular file? This isn't a workspace relative path for which
URI.createPlatformResourceURI should be used? (See FAQ)
>> <eClassifiers xsi:type="ecore:EClass" name="ClassExtension" >
>> eSuperTypes="
>> platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Clas s "> >
>> line > above, and then I have to analyze all contained EClasses:
>> > for ( Iterator<EObject> allIt = getResource().getAllContents(); >
>> work if UML2 is installed in the running process...
So that's not going to work well.
Yep.
You'll trade on simplicity for another. When you run an Equinox
application all the plugin.xml registrations kick and to help configure
everything. You'll have to do all that manually others.
Yes, you can use URI mappings to redirect these things into the jar
location. Is that sounding simpler?
>> way, > e.g. registering something before, so that the model is
>> loading > differently? Or is it good to resolve the proxy afterwards.
>> However, I > am not allowed to add the UML.ecore to any project (so
>> "platform" has > to be resolved somewhere).
>> > Thanks in advance!
Re: URI Mapper example - resolve proxy: platform:/model [message #646005 is a reply to message #645880] |
Tue, 21 December 2010 09:40   |
To be honest, it sounds simpler for my requirements (an application which runs in differenty model modes with/without EMF, with/without Eclipse). I have to configure everything in the plugin.xml correctly using Maven. And, but this is my own disability, sometimes I get stuck configuring the plugin.xml even within Eclipse.
On the other hand, I just have to get some kind of default path and can hopefully set-up a working URI mapping. But again: I have no idea how to get it working. I tested, but failed, so I wanted to ask the community how to resolve proxies correctly (before or after loading my "main" ecore file).
Re: URI Mapper example - resolve proxy: platform:/model [message #646043 is a reply to message #646005] |
Tue, 21 December 2010 12:03  |
You can read the URIConverter Javadoc about how to do URI mappings and
the Javadoc for ArchiveURLConnection for how to access archive contents.
>> thing")? You'll trade on simplicity for another. When you run an
>> Equinox application all the plugin.xml registrations kick and to help
>> configure everything. You'll have to do all that manually others.
> "main" ecore file).
Current Time: Sat Jul 19 00:09:17 EDT 2025
Powered by FUDForum. Page generated in 0.04093 seconds
