Home » Eclipse Projects » Remote Application Platform (RAP) » IDoubleClickListener(CheckboxTableViewer's IDoubleClickListener)
IDoubleClickListener [message #645778] Mon, 20 December 2010 10:02 Go to next message
hi,
i've experienced following error using IDoubleClickListener + CheckboxTableViewer combination in RAP. however the same works fine, when double click event is triggered from our single source RCP product, which uses the same code base.
also, it works as expected in RAP, when the method is invoked from toolbar event in RAP client.
i've tried to debug IDoubleClickListener event and surprisingly it works as expected during the debug mode, and when invoked several times repeatedly during debug mode, it produces the error message after few attempts.
METHOD :
_doubleClickListener = new IDoubleClickListener() {
public void doubleClick(final DoubleClickEvent event) {
if (_isRecordViewSupported) {
if (event.getSelection() != null) {
final IStructuredSelection selection = (IStructuredSelection) event
.getSelection();
if (selection.getFirstElement() != null) {
final DatasetGridRecordModel datasetGridRecordModel = (DatasetGridRecordModel) selection
.getFirstElement();
if (datasetGridRecordModel.getRecordId() != null) {
getDatasetBroadcast().notifyRecordView(
getName(),
new UUIDDataValue(
.getRecordId()));
ERROR MESSAGE :
Could not evaluate javascript response:
TypeError: Cannot call method '_render' of undefined
var wm = org.eclipse.swt.WidgetManager.getInstance();var w = wm.findWidgetById( "w554" );w.dispose();var w = wm.findWidgetById( "w555" );w.dispose();var w = wm.findWidgetById( "w556" );w.dispose();var w = wm.findWidgetById( "w557" );w.dispose();var w = wm.findWidgetById( "w558" );w.dispose();var w = wm.findWidgetById( "w559" );w.dispose();var w = wm.findWidgetById( "w560" );w.dispose();var w = wm.findWidgetById( "w561" );w.dispose();var req = org.eclipse.swt.Request.getInstance();req.setRequestCounter( "38" );wm.setToolTip( wm.findWidgetById( "w138" ), "Locked" );var w = wm.findWidgetById( "w138" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w139" );w.setEnabled( false );w.resetTextColor();w.setBackgroundColor( "#dcdfe4" );wm.setToolTip( wm.findWidgetById( "w141" ), "Locked" );var w = wm.findWidgetById( "w141" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w142" );w.setEnabled( false );w.resetTextColor();w.setBackgroundColor( "#dcdfe4" );wm.setToolTip( wm.findWidgetById( "w144" ), "Locked" );var w = wm.findWidgetById( "w144" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w145" );w.setEnabled( false );w.resetTextColor();w.setBackgroundColor( "#dcdfe4" );wm.setToolTip( wm.findWidgetById( "w147" ), "Locked" );var w = wm.findWidgetById( "w147" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w149" );w.setEnabled( false );w.resetTextColor();w.setBackgroundColor( "#dcdfe4" );var w = wm.findWidgetById( "w150" );w.setEnabled( false );w.resetTextColor();wm.setToolTip( wm.findWidgetById( "w152" ), "Locked" );var w = wm.findWidgetById( "w152" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w153" );w.setEnabled( false );w.resetTextColor();w.setBackgroundColor( "#dcdfe4" );wm.setToolTip( wm.findWidgetById( "w160" ), "Locked" );var w = wm.findWidgetById( "w160" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w162" );w.setEnabled( false );w.resetTextColor();w.setBackgroundColor( "#dcdfe4" );var w = wm.findWidgetById( "w163" );w.setEnabled( false );w.resetTextColor();wm.setToolTip( wm.findWidgetById( "w165" ), "Locked" );var w = wm.findWidgetById( "w165" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w166" );w.setEnabled( false );w.resetTextColor();w.setBackgroundColor( "#dcdfe4" );wm.setToolTip( wm.findWidgetById( "w168" ), "Locked" );var w = wm.findWidgetById( "w168" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w169" );w.setEnabled( false );w.resetTextColor();w.setBackgroundColor( "#dcdfe4" );wm.setToolTip( wm.findWidgetById( "w171" ), "Locked" );var w = wm.findWidgetById( "w171" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w172" );w.setEnabled( false );w.resetTextColor();w.setBackgroundColor( "#dcdfe4" );wm.setToolTip( wm.findWidgetById( "w174" ), "Locked" );var w = wm.findWidgetById( "w174" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w175" );w.setEnabled( false );w.resetTextColor();w.setBackgroundColor( "#dcdfe4" );wm.setToolTip( wm.findWidgetById( "w177" ), "Locked" );var w = wm.findWidgetById( "w177" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w179" );w.setEnabled( false );w.resetTextColor();w.setBackgroundColor( "#dcdfe4" );var w = wm.findWidgetById( "w180" );w.setEnabled( false );w.resetTextColor();wm.setToolTip( wm.findWidgetById( "w187" ), "Locked" );var w = wm.findWidgetById( "w187" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w189" );w.setEnabled( false );w.resetTextColor();w.setBackgroundColor( "#dcdfe4" );var w = wm.findWidgetById( "w190" );w.setEnabled( false );w.resetTextColor();var w = wm.findWidgetById( "w191" );w.setEnabled( false );w.resetTextColor();var w = wm.findWidgetById( "w193" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w196" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w199" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w202" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w205" );w.setIcon( "rwt-resources/generated/9b5ecf3b" );var w = wm.findWidgetById( "w217" );w.setVisibility( true );var w = wm.findWidgetById( "w226" );w.setIcon( "rwt-resources/generated/ce9553dd" );var w = wm.findWidgetById( "w228" );w.setValue( "C001ADD5" );org.eclipse.swt.TextUtil.setSelection( w, 0, 8 );var w = wm.findWidgetById( "w233" );w.setIcon( "rwt-resources/generated/ce9553dd" );var w = wm.findWidgetById( "w237" );w.setIcon( "rwt-resources/generated/ce9553dd" );var w = wm.findWidgetById( "w238" );w.setMonth( 10 );w.setDay( 5 );var w = wm.findWidgetById( "w241" );w.setIcon( "rwt-resources/generated/ce9553dd" );var w = wm.findWidgetById( "w245" );w.setIcon( "rwt-resources/generated/ce9553dd" );var w = wm.findWidgetById( "w254" );w.setIcon( "rwt-resources/generated/ce9553dd" );var w = wm.findWidgetById( "w260" );w.setIcon( "rwt-resources/generated/ce9553dd" );var w = wm.findWidgetById( "w266" );w.setIcon( "rwt-resources/generated/ce9553dd" );var w = wm.findWidgetById( "w272" );w.setIcon( "rwt-resources/generated/ce9553dd" );var w = wm.findWidgetById( "w278" );w.setIcon( "rwt-resources/generated/ce9553dd" );var w = wm.findWidgetById( "w289" );w.setVisibility( false );var w = wm.findWidgetById( "w290" );w.setItemCount( 1 );w.setFocusIndex( -1 );var w = new org.eclipse.swt.widgets.TableItem( wm.findWidgetById( "w290" ), 0 );wm.add( w, "w562", false );w.setTexts( [ "C001ADD5", "", "11/5/09", "", "Not Required/Completed", "Id Cust Sort Code 1", "", "", "", "" ] );w.update();var w = wm.findWidgetById( "w305" );w.setEnabled( false );var w = wm.findWidgetById( "w309" );w.setEnabled( false );var w = wm.findWidgetById( "w310" );w.setEnabled( false );var w = wm.findWidgetById( "w311" );w.setEnabled( false );var w = wm.findWidgetById( "w312" );w.setEnabled( false );var w = wm.findWidgetById( "w314" );w.setEnabled( true );var w = wm.findWidgetById( "w315" );w.setEnabled( true );var w = wm.findWidgetById( "w317" );w.setEnabled( false );var w = wm.findWidgetById( "w331" );w.setEnabled( false );var w = wm.findWidgetById( "w332" );w.setEnabled( false );var w = wm.findWidgetById( "w333" );w.setEnabled( false );var w = wm.findWidgetById( "w334" );w.setEnabled( false );var w = wm.findWidgetById( "w335" );w.setEnabled( false );var w = wm.findWidgetById( "w336" );w.setEnabled( false );var w = wm.findWidgetById( "w338" );w.setEnabled( false );var w = wm.findWidgetById( "w339" );w.setEnabled( false );var w = wm.findWidgetById( "w340" );w.setEnabled( false );var w = wm.findWidgetById( "w341" );w.setEnabled( false );var w = wm.findWidgetById( "w346" );w.setEnabled( false );var w = wm.findWidgetById( "w16" );w.setActiveControl( wm.findWidgetById( "w228" ) );org.eclipse.swt.WidgetManager.getInstance().focus( "w228" );
any help on this will be highly appreciated.
thanks & regards,
sudesh
[Updated on: Mon, 20 December 2010 10:06] by Moderator
Re: IDoubleClickListener [message #645802 is a reply to message #645778] Mon, 20 December 2010 11:18 Go to previous messageGo to next message
Hi Sudesh,
could you open a bugzilla with a self-running snippet to reproduce it?
Which version of RAP are you using?
Best,
Ivan
On 20.12.2010 5:02 PM, Sudesh Bulathsinhala wrote:
> hi,
> CheckboxTableViewer in RAP. however the same works fine, when double
> i've tried to debug using IDoubleClickListener and surprisingly it
> works while debug mode, and when invoked several times repeatedly it
> METHOD :
> @Override
> .getSelection();
> .getFirstElement();
> != null) {
> getName(),
> new UUIDDataValue(
> .getRecordId()));
> ERROR MESSAGE :
> thanks & regards,
> sudesh
Re: IDoubleClickListener [message #646455 is a reply to message #645802] Fri, 24 December 2010 07:17 Go to previous messageGo to next message
hello ivan,
i'm using 1.4 M4 right now, i had this problem through out earlier versions.
will report this in bubzilla as per your instructions.
rgs,
sudesh
Re: IDoubleClickListener [message #646463 is a reply to message #646455] Fri, 24 December 2010 08:25 Go to previous messageGo to next message
hello ivan,
i just did some further analysis and actually located where the real problem was.
during the following method, it gets crashed..
public void switchView(final String viewType) {
/* RECORD_VIEW */
if (viewType.equals(RECORD_VIEW)) {
_stackLayout.topControl = _gridRecordContentComposite;
/* GRID_VIEW */
else if (viewType.equals(GRID_VIEW)) {
_stackLayout.topControl = _gridTableContentComposite;
_gridComposite.layout();
actually the above method functionality is expected to switch between grid view and record view using StackLayout. when the appropriate type is invoked from DoubleClickListener event.
(the idea is to bring the underlying composite to the topmost, according to the viewType parameter)
the above snippet works fine with RCP, and sometimes it works with RAP in debug mode, provided i run through incremental steps.
however, if i invoke the same method from tool bar action, it just works in both RCP and RAP, without crashing.
hope above scenario will help you further.
any idea ?
regards,
sudesh
Re: IDoubleClickListener [message #646552 is a reply to message #646463] Mon, 27 December 2010 05:55 Go to previous messageGo to next message
Hi Sudesh,
I will really appreciate, if you open a bugzilla with a self-running
snippet to reproduce it. Without it, I can't help you much.
Ivan
On 24.12.2010 3:25 PM, Sudesh Bulathsinhala wrote:
> hello ivan,
> problem was.
> /* RECORD_VIEW */
> /* GRID_VIEW */
> is invoked from DoubleClickListener event. (the idea is to bring the
> any idea ?
> regards,
> sudesh
Re: IDoubleClickListener [message #646568 is a reply to message #646552] Tue, 28 December 2010 15:08 Go to previous messageGo to next message
hello ivan,
will do that tomorrow and notify you immediately.
thanks and regards,
sudesh
Re: IDoubleClickListener [message #647826 is a reply to message #646568] Sun, 09 January 2011 12:23 Go to previous messageGo to next message
hello ivan,
actually it's working properly as expected. i had a method attached to both DoubleClickListener and SelectionListener, which is conflicting. this was causing the trouble. i had to move certain stuff to SelectionListener and the rest to DoubleClickLitener and it's working as expected.
thanks & regards,
sudesh
Re: IDoubleClickListener [message #647865 is a reply to message #647826] Mon, 10 January 2011 03:17 Go to previous messageGo to next message
Hi Sudesh,
it's good to know that you find a solution of your problem, but I think
that it's a workaround. In any case, there should be NO javascript error
on the client. I'm interesting in a snippet that provokes this
javascript error and really ask you to open a bug with a snippet to
reproduce it.
Thanks in advanced,
Ivan
On 1/9/2011 7:23 PM, Sudesh Bulathsinhala wrote:
> hello ivan,
> as expected.
> thanks & regards,
> sudesh
Re: IDoubleClickListener [message #659697 is a reply to message #645778] Tue, 15 March 2011 05:50 Go to previous messageGo to next message
I seem to have the same problem. I have 1 method. This method lies in an editor, that has a list of contained further objects. The list of contained objects is displayed in a table. The method takes the ID of a selected contained object and tries to open another editor, to display the content of the selected object.
This code to open another editor works, when I trigger it from a toolbar's button, that is inside the first editor. When I add a DoubleClickListener, that triggers the same method, it crashes every time with a javascript error.
Error: TypeError: Cannot call method '_render' of undefined
Then I have added a breakpoint to the first line of the triggered method. When the VM stops at this point and I simply press "play" the method works. Without the breakpoint it is crashing again.
Sorry I am too layz to create a snippet for now. But can anyone use the information I could give?
Best regards!
Re: IDoubleClickListener [message #659700 is a reply to message #659697] Tue, 15 March 2011 05:58 Go to previous messageGo to next message
this is probably a bug in RAP. If you have overcome your laziness ;) we
would appreciate a bug report with information on how to reproduce the
issue.
TIA
Rüdiger
> time with a javascript error.Could not evaluate javascript response:
> Best regards!
Re: IDoubleClickListener [message #659702 is a reply to message #659697] Tue, 15 March 2011 05:59 Go to previous messageGo to next message
Hi Bassspieler,
any kind of JavaScript errors are bugs in RAP, but without a snippet to
reproduce it it's very hard to do anything about it.
Best,
Ivan
> Best regards!
Re: IDoubleClickListener [message #664106 is a reply to message #645778] Thu, 07 April 2011 09:47 Go to previous messageGo to next message
Still don't have overcome my laziness, but I have new information. I could solve my problem.
I had an editor that opened another editor via double-click. The opended editor had a refreshing method at the end of his start-up process that fetched all instances of editors of the kind of the very first editor and forced them to update. It was not a loop, but a strange thing, though. I changed the behaviour so that the 2nd editor does not try to refresh the 1st editor's types editors. Now the double click works fine.
Sounds like some kind of runtime-thready-issue, but I am not so into this stuff.
Bassspieler
[Updated on: Thu, 07 April 2011 09:47] by Moderator
Re: IDoubleClickListener [message #675740 is a reply to message #664106] Wed, 01 June 2011 07:31 Go to previous messageGo to next message
I am into this trouble again. This time I have a editor with a table. Double click on the table opens another editor. The only thing I do within the IDoubleClickListener is
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().openEditor(input, editorId)
But I get
Error: 'undefined' ist Null oder kein Objekt
message: 'undefined' ist Null oder kein Objekt
number: -2146823281
description: 'undefined' ist Null oder kein Objekt
Debug: off
Request: org.eclipse.swt.events.widgetDefaultSelected=w512&org.eclipse.swt.events.widgetSelected.index=0&org.eclipse.swt.events.keyDown=w512&org.eclipse.swt.events.keyDown.keyCode=13&org.eclipse.swt.events.keyDown.charCode=0&org.eclipse.swt.events.keyDown.modifier=&w1.cursorLocation.x=478&w1.cursorLocation.y=527&uiRoot=w1&requestCounter=123
The reason for this seems to be the first editor. It's a special one. I have other editors where the same actions runs fine. The special thing with the editor is, that it contains a ComboBox and a table. On changing selection in the box, the TableViewer gets set new columns and data.
The upper code that opens the editor returns the correct IEditorPart, but something while trying to create the UI crashes. The behaviour is exactly as described in the first post. In debug mode everything runs fine. On runtime is crashes.
I know you RAP developers need code that contains the error, but still I can't help with that. So this post may serve as further documentation that something about the IDoubleClickListener is strange.
Best regards.
Re: IDoubleClickListener [message #675754 is a reply to message #675740] Wed, 01 June 2011 07:54 Go to previous message
Hi Bassspieler,
as we mention several times in this thread, without a bugreport and a
snippet to reproduce it we can't help you much.
Best,
Ivan
> editorId)
> But I get
> Quote:
>> number: -2146823281
>> Debug: off
>> Request:
> and data.
> Best regards.
Previous Topic:Target Platform RAP and RCP
Next Topic:How to use org.eclipse.compare with RAP
Current Time: Sun Jul 27 01:11:37 EDT 2025
Powered by FUDForum. Page generated in 0.05409 seconds
