Home » Eclipse Projects » EclipseLink » Lazy load on OneToMany mapping does not work
Lazy load on OneToMany mapping does not work [message #644899] |
Tue, 14 December 2010 11:37  |
Hi!
I'm using EclipseLink 1.1.4 to map a relationship where an "AreaSurface" can belong to several "Area". By querying Area by id I get the Area and its AreaSurface, but if I use a geometry query I get the AreaSurface but not its Areas. The log shows that a database query is prepared
[EL Fine]: ClientSession(15830327)--Connection(29407392)--SELECT FKFOGGUID, FNR_FR, AREANR FROM AREA WHERE (FKFOGGUID = ?)
bind => [859269b6-5200-49ab-b47f-785c4c305d4d]
but never executed. I do get the Areas if I set the OneToMany mapping in AreaSurface to eager. Any idea what may be wrong?
Here are the classes:
@Entity
public class AreaSurface {
@Id
@Column(name = "GUID")
private String uuid;
@StructConverter(name = "GeometryConverter",
converter = ConverterType.GEOMETRY_CONVERTER)
@Convert("GeometryConverter")
@Column(name = "SHAPE", columnDefinition = "MDSYS.SDO_GEOMETRY", nullable = false)
private Geometry geometry;
@OneToMany(mappedBy = "areaSurface") //if fetch = FetchType.EAGER is set it works
private List<Area> areas;
// Getters and setters..
@Entity
public class Area{
@Id
@Column(name = "FKFOGGUID")
private String fkfogguid;
@Column(name = "FNR_FR", insertable = false, updatable = false)
private String areaId;
@Column(name = "AREANR")
private int areaNumber;
@ManyToOne()
@JoinColumn(name = "FKFOGGUID", referencedColumnName = "GUID", insertable = false, updatable = false)
private AreaSurface areaSurface;
Re: Lazy load on OneToMany mapping does not work [message #645155 is a reply to message #645104] |
Wed, 15 December 2010 12:44   |
Quote: | The log is showing the query being executed, not prepared.
Does it really? I attached some more logs, and as you can see the eager log has the line "Execute query ReadObjectQuery(name="areaSurface" referenceClass=AreaSurface )" while the lazy log skips straight to "release unit of work".
Eager log:
[EL Finest]: UnitOfWork(3966697)--Execute query ReadAllQuery(referenceClass=AreaSurface )
[EL Finest]: ClientSession(32314330)--Execute query ReadAllQuery(referenceClass=AreaSurface)
[EL Fine]: ClientSession(32314330)--Connection(5511938)--SELECT GUID, SHAPE FROM AREA_SURFACE WHERE ((MDSYS.SDO_FILTER(SHAPE, ?, ?) = ?) AND (MDSYS.SDO_RELATE(SHAPE, ?, ?) = ?))
bind => [JGeometry (gtype=1, dim=2, srid=3006, QUERYTYPE=WINDOW, TRUE, JGeometry (gtype=1, dim=2, srid=3006, MASK=ANYINTERACT QUERYTYPE=WINDOW, TRUE]
[EL Finest]: ClientSession(32314330)--Execute query ReadAllQuery(name="areas" referenceClass=Area sql="SELECT FKFOGGUID, FNR_FR, AREANR FROM AREA WHERE (FKFOGGUID = ?)")
[EL Fine]: ClientSession(32314330)--Connection(5511938)--SELECT FKFOGGUID, FNR_FR, AREANR FROM AREA WHERE (FKFOGGUID = ?))
[EL Finest]: ClientSession(32314330)--Execute query ReadObjectQuery(name="areaSurface" referenceClass=AreaSurface )
[EL Finer]: UnitOfWork(3966697)--release unit of work
[EL Finer]: ClientSession(32314330)--Connection(5511938)--rollback transaction
[EL Finer]: ClientSession(32314330)--client released
Lazy log:
[EL Finest]: UnitOfWork(26193147)--Execute query ReadAllQuery(referenceClass=AreaSurface )
[EL Finest]: ClientSession(32579087)--Execute query ReadAllQuery(referenceClass=AreaSurface )
[EL Fine]: ClientSession(32579087)--Connection(27595538)--SELECT GUID, SHAPE FROM AREA_SURFACE WHERE ((MDSYS.SDO_FILTER(SHAPE, ?, ?) = ?) AND (MDSYS.SDO_RELATE(SHAPE, ?, ?) = ?))
[EL Finest]: ServerSession(22238933)--Execute query ReadAllQuery(name="areas" referenceClass=Area )
[EL Finest]: ServerSession(22238933)--reconnecting to external connection pool
[EL Fine]: ServerSession(22238933)--Connection(1399004)--SELECT FKFOGGUID, FNR_FR, AREANR FROM AREA WHERE (FKFOGGUID = ?))
[EL Finer]: UnitOfWork(26193147)--release unit of work
[EL Finer]: ClientSession(32579087)--Connection(27595538)--rollback transaction
[EL Finer]: ClientSession(32579087)--client released
[EL Finer]: ServerSession(22238933)--client acquired
[EL Finer]: ClientSession(5174832)--Connection(322649)--begin transaction
java.lang.AssertionError: expected:<1> but was:<0>
at org.junit.Assert.fail(Assert.java:74)
at org.junit.Assert.failNotEquals(Assert.java:448)
Here is the unit test:
@Test
public void findAreaByPointInAreaSurface() {
Point point = new GeometryFactory(new PrecisionModel(),3006).createPoint(new Coordinate(6598735, 714690));
List<AreaSurface> surfaces = repository.findSurfacesByGeometry(point, AreaSurface.class);
assertEquals(1, surfaces.size());
AreaSurface surface = surfaces.get(0);
assertNotNull(surface.getAreas());
assertEquals(1, surface.getAreas().size()); // <-- fails if lazy!
Area area = surface.getAreas().get(0);
And this is the query code:
public List<AreaSurface> findSurfacesByGeometry(Geometry geometry, Class clazz) {
ReadAllQuery query = new ReadAllQuery(clazz);
query.setIsReadOnly(true);
ExpressionBuilder builder = query.getExpressionBuilder();
SpatialParameters spatialParameters = new SpatialParameters();
spatialParameters.setQueryType(SpatialParameters.QueryType.WINDOW);
SpatialParameters spatialParameters2 = new SpatialParameters();
spatialParameters2.setQueryType(SpatialParameters.QueryType.WINDOW);
SpatialParameters.Mask [] mask;
if(geometry instanceof Polygon || geometry instanceof MultiPolygon) {
mask = new SpatialParameters.Mask [] {
SpatialParameters.Mask.EQUAL,
SpatialParameters.Mask.OVERLAPBDYDISJOINT,
SpatialParameters.Mask.OVERLAPBDYINTERSECT,
SpatialParameters.Mask.CONTAINS,
SpatialParameters.Mask.COVERS,
SpatialParameters.Mask.INSIDE,
SpatialParameters.Mask.COVEREDBY,
SpatialParameters.Mask.ON
}; // Basically ANYINTERACT - TOUCH.
} else {
SpatialParameters.Mask.ANYINTERACT
spatialParameters2.setMasks(mask);
JGeometry jgeometry = GeometryConverter.toJGeometry(geometry);
Expression filter = SpatialExpressionFactory.filter(builder.get("geometry"), jgeometry, spatialParameters);
Expression relate = SpatialExpressionFactory.relate(builder.get("geometry"), jgeometry, spatialParameters2);
Expression spatialCriteria = filter.and(relate);
query.setSelectionCriteria(spatialCriteria);
return (List<AreaSurface>) entityManager.getActiveSession().executeQuery(query);
Thanks alot!
Current Time: Fri Jul 18 22:21:40 EDT 2025
Powered by FUDForum. Page generated in 0.04988 seconds
