Home » Modeling » M2T (model-to-text transformation) » Setting up mwe workflow file contents?(Problem with setting up workflow file for xpand generator)
icon9.gif  Setting up mwe workflow file contents? [message #645640] Sun, 19 December 2010 05:46 Go to next message
I have been trying for few days now to set up the mwe workflow file for xpand generator I am trying to build.
The problem is the i have separated my:
1. metamodels
2. m2t qvt transformations
3. output instances of m2m transformations
4. xpand templates and workflows
into 4 separate projects (respectively).
I managed to reference them all, and the editor for xpand template file is properly reading metamodels (e.g. ctrl-space in template editor gives me list of metamodel elements).
However, when I run my generator.mwe file, it gives me following error:
Dec 19, 2010 11:43:51 AM org.eclipse.emf.mwe.core.WorkflowRunner prepare
INFO: --------------------------------------------------------------------------------------
INFO: EMF Modeling Workflow Engine 0.7.2, Build v200908120417
INFO: (c) 2005-2009 openarchitectureware.org and contributors
INFO: running workflow: C:/eclipse_modeling/ado_generator/generatorM2TTransformations/workflows/entityWorkflow.mwe
INFO:
Dec 19, 2010 11:43:51 AM org.eclipse.emf.mwe.utils.StandaloneSetup setPlatformUri
INFO: Registering platform uri 'C:\eclipse_modeling\ado_generator'
Dec 19, 2010 11:43:51 AM org.eclipse.emf.mwe.utils.StandaloneSetup registerPackage
INFO: Adding dynamic EPackage 'http://www.dorius-soft.com/ejb3' from 'platform:/resource/generatorMetamodels/model/ejb3.ecore'
Dec 19, 2010 11:43:51 AM org.eclipse.emf.mwe.core.container.CompositeComponent internalInvoke
INFO: Reader: Loading model from platform:/resource/generatorOutput/model/OrganizacijaEntities.xmi
Dec 19, 2010 11:43:52 AM org.eclipse.emf.mwe.core.container.CompositeComponent internalInvoke
INFO: Generator(generate): generating 'EntityBeanTemplate::entityTemplate FOR EntityBean' => src-gen
Dec 19, 2010 11:43:52 AM org.eclipse.xtend.expression.AbstractExpressionsUsingWorkflowComponent invokeInternal
SEVERE: Error in Component generate of type org.eclipse.xpand2.Generator:
	EvaluationException : Couldn't find type or property 'EntityBean'
	[69,10] on line 1 'EntityBean'
Dec 19, 2010 11:43:52 AM org.eclipse.emf.mwe.core.WorkflowRunner executeWorkflow
SEVERE: Workflow interrupted. Reason: Couldn't find type or property 'EntityBean'
Dec 19, 2010 11:43:52 AM org.eclipse.emf.mwe.core.WorkflowRunner logIssues
SEVERE: [ERROR]: Couldn't find type or property 'EntityBean'(Element: EntityBean; Reported by: Generator(generate): generating 'EntityBeanTemplate::entityTemplate FOR EntityBean' => src-gen)
SEVERE: [ERROR]: Couldn't find type or property 'EntityBean'(Element: EXPAND EntityBeanTemplate::entityTemplate FOR EntityBean; Reported by: Generator(generate): generating 'EntityBeanTemplate::entityTemplate FOR EntityBean' => src-gen)
Here is the source for generator.mwe file:
<?xml version="1.0"?>
<workflow>
	<property name="model" value="platform:/resource/generatorOutput/model/OrganizacijaEntities.xmi"/>
	<property name="out" value="src-gen" />
	<!-- set up EMF for standalone execution -->
	<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
		<platformUri value=".."/>
		<RegisterEcoreFile value="platform:/resource/generatorMetamodels/model/ejb3.ecore"/>
	</bean>
	<!-- load model and store it in slot 'model' -->
	<component class="org.eclipse.emf.mwe.utils.Reader">
		<uri value="${model}" />
		<modelSlot value="model" />
	</component>
	<!--  generate code -->
	<component class="org.eclipse.xpand2.Generator" id="generate">
		<metaModel id="mm" class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
		<expand value="EntityBeanTemplate::entityTemplate FOR EntityBean" />
		<outlet path="${out}"/>
	</component>
</workflow>
Can anyone help me, please? Sad
Re: Setting up mwe workflow file contents? [message #645668 is a reply to message #645640] Sun, 19 December 2010 12:46 Go to previous messageGo to next message
should be
<expand value="EntityBeanTemplate::entityTemplate FOR model" />
since yiu stored the model in a slot named "model" in the reader
~Christian
Re: Setting up mwe workflow file contents? [message #645721 is a reply to message #645668] Mon, 20 December 2010 03:38 Go to previous message
Thank you so so much, it works!!!
Previous Topic:Re: Regarding XPand template file(contd..)
Next Topic:[Acceleo 3] Internal Error - installBundle - NullPointerException
Current Time: Tue Sep 16 18:15:27 EDT 2025
Powered by FUDForum. Page generated in 0.05056 seconds
