Home » Language IDEs » PHP Development Tools (PDT) » trouble with Zend Debugger(moving this post to different board)
trouble with Zend Debugger [message #645630] Sat, 18 December 2010 21:43 Go to next message
hi,
i posted this on another board:
http://www.eclipse.org/forums/index.php?t=msg&th=201928& amp;start=0&S=157315387bc1969a380887df2e7c9241
with apologies, i'm posting it again on this one, where hopefully it will have more interest.
i have been going in circles trying to get Eclipse + php debugging for Drupal working. i have installed Eclipse a couple of times from different sources. then i decided to delete them and pick up the 'all-in-one' version of Eclipse from the Zend site:
http://www.zend.com/en/community/pdt
(I got the 32 bit for Linux. this is not the Zend Studio upgrade.)
with Eclipse Helios up and running, i installed the XTend Drupal plugin:
http://xtend.us/downloads/eclipse
I also downloaded the Zend Server-Debugger from this page:
http://downloads.zend.com/pdt/server-debugger/
http://downloads.zend.com/pdt/server...23-i386.tar.gz
i have some reservations about where I put Eclipse and the Zend Debugger. I put them both in my Drupal root; i.e.,
http://localhost/Drupal
then i modified the PHP.ini. (I know we're not supposed to do this. however, every time i try to create an INI in the /etc/apache2/conf.d folder, I get an error. i don't know how to make a custom INI.)
i changed the PHP to add these lines:
zend_extension="/usr/lib/php5/20090626+lfs/xdebug.so"
zend_extension_manager.debug_server=/var/www/Drupal/ZendDebu gger-5.2.14-linux-glibc23-i386/5_2_x_comp
zend_debugger.allow_hosts=127.0.0.1
zend_debugger.expose_remotely=always
I have closely looked over the paths given for zend_extension and zend_extension_manager.debug_server. The paths are correct.
when i run phpinfo.php, among the many lines of output I see this:
This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.3.0, Copyright (c) 1998-2010 Zend Technologies
(I don't see a message indicating the Zend Debugger is working.)
from Eclipse, i have created a project that points to the folder of my Drupal installation. I have created a Debug Configuration that points to the index.php for the particular installation of Drupal i am attempting to debug.
when i try to test the debug configuration i get this familiar error:
"A timeout has occurred on http://localhost/Drupal/foobar/index.php . Please verify the Zend Debugger is properly installed on the server and that the 'dummy.php' is located in your Web Server's document root."
i don't think the problem is the dummy.php, as i copied it into /var/www .
does anyone have any ideas?
thanks in advance.
(in response to a suggestion from someone on another board (besides eclipse.org) I commented out the reference in the PHP.ini to Zend_Extension_Manager. Here's my reply to the person who made that suggestion).
...thanks for the reply. i commented out the line in php.ini that refers to the Zend_extension_manager. the php.ini looks like:
i restarted Apache. i also verified (again) that the zend_extension path is correct.
unfortunately, nothing has changed. phpInfo shows the same message; it doesn't indicate the Zend Debugger is working.
also, when i start Eclipse Helios, click 'debug configurations' and then try to test the index.php for my Drupal installation, i get the same error about Zend Debugger and/or the dummy.php.
Re: trouble with Zend Debugger [message #645699 is a reply to message #645630] Sun, 19 December 2010 22:18 Go to previous message
hi,
i clicked on the 'configuration' button on the Debug Configurations page. i changed the document root path. i'm no longer getting the error i mentioned at the top of this thread. instead, now i'm receiving:
a timeout occurred when the debug server attempted to connect to the following client hosts/IPS:
127.0.0.1
i found these threads which discuss the error message:
http://drupal.org/node/929198
http://www.eclipse.org/forums/index.php?t=tree&th=197804 &S=0e4cdbfcd13d6ea5d4cc662fd90b15db
apparently a lot of people just give up on Zend Debugger and try xdebug instead. i haven't quit on Zend, yet. i'm still trying to figure out how to use it.
i will post a resolution when i have one. thanks.
Previous Topic:Can't compare CVS files in PDT
Next Topic:Help developing DCOM client in JAVA
Current Time: Sat Jul 26 20:33:43 EDT 2025
Powered by FUDForum. Page generated in 0.03126 seconds
