Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Content Assist for methods in custom editor(How to display parameter name list of a method???)
icon5.gif  Content Assist for methods in custom editor [message #632057] Mon, 11 October 2010 07:51 Go to next message
I am working on developing an editor. For this editor, we need to provide content assist support. So, for that, I extended "ScriptCompletionEngine" class.
My issue is with parameter list in methods. After creating CompletionProposal for method, I set parameter values of that method. And, yeah, it is getting displayed. But as we see in Java editor, the selected parameter name is not getting highlighted in the help info balloon. If there are multiple parameter names, then when I press tab, selection goes to next paramater but at the same time the help info balloon disappears.. I tried the same in a Ruby editor and there also same thing is happening.
Also, do I need to give the parameter type along with parameter name while setting the parameter list?
eg: parameter -> param1, type int.. So the parameter name to be set in proposal.setParameterNames() is "int param1"?? Or is there any other section where I need to mention the parameter type?
Following is the summary of my requirement/issues
1) Selected parameter name is not getting highlighted.
2) Help info balloon disappears when selection is changed to next parameter by selecting tab.
3) How to display parameter type along with parameter name?
Thanks in advance,
Daisy.
Re: Content Assist for methods in custom editor [message #635446 is a reply to message #632057] Tue, 26 October 2010 15:39 Go to previous messageGo to next message
Hi Daisy,
Looks like these items are not completely supported at the moment.
The good news they are among our short-term plans.
Please stay tuned.
Alex
Re: Content Assist for methods in custom editor [message #635821 is a reply to message #635446] Thu, 28 October 2010 05:24 Go to previous messageGo to next message
Thank you, Alex.
Is there any expected release date for the feature?
Daisy.
Re: Content Assist for methods in custom editor [message #645569 is a reply to message #632057] Fri, 17 December 2010 21:09 Go to previous messageGo to next message
Don't know if this helps, but here is my workaround for the same problem:
 * @author carlk
public class UMethodProposal extends CompletionProposal {
	 * @param kind
	 * @param completionLocation
	 * @throws ModelException
	public UMethodProposal(int completionLocation, IMethod method) throws ModelException {
		super(CompletionProposal.METHOD_REF, completionLocation);
		List<String> paramaterTypesAndNames = new ArrayList<String>();
		for( IParameter param : method.getParameters() )
			paramaterTypesAndNames.add(param.getType() + " " + param.getName());
		setParameterNames(paramaterTypesAndNames.toArray(new String[]{}));
		setFlags(method.getFlags());
In the CompletionEngine I just create an instance of this for the proposal for methods.
- C.
Re: Content Assist for methods in custom editor [message #707407 is a reply to message #645569] Mon, 01 August 2011 12:00 Go to previous messageGo to next message
In CompletionEngine, I have the folowing code:
proposal = this.createProposal(CompletionProposal.METHOD_DECLARATION, this.actualCompletionPosition);
IMethod method = (IMethod) element;
proposal.setFlags(method.getFlags());
proposal.setParameterNames(method.getParameterNames());
proposal.setModelElement(element);
proposal.setName(name);
proposal.setCompletion(name);
I get completion only on function name, no parenthesis and worse parameters are not available to fill.
What did I miss?
Any clue?
Re: Content Assist for methods in custom editor [message #707929 is a reply to message #707407] Tue, 02 August 2011 04:34 Go to previous messageGo to next message
Hi Kevin,
In this line, for the completion proposal type, please make sure that you are looking for METHOD_DECLARATION itself. There is another type, METHOD_REF, which will complete the reference. In my case, METHOD_REF is the one that served my purpose.
Hope this helps.
Daisy.
Re: Content Assist for methods in custom editor [message #707974 is a reply to message #707929] Tue, 02 August 2011 05:38 Go to previous message
It sure helps, I changed METHOD_DECLARATION for METHOD_REF and it works just fine.
Previous Topic:Debug Perspective not triggering on program suspend
Next Topic:DLTK Documentation
Current Time: Fri Jul 18 23:56:14 EDT 2025
Powered by FUDForum. Page generated in 0.05771 seconds
